Faulty tachometer
johnlangford
PostPosted: 17:15 - 08 Nov 2024    Post subject: Faulty tachometer Reply with quote
Recently bought Yamaha ybr125 custom 2008. - runs well
But rev counter not working.
Inside tachometer two wires blue and black for light then three wires
Black
Green
Black/ yellow
I see 6.3 volts between b/y and ground with engine running but no voltage on green!?
Does this mean fault is probably in ecu?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:30 - 08 Nov 2024    Post subject: Reply with quote
Normally you would expect an earth, a reference which will be whatever you measure across the battery, and the signal which will be somewhere between 0 and the reference voltage which will depend on engine speed.
Seems your ref voltage is missing. I would try connecting the green to the positive connection on the battery when the engine is running.
Triumph Sprint ST 1050
WD Forte
PostPosted: 17:48 - 08 Nov 2024    Post subject: Reply with quote
The manual shows the tacho has 3 wires if we ignore the back light
Power in (12v) on a Brown wire
This also powers the fuel gauge,eml and neutral lights
Ground on a Black cable
this ground is also common to other lamps and gauges
The tacho gets its driving pulses from the ECU on a Black/Yellow cable
If you cant detect pulses on this when the engine is running, you wont get any movement
on the tacho.
At this point we dont know if you have a steady 6.3 V DC or your meter cant handle
pulses and is averaging out what it reads
The only green cable I see in the area is the cable between the fuel gauge and sender so you may be a wee bit confused?
I may be of course, but I doubt it's the ecu or tacho at fault
its an old bike so I would check and clean all connectors first
bikers smell of wee
jeffyjeff
PostPosted: 18:07 - 08 Nov 2024    Post subject: Reply with quote
WD Forte wrote:
At this point we dont know if you have a steady 6.3 V DC or your meter cant handle pulses and is averaging out what it reads
If you have a higher end meter, you could try setting it to frequency (Hz) and see how the signal on the black/yellow wire increases as you rev the engine. From your symptoms, sounds like a problem on the green wire.
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
The last post was made 2 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 39.93 Kb
