2019 EFI Keeway Superlight 125
BERT456
PostPosted: 20:16 - 31 Jul 2020    Post subject: 2019 EFI Keeway Superlight 125 Reply with quote
Hi all,
purchased the above bike last October, done 3500 miles and its been great up to now.
The bike starts and idles fine but if I slowly increase the throttle, at around 3000rpm it will either cut out or if I keep opening the throttle it will run, but a little rough.
If the engines cold it will tend to cut out at 3000rpm
If the engines warm it will run a little rough between 2-3000rpm and then seems fine.? May be under powered?
I know little about EFI, but I'm guessing one of the sensors maybe faulty. I think I have identified its sensors correctly,
1) Idle air control valve. 2) TPS. 3) Intake Pressure, then Engine temp and Lambda.
If anyone has any thoughts on what could be causing this issue I would appreciate hearing them. Thanks very much
Easy-X
PostPosted: 21:19 - 31 Jul 2020    Post subject: Reply with quote
For a start they run a little lean, it seems more noticeable from cold.
I didn't have it quite as bad with mine but I found readjusting the valve gaps to spec made a difference. Also worth eyeballing the spark plug while you're at it along with the air filter.
jaffa90
PostPosted: 23:18 - 31 Jul 2020    Post subject: Reply with quote
"""2019 EFI Keeway Superlight 125""
Surely under a warranty?
Also sale of goods act.
Easy-X
PostPosted: 23:24 - 31 Jul 2020    Post subject: Reply with quote
Good shout. Mine was a salvage job so no warranty left Wink Has the OP asked the dealer/garage yet?
BERT456
PostPosted: 09:43 - 01 Aug 2020    Post subject: Reply with quote
Hi guys, thx for the replies, Keeways do come with a 2 year warranty if you have
them serviced every 600 miles or 6 months, I decided to try and do servicing myself.
I have read that the TPS sensor works like a potentiometer (volume control knob)
so there maybe some dirt or a break in the sensor thats causing the stalling.
Guess I'm gonna have to spend some money!!!
Easy-X
PostPosted: 11:21 - 01 Aug 2020    Post subject: Reply with quote
General comment on maintenance: don't get hyper-focused on one "problem area" and expect it to fix everything, it'll lead to disappointment.
At one point I had the whole throttle body off, cleaned the injector, re-adjusted the TPS... didn't make the slightest bit of difference! YMMV of course Smile
BERT456
PostPosted: 17:02 - 01 Aug 2020    Post subject: Reply with quote
Yeah Easy-X your right, its easy to focus on one "problem area". My issues seem to be getting worse. Still idles perfect but starting to run like cr*p through the whole rev range now. Gonna be something small I know.
thx
There is a gap of 4 years, 101 days between these two posts...
Persizi
PostPosted: 17:02 - 10 Nov 2024    Post subject: Reply with quote
How did you re-adjusted the TPS, what is the data and the values?
Easy-X
PostPosted: 17:49 - 10 Nov 2024    Post subject: Reply with quote
Lol... lot of beer under the bridge since then. I think there was a supplement in the engineering manual for fuel injection (originally these were carb bikes) and I probably followed that.
Persizi
PostPosted: 18:06 - 10 Nov 2024    Post subject: Reply with quote
Yeah, I noticed the thread is very old but just got the same bake and can't find any technical information. Do you know where I can find such an engineering manual?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:15 - 10 Nov 2024    Post subject: Reply with quote
https://www.google.com/search?q=keeway+superlight+125+service+manual+pdf&client=firefox-b-d&sca_esv=8c3b9fce3b8221a7&sxsrf=ADLYWIKcKkK48ci5m5V8UmMlYDcSjpl5KQ%3A1731258873912&ei=-ekwZ_C6N9WHhbIPrdPE4Qw&oq=keeway++service+manual&gs_lp=Egxnd3Mtd2l6LXNlcnAiFmtlZXdheSAgc2VydmljZSBtYW51YWwqAggBMgoQIxiABBgnGIoFMgYQABgHGB4yBhAAGAcYHjIGEAAYBxgeMgYQABgHGB4yBhAAGAcYHjIGEAAYBxgeMgYQABgHGB4yBhAAGAcYHjIGEAAYBxgeSI4cUHtYe3ABeAGQAQCYAUmgAUmqAQExuAEByAEA-AEBmAICoAJUwgIKEAAYsAMY1gQYR5gDAIgGAZAGCJIHATKgB8UH&sclient=gws-wiz-serp
Triumph Sprint ST 1050
Persizi
PostPosted: 18:26 - 10 Nov 2024    Post subject: Reply with quote
Thank you! I've tried that before but still I can't find any data about the TPS values.
EDIT: Found it:
Manuel entretien K-light125
It is for the K-Light but the engines are the same:
Sensor inspection: connect it to the cable and turn
on the power; measure the voltage between pin 1 and
pin 3 with multimeter;(as shown in the figure)
Standard: throttle idle position: 0.5 - 0.9V
Full-open position of throttle: about 3.5-4V
Here is the pin out for the OBD2 adapter.
https://i.imgur.com/IvfnE2i.png
That is for the Euro 4 model. For the Euro 5 might be different.
The last post was made 1 year, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 72 Kb
