| sell off honda hornet 600 |
| Yes |
40% |
[ 2 ] |
| No |
60% |
[ 3 ] |
| Total Votes : 5 |
| legendracer |
 legendracer Derestricted Danger
 Posted: 13:01 - 30 Nov 2024 Post subject: |
Or if it's a commuter, does it need a lot of money spending on it. They are pretty good bikes as-is. Does the exhaust need replacing? If not, why bother?
Shock will be tired after 10 years so probably worth servicinging/upgrading.
Fork-wise, is it just the sag that's getting to you? They were soflty sprund as new and a new shock will only amplify that feeling. You could just order up a set of linear springs correct for your weight and riding style and set the sag properly. That's an upgrade that's enormously beneficial and not particularly expensive.
If you wanted a hornet with sportsbike performance, should've bought a CBR6. Are you trying to make it into something it's not? I'd say there's a strong case for appresiating it as it is. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| legendracer |
| MarJay |
 MarJay But it's British!
| legendracer |
| MarJay |
| Polarbear |
 Polarbear Super Spammer
| Easy-X |
 Easy-X Super Spammer
 Posted: 23:02 - 30 Nov 2024 Post subject: |
I find suspension is very much a case of diminishing returns. The first bit you spend gives you the most benefit, then it both peters off and gets progrssively more expensive for each increment of further improvement.
Start getting the correct spring rate and setting your sag. That's the most important. After that you get more progressively more fiddling and expense for smaller benefits.
I'll give you the example of my VFR750 which I had the shock rebuilt and sprung for my weight and typical luggage load. I set up the static sag, it had various damping settings, all of which I left factory.
I went on a three day trip to the Highlands on it and towards the end of day 1, the shock shat itself* . I mean it totally shat itself, no damping at all, just a spring. I was still able to ride the bike on twisty highland roads at a fair percentage of my normal speed for the rest of the trip, certainly quickly enough to keep up with the pace of the group. It wasn't fantastic but it was perfectly rideable, even quite enthusiastically. Tendancy to get a bounce-on if you hit a big compression or a double bump but with a bit of fine throttle and rear brake control, it was far from unmanageable. Even got into a race with a random powerranger on a fireblade on the Darva Moor road and while I didn't pass him, he didn't shake me either. It'll have been a 1000 mile weekend and was thoroughly enjoyable.
My point? If I have one. Get the basics right, beware of guilding the lilly on what was a fairly moddle or the road sports commuter bike. Spend the extra on good tyres.
* Later turns out the re-chromed damper rod had de-laminated and blown chrome flakes throughout the internals, tearing all the oil selas and blassers the pressure bladder to shreds. Effectively became a spring with a guide-rod attached. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| legendracer |
| ThunderGuts |
| PotatoHead202... |
 PotatoHead202... Scooby Slapper
| Robby |
 Robby Dirty Old Man
| legendracer |
| ThunderGuts |
| legendracer |
| rpsmith79 |
 rpsmith79 World Chat Champion
The last post was made 1 year, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
