Softlink Camchains
virus
PostPosted: 20:28 - 30 Dec 2024    Post subject: Softlink Camchains Reply with quote
Anyone got any experience with them?
MY oilboiler Suzuki needs a new camchain soon. The motor is a pig to get in and out so I was looking at doing a soft link cam chain from above but not sure how easy it is to do and trust? Id be buying direct from a reputable manufacturer of course.
Got a mech CCT in at the moment as the auto one ran out of travel, Normally this would suggest that other components such as camchain guides, big end bearings, piston rings etc. would be in need of a once over at the same time hence its usually a full engine strip to do.
I however built this engine out of a series of second hand parts of various levels of wear and have changed cylinder head and cams for different model parts anyways. Im confident enough that its only the chain itself thats in need of replacement.
John
own: 81 xs1100g...
PostPosted: 00:00 - 31 Dec 2024    Post subject: Reply with quote
No experience of them, but if they'll take full engine power on a final drive chain under varying tension conditions and covered in road dirt. I can't see whay they wouldn't cope with compressing a few valve springs while sitting in a spotlessly clean oil bath.
yen_powell
PostPosted: 15:00 - 31 Dec 2024    Post subject: Reply with quote
Galea Cam Chains did thousands back in the day, 3 of them on my bikes, including one which did a further 80,000 miles afterwards with no problems. I think he may still be going somewhere near Wickford in Essex.
I asked about his guarantee and he said he guaranteed if it snapped I could keep both halves.
XT1200Z and a DR350 in bits
sickpup
Old Timer
PostPosted: 19:22 - 31 Dec 2024    Post subject: Reply with quote
I've done a fair few including GSXR11 and B12 engines and they work fine as long as you have the correct tool to fit them.
Laser do one, part No. 6740 but I don't know how good it is. I got mine from Hi-Level years ago so anyone who buys from them should be able to get one.
I will try and get a photo and part No. for you when I'm off work in 5 days time.
virus
PostPosted: 23:32 - 31 Dec 2024    Post subject: Reply with quote
Ah thats good to hear, this uses the same hyvo chain as in the b12. Is there any trick to making sure the gaps between plates are ok? I imagine if you peened it too much you'd create a tight spot in the chain.
own: 81 xs1100g...
PostPosted: 02:51 - 01 Jan 2025    Post subject: Reply with quote
If they are anything like final drive softlinks, they should specify a diameter the end of the pin needs to be squished out to. It's usually printed on the box or on that little bit of paper you immediately throw away.
Might be in one of the engineering reference books too, they'll probably be an ISO standard chain. I'd imagine there's one kicking about at your work.
sickpup
Old Timer
PostPosted: 10:41 - 01 Jan 2025    Post subject: Reply with quote
Been a decade since I did one but I think I just measured with verniers.
virus
PostPosted: 13:58 - 04 Jan 2025    Post subject: Reply with quote
well my new D.I.D open chain has arrived and Ive got the engine opened up. Did look at that tool sickpup suggested but Jeez thats expensive, got the US pro tool on the way for a tenner rather than the £280 for the lazer one. Got a few US pro tools and they do the job so worth the shot.
Just popped back in for a brew to warm up then im back out to the garage to count links/measure etc to check I bought the right chain before I get carried away then hopefully one afternoon next week when the tool arrives I'll get her back up and running.
John
own: 81 xs1100g...
The last post was made 1 year, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.54 - MySQL Queries: 15 - Page Size: 58.29 Kb
