changeover timer socket?
PostPosted: 23:37 - 30 Dec 2024    Post subject: changeover timer socket? Reply with quote
Is there such a thing? I've looked but not found.
It's for a reptile vivarium. The wee beastie needs it to be cooler at night than during the day but still needs heat.
The solution is currently two heat bulbs, one for day, and a lower wattage one for night. I'd like to have them on a timer.
The simple way would be two socket timers however, they are never perfectly in synch and both on at once would be bad. Current solution is to have a gap in the timing with neither on but I'd like to find a timer that instead of being on or off, switches between two sockets. Then one or the other is always on, never both.
PostPosted: 23:42 - 30 Dec 2024    Post subject: Reply with quote
The beastie in question. Drax, a baby panther chameleon. He will be a lot more colourful in a couple of months.
https://lh3.googleusercontent.com/pw/AP1GczOe5lhHkAw8-nahrqpKeZN2tjqDNImYrXwBiKcBptYHCXR2SplBbwxiAQrc9rLoDKhE-ZuqQFbuZivI69xgjCANmV3c45APqPzMLHW-uU22CZngU2pKRxu9NE-dqHbkCvFRkKX086x6a74TjNtOJc5P=w650-h876-s-no
Nobby the Bastard
Harley Gaydar
PostPosted: 23:51 - 30 Dec 2024    Post subject: Reply with quote
Or the night bulb on permanently and a supplementary one on a timer for daytime.
Don't overcomplicate the problem.
Triumph Sprint ST 1050
PostPosted: 00:05 - 31 Dec 2024    Post subject: Reply with quote
It gets too hot over too wide an area with both on at once (well, technically all three because the UV is a mercury discharge lamp).
panrider_uk
PostPosted: 00:10 - 31 Dec 2024    Post subject: Reply with quote
Tapo smart plugs
Time is always accurate and each one can have it own schedule(s).
ZebraDriver
PostPosted: 06:43 - 31 Dec 2024    Post subject: Reply with quote
Use the timer switch to power a changeover relay (or a small contactor) as one set of contacts switch off another set will switch on.
PostPosted: 08:56 - 31 Dec 2024    Post subject: Reply with quote
I know what'll work if I can't find anything simpler. A central heating controller. Has hot water and central heating outputs and a selectable timer switch
Easy-X
PostPosted: 14:02 - 31 Dec 2024    Post subject: Reply with quote
I have one of these:
https://www.tp-link.com/uk/home-networking/smart-plug/kp303/
WiFi enabled power strip that according to the blurb you can set schedules for each socket although I've not tried said feature personally. If it looks like something you could use I'll dig it out of the cupboard and test the functionality for you.
to v or not to v
PostPosted: 15:07 - 31 Dec 2024    Post subject: Reply with quote
just get a bloody cat. far less complicated.
Moto Guzzi V7.
PostPosted: 15:36 - 31 Dec 2024    Post subject: Reply with quote
I'll be honest, I'm trying to stay electromechanical with this setup. I have an immense distrust of all things microdigital and especially internet of things related.
The failure mode of an electromechanical setup is always safe. It'll either be day, night or off with time to notice a failure. We do not want a repeat of the aquarium full of hot fish soup incident.
Easy-X
PostPosted: 16:24 - 31 Dec 2024    Post subject: Reply with quote
Something like this to "electronic" ?
https://www.electrical4less.co.uk/product/live-electrical-double-module-digital-timer/
PostPosted: 17:53 - 31 Dec 2024    Post subject: Reply with quote
Can you not get an internal heater that has hardware timer and heat level settings? When I had my sugar gliders, I had a ceramic heater inside which was 28 degrees in the day and 22 at night, it was hardcoded though so I had to get in the viv to change it should DST kick in.
Found it nicer than the bulb style, 2 heat probes meant it found a nice average when the viv was 7ft tall Laughing
HabiStat do a range.
PostPosted: 18:34 - 31 Dec 2024    Post subject: Reply with quote
This is a good suggestion.
One of these:
https://cpc.farnell.com/hongfa/hf92f-240a-2c21s/power-relay-industrial-240ac-30a/dp/SW07038
and one of these:
https://cpc.farnell.com/timeguard/ntt05/timeswitch-analogue-24hr-slim/dp/PL13474
Built into an enclosure.
ZebraDriver
PostPosted: 12:23 - 01 Jan 2025    Post subject: Reply with quote
Its easy to do but remember that you need a power supply onto the relay thats live when the timer switches out. It makes it slightly difficult (but not impossible) when using a plug in timer. It may be easier to build it all into an enclosure and use a din rail mounted timer inside the box
PostPosted: 12:58 - 01 Jan 2025    Post subject: Reply with quote
That timer is a panel mount, thought I could mount it on the face of an enclosure box and take the power into the box through a gland and have two IEC sockets for the day/night outputs. Then I can just take a cable into the enclosure and branch one wire to the timer supply one one to the base terminals of the relay.
WD Forte
PostPosted: 15:11 - 01 Jan 2025    Post subject: Reply with quote
A box with two cheap, easily sourced CH timers in parallel would be simplest.
Same power in but one for high temp times one for low.
bikers smell of wee
Robby
Dirty Old Man
PostPosted: 13:30 - 03 Jan 2025    Post subject: Reply with quote
The ideal thing for your application doesn't seem to exist, which would be a traditional timer plug but using grid ac power frequency for time, like old fashioned plug-in clocks. Purely electromechanical, but decent accuracy.
The next best thing would be to source a pair of decent timer plugs from a shop you can trust, and check them every few days for drift.
The right place to ask would be a reptile forum, but it would make BCF look neurotypical.
PostPosted: 20:54 - 03 Jan 2025    Post subject: Reply with quote
Very much so. Also the people who work in the shops. They clearly know their stuff but are almost totally incapable of communicating the information you need in a coherant and organised fashion. Tried and failed to get eye contact last time so i had the guys full attention. Had to resort to asking very specific questions one at a time between mobile phone fiddles and navel gazes.
Easy-X
PostPosted: 00:26 - 04 Jan 2025    Post subject: Reply with quote
Is this not sufficient?
https://www.reptiles.swelluk.com/media/catalog/product/h/a/habistat_digital_temp_thermostat_t001001.png
https://www.reptiles.swelluk.com/habistat-digital-temperature-thermostat-day-night-timer#digital-temperature-thermostat-day-night-timer
Robby
Dirty Old Man
PostPosted: 07:04 - 04 Jan 2025    Post subject: Reply with quote
Our beloved Stinkwheel lives in 1952 and is unwilling to compromise on that. Once you accept it, he starts to make sense.
So whilst a modern, fully automated setup makes sense to you and me, he is far more comfortable with a bit more manual intervention as long as the complexity doesn't extend beyond a spring or a set of points.
It's why I find his challenges interesting. It's problem solving, but with a totally different set of constraints. Makes me think differently.
It also means we (thankfully) avoid going off in the opposite direction, which I also dislike - use an arduino and fiddle with some random code. This could provide a better solution, but it is far more likely to result in baked lizard.
When we eventually all move to electric vehicles, I'm really looking forward to seeing what he does with an old milk float.
PostPosted: 09:46 - 04 Jan 2025    Post subject: Reply with quote
I reckon I could convert an enfield bullet to electric with minimal fuckwittery. They will basically run on anything that allows you to poke a rotating shaft through the front opening of the primary chaincase and mount a sprocket on it.
PostPosted: 19:27 - 04 Jan 2025    Post subject: Reply with quote
Rigged this for just now. The timer does the UV lighting. The RCD switch does night/day heat. Pending me thinking about and implementing a timer changeover circuit. All the hard-wiring is done now so it'll just be a case of hooking it into the automated system when I get it sorted out.
Old-school dymo labels because they work, stay stuck and don't fade.
https://lh3.googleusercontent.com/pw/AP1GczOHJ_wCgGFvUxnkhvrcNGHaprKhpcoqXN_DtGh_rKBhzGJWd5SkNQ4flByO4lna9wsmgJk5wG7m0REfyQIeM3iIqJazqeRiG8RDFI_2bHP1PEAZRx7KeKSRGdHeJbDrdy2IBN05pUe3ANombWZ_WTvs=w1557-h876-s-no
sickpup
Old Timer
PostPosted: 13:11 - 20 Jan 2025    Post subject: Reply with quote
An SPDT Contactor relay would do the job.
It will require two sockets, one for power and one for the timer and normally has two trailing leads. One lead for each live
It will normally have one switched live for the small light and a switched live for the big light that when operating disconnects the small light.
In a failure state it would normally keep the small light operating.
The last post was made 1 year, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 121.92 Kb
