So... What oiled your gears today?
Bike Chat Forums Index -> Random Banter Goto page Previous  1, 2, 3 ... 111, 112, 113 ... 123, 124, 125  Next
Easy-X
PostPosted: 14:32 - 15 Feb 2025    Post subject: Reply with quote
My neighbour thinks Vegemite is the vegan version of Marmite.
hellkat
PostPosted: 02:15 - 16 Feb 2025    Post subject: Reply with quote
I gave the doge a bath and she didn't try to escape.
I have learnt the trick of putting a little towel down in the bath itself so that her claws don't make her slip and slide on the bathtub and she feels a bit more secure.
She's still not thrilled about the concept of "bath", but she now tolerates it in a much less panicky way.
blurredman
PostPosted: 15:46 - 26 Feb 2025    Post subject: Reply with quote
One of the cars passed MOT re-test. Actually...
It initially failed on the re-test for the one rear wheel not doing much braking force still (it previously failed for this which I found to be a seized wheel cylinder). Plus a seatbelt buckle not working.
So between the initial fail and now I bought a new cylinder online (which subsequently had a ripped boot so I had a full refund, and then just installed one of the old dust boots from the old cylinder which was still nice). I had to make up a new flexi>cylinder line as typically the one I had twisted initially removing the line fitting to the cylinder (I had already cut it down a few years back so there was no slack to recover it) - and I did my best to bleed the brakes on my own and reset the handbrake etc. I was pretty sure I had all the air out and the brakes were acting as they should be so it was a bit of a suprise when he said it failed again on the same thing.
But when he put the car back on the rolling road to show me, both rear brakes were working fine, and actually fairly well balanced between eachother too. I suppose the shoes might have needed to be bed in more centrally to the drum or something, maybe. It felt fine to me on my quick drive around the block before the re-test and it seemed to brake straight as far as I could tell. I'll have to keep my eye on it though. Diagonal braking, so it's possible that only one diagonally braking corner of the car would ever really actuate if you didn't need to press the brake harshly, possibly the cause for the cylinder seizing in the first place, it's the last brake to be applied. Ah well.
Yes I did fix the seatbelt buckle too, but he took my word for it that I did so.
Yet another messy pass, in the end... Similar to last year, when the fog lamp wouldn't light, but he let me tap the lens, and then it did. Rolling Eyes
It's been on stands since May as I removed and rebuilt the gearbox, but It stinks of mould- I need to strip it internall fully to find where the hell the puddles of water are coming from. One at least seems to be coming from the dome light- which is also the cover for the aerial so that's quite an obvious fix.
virus
PostPosted: 19:52 - 27 Feb 2025    Post subject: Reply with quote
this new 3d printer I bought myself is the tits, with just 10 mins in fusion ive designed and printed some custom little clamps and sent them to the printer, total cost 9p each.
The problem they solve has been bugging me since I built the bike 7 years ago.
own: 81 xs1100g...
Easy-X
PostPosted: 14:37 - 06 Mar 2025    Post subject: Reply with quote
Having a bit of a clear out, found a Frank Thomas jacket I'd worn for barely one season. Flogged on Facebook marketplace and surprisingly it wasn't the Deliveroo crowd that picked it up Smile
A100man
PostPosted: 15:43 - 06 Mar 2025    Post subject: Reply with quote
Total cost? How much was the printer?? Wink
PostPosted: 19:37 - 06 Mar 2025    Post subject: Reply with quote
One of the local small businesses has a publically accessable scrap metal skip which I have standing permission from the owner to have a rake in.
Small honda 4t static engine in it today. Probably off a genny or pump. Pull cord intact, turns over, has compression, no wobble on the main bearings. I can also see someone has had the carb off and tried to refit it with the wrong gasket. None of the engine shrouding looks like it's ever been removed and it's clean as a whistle so I have every confidence it's going to be a runner once I find whatever carb or electrical issue it has.
It's now in my shed for a rainy day project. No idea what I'll use it for if I get it running but it was free and it'll beat the shit out of doing a jigsaw.
A100man
PostPosted: 10:50 - 07 Mar 2025    Post subject: Reply with quote
.. Thumbs Up and as I tell other folk - much cheaper than playing golf - and far less pointless.
virus
PostPosted: 17:21 - 07 Mar 2025    Post subject: Reply with quote
why do you have to go spoil it for me by reminding me about that? Laughing
tbf it was one of the cheaper hobbies to get into considering the options, and its more useful than a coke habit Laughing
own: 81 xs1100g...
hellkat
PostPosted: 19:59 - 07 Mar 2025    Post subject: Reply with quote
Chocolate fudge edibles.
Wub
What me worry?
hellkat
PostPosted: 20:15 - 07 Mar 2025    Post subject: Reply with quote
This military gallivanting about I've started doing lately.
I feel it may get me into Wub some trouble Wub at some point.
They're a bad influence all round, and I forget that I can't drink anybody under the table, let alone that sort of career-level boozers.
I lost my virginity on a Naval base, you know.
I feel an ill wind blowing in my future Mr. Green
A100man
PostPosted: 20:23 - 07 Mar 2025    Post subject: Reply with quote
I do sometimes think that BCF was set-up simply to be your confessional, really I do.. Wink
hellkat
PostPosted: 20:26 - 07 Mar 2025    Post subject: Reply with quote
It does seem rather to have become that way.
I shall become a withdrawn little wallflower instead.
(actually I feel like I already am, poor old dear that I am).
*mwah*
CrypticCrud
PostPosted: 10:27 - 08 Mar 2025    Post subject: Reply with quote
Talentless tone deaf noise polluter Lily Allen slagging off her ex(s) because they didn't give her enough in the bedroom.
I swear some people are stuck on this planet solely to steal oxygen from the more deserving.
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
to v or not to v
PostPosted: 10:10 - 09 Mar 2025    Post subject: Reply with quote
watching a blackbird build a nest in the back garden.
Moto Guzzi V7.
CrypticCrud
PostPosted: 23:27 - 09 Mar 2025    Post subject: Reply with quote
Paying £11 for burger, chips & a mug of tea at Squires Cafe.
blurredman
PostPosted: 11:36 - 14 Mar 2025    Post subject: Reply with quote
Maybe she was that unresponsive and rigid, it was difficult to get beyond a softy.
hellkat
PostPosted: 17:01 - 14 Mar 2025    Post subject: Reply with quote
I was nice to some minions and they said Thank you for beating us, and tugged their forelocks.
So that was nice.
Shifty
Easy-X
PostPosted: 17:22 - 14 Mar 2025    Post subject: Reply with quote
So that was nice.
Shifty
Getting shouty at work?
hellkat
PostPosted: 17:24 - 14 Mar 2025    Post subject: Reply with quote
Not at all.
I *may* have employed some muscle and dropped a name or two.
In fact I was very polite indeed.
Shifty
PostPosted: 17:38 - 14 Mar 2025    Post subject: Reply with quote
Spanking in the work place. Naughty naughty Miss HK. Laughing
Triumph Trophy Launch Edition
Easy-X
PostPosted: 12:42 - 18 Mar 2025    Post subject: Reply with quote
The neighbours have a skip in their front garden and they've said we can throw any odds and sods in if we like, which is nice. Their side alley is piled high with all sorts of junk.
"Everything but the kitchen sink..."
So far they've found two Laughing
hellkat
PostPosted: 23:58 - 18 Mar 2025    Post subject: Reply with quote
Apparently ...
(my boss told the Chief Exec, who had popped his head around the door during our weekly 1-2-1 meeting)
... I am doing an audit for them. Can't remember what of, but it sounded terribly posh.
"An audit" ... get a load of me.
Rolling Eyes
Shocked
Mr. Green
I thought I was just putting together a spreadsheet and collating evidence.
I also actually had no idea what I was doing but in fact, apparently I've been doing it quite well.
Who'd a thunk it ...
If only I could work out how to write it on my CV without sounding like a complete twonk.
Corporate speak. Brick Wall
Its a good thing *they* understand what they are talking about, cos I fuckin don't.
hellkat
PostPosted: 00:02 - 19 Mar 2025    Post subject: Reply with quote
Is it skip season?
Even our street has two skips on it and the whole street is only about fifty yards long Laughing
This is one of the shittiest areas left in London, and skips are even starting to regularly appear hereabouts.
In other news, some cunt left a baby carrier carseat-y thing on the rubbish bins outside my house. No baby, just the carrier.
WTF. Shocked
Fly-tipping is reaching epic proportions in this manor Brick Wall
BanditsHigh
Worse than a woman
PostPosted: 09:43 - 19 Mar 2025    Post subject: Reply with quote
Lifted some more of my pension and they didn't take any tax ... give it a month or so and they be sending me a bill, but I would rather have that than a 6-8 month wait for a refund (like last time).
The last post was made 1 year, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Page 112 of 125
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 135.38 Kb
