Bike Chat Forums Index -> Random Banter Goto page Previous  1, 2, 3 ... 474, 475, 476 ... 497, 498, 499  Next
Islander
PostPosted: 17:42 - 23 Feb 2025    Post subject: Reply with quote
Easy-X wrote:
Islander wrote:
A geiger counter sensitive to alpha, beta, gamma and x-rays.
A chunk of Uraninite as a test source. I'm also going to be dismantling a smoke detector for the americium source. I may also have ordered an antique officer's WW2 marching compass of of eBay. Guess why... Laughing
No idea why I bought a Geiger counter but I was very disappointed it didn't go berserk with the lump of granite my dad gave me when I left home. Still, I have been toting it around for ~35 years, I expect all the Radon's gone by now.
Gonna try the smoke detectors though Thumbs Up
Check to see whether it's sensitive to alpha radiation before you do. A lot of Geiger counters aren't.
A bit of advice and I apologise if I'm preaching to the choir here. You'll either have to unsolder the module or the screening can to expose the actual source otherwise you won't pick anything up at all. Alpha particles are helium nuclei and are stopped easily (sheet of paper, human skin, more than about 5cm distance...) and as such don't present much of a threat as long as you don't go digging around in the holder to get the material out (Seriously, don't do that). Use forceps to handle the button if you remove it and wear gloves. Put the screen back on or put it in a tin when you're done and you'll be fine.
I got about 30,000 counts per minute from mine Smile
blurredman
PostPosted: 18:11 - 23 Feb 2025    Post subject: Reply with quote
Wheel slave cylinder for the car. Unfortunately dust seal has a split in it. I've message e-Bay vendor, but has yet to get back to me. I have MOT re-test relatively soon so if time becomes too close i'll have to just use seal from the old cylinder. I'll give him a bit of time, after all I need to put a new section of line to the flexi after the fixing to the cylinder rounded, and then the line twisted when I did get it free.
I was considering just re-building or freeing up old cylinder anyway but the bore is just far too rusty and beyond use.
mentalboy
PostPosted: 00:26 - 24 Feb 2025    Post subject: Reply with quote
Are we guessing why you are collecting radioactive materials or why you'd be buying a compass that is most likely lathered with radium so that it can be used in the dark?
There was an interesting programme on the telly a while back, about the women that worked in the factories during the war, one of the things covered was about those that painted the radium on compasses and watch dials.
Make mine a Corona.
Islander
PostPosted: 13:04 - 24 Feb 2025    Post subject: Reply with quote
That's the reason. I wanted a gamma (and beta) source as well. The radium paint is behind glass but you can bet I'll be very careful with the compass. I suspect it'll be pretty lively and it'll be stored out of the house that's for certain. I may even make a lead box for it.
The sheer lack of understanding and the wilful exposure of the radium girls is horrendous. There was a landfill near Dalgety bay in Fife that eroded out a load of radium painted materials from WW2 aircraft onto the shoreline that's only just recently been properly cleaned up.
I'm planning to build a Wilson cloud chamber as well. That lets you see tracks of the different types of radiation as they pass through an isopropanol vapour. This is a lifelong interest of mine. I have a decent understanding of the processes and an even better understanding of the potential risks and safe handling.
The Geiger counter is going to be mostly used to test rocks and minerals throughout Scotland.
blurredman
PostPosted: 16:30 - 24 Feb 2025    Post subject: Reply with quote
Got full refund for wheel cylinder and a 'don't bother sending it back', so i'll just fit one of the old dust seal from old cylinder and then fit the thing on the axle. Happy days. Always worth complaining.
hellkat
PostPosted: 23:29 - 26 Feb 2025    Post subject: Reply with quote
An Uber home (£37)
Rolling Eyes
Wiped myself out getting to the monthly Exec Committee meeting by 9am without first having breakfast or even swilling down a coffee before I left the house.
Managed to blag an instant coffee before the meeting but followed that up 3 hrs later at lunchtime with two steak bakes which repeated on me all afternoon Rolling Eyes
So I had a little snooze for half an hour on the way home and managed to perk up a bit in the late afternoon/early evening to catch up on my emails before knocking off time.
panrider_uk
PostPosted: 23:49 - 26 Feb 2025    Post subject: Reply with quote
Some solar lights for a fence and a load of veggies for stir-fries
BanditsHigh
Worse than a woman
PostPosted: 10:28 - 27 Feb 2025    Post subject: Reply with quote
Bought some new parrot food for my African Grey, Holly Crackers ... 12.5kg for £35 delivered, so £2.80 per kg.
Pets At Home was charging around £50 for 10kg of their stuff so £5 per kg (which looks the exact same as the new stuff) ... they are now stocking the new stuff I've just bought, but for £40 so £3.20 per kg ... bye bye P.A.H.
Easy-X
PostPosted: 22:00 - 27 Feb 2025    Post subject: Reply with quote
A "proper" Raspberry Pico 2 W to replace the Chinese knock-off. The genuine WiFi is much easier to get on with and serving up basic web pages trivial.
I'd have to say the setup is well thought out. In "boot select" mode the Pico looks like a USB memory stick and you just drag and drop an operating system image file, it gobbles it up and reboots as a USB serial device ready for programming. MicroPython is the ez-mode and you can either send the code down the serial for interactive running or dump a "main.py" file on the Pico and it'll autorun on power up.
Fun as Picos and Arduinos are to tinker with it's all a bit futile without a genuine task. I therefore have an idea to leverage the Pico's USB host capability to turn a cheap PC numberpad along with a simple display and emulate an old-skool accounting calculator:
https://i.ebayimg.com/images/g/-2EAAOSw2Zhf3lI6/s-l400.jpg
CrypticCrud
PostPosted: 21:46 - 02 Mar 2025    Post subject: Reply with quote
£11.75 of Sausage rolls, doughnuts, coffee & a cup of tea.
Could only drink the tea as i'm on a diet.
CBT - Aug24, Theory - Jun25, Mod 1 - Jul25, Mod 2 - Sep25
Kawasaki Z125 > Honda Z125 > GSX-R600 Y
A100man
PostPosted: 18:24 - 03 Mar 2025    Post subject: Reply with quote
Come again? Eh?
Easy-X
PostPosted: 19:06 - 03 Mar 2025    Post subject: Reply with quote
A100man wrote:
Come again? Eh?
The plan is: USB keypad => Raspberry Pico => cheap display => (something, something) => custom desktop calculator.
The old calculators used to run bright vacuum florescent displays. The closest equivalent these days would be blue or white OLED screens. I haven't found an off-the-shelf wide display anything like the pictured Sharp has so I'm going to chain 3 or 4 small OLED displays together to get the same effect.
https://ae-pic-a1.aliexpress-media.com/kf/S2b1e561093be48b29772938dc54cd427g.jpg_220x220q75.jpg_.avif
They're 5 for £4.35 on AliExpress Smile
Basically following the same principle as faking Nixie Tubes:
https://hackaday.com/wp-content/uploads/2023/07/Fake-Nixie-bootup-Square.gif?w=300
A100man
PostPosted: 20:56 - 03 Mar 2025    Post subject: Reply with quote
Easy-X wrote:
A100man wrote:
Come again? Eh?
Thats an insane price for the displays, but even so a lot of bother when you can still buy a Sharp print calculator Thinking
Cheaper than fettling motorbikes I guess.
https://www.staples.co.uk/office-machines-electrical-products/calculators/printing-calculators/sharp-12-digit-digitron-display-2-colour-printing-calculator-el-2607v/
https://ik.imagekit.io/pimberly/595e406f0f15f30010780448/tr:w-406,h-406,cm-pad_resize/084717d5/62ced7db18240a13350001de/SH20049_01.jpg?product_name=Sharp-12-Digit-Digitron-Display-2-Colour-Printing-Calculator-EL-2607V.jpg
recman
PostPosted: 21:10 - 03 Mar 2025    Post subject: Reply with quote
Thinking
CrypticCrud
PostPosted: 22:31 - 03 Mar 2025    Post subject: Reply with quote
Thinking
I'm that kinda guy... think of everyone but myself!
panrider_uk
PostPosted: 23:56 - 04 Mar 2025    Post subject: Reply with quote
New torch
https://ledlenser.co.uk/cdn/shop/files/WEB_P7R_Signature_red_dot_2048x2048.jpg?v=1729671239
And a foot pump for the bike
https://media.autoexpress.co.uk/image/private/s--hhN6CPep--/f_auto,t_content-image-full-desktop@1/v1739375765/autoexpress/2025/02/Best%20car%20tyre%20foot%20pumps%20-%20Michelin.jpg
hellkat
PostPosted: 20:00 - 07 Mar 2025    Post subject: Reply with quote
Ten spicy wings Wub
recman
PostPosted: 10:02 - 08 Mar 2025    Post subject: Reply with quote
Just signed up for my separation/early retirement package from work.
One of the options included the very impressively discounted fleet vehicle purchase of the car I picked up on Tuesday.
Which was nice.
to v or not to v
PostPosted: 10:13 - 09 Mar 2025    Post subject: Reply with quote
i found those double barrelled foot pumps a bit tiring to use.
Moto Guzzi V7.
recman
PostPosted: 07:43 - 10 Mar 2025    Post subject: Reply with quote
to v or not to v wrote:
i found those double barrelled foot pumps a bit tyring to use.
FTFY.
PostPosted: 09:29 - 10 Mar 2025    Post subject: Reply with quote
I honestly cannot see a reason to buy a manual foot pump when you can buy a battery operated one as cheaply.
Triumph Trophy Launch Edition
BanditsHigh
Worse than a woman
PostPosted: 22:53 - 10 Mar 2025    Post subject: Reply with quote
Until they run out of battery and you don't have a spare to hand ... foot pump always works Thumbs Up
PostPosted: 22:59 - 10 Mar 2025    Post subject: Reply with quote
My air pump runs off the bike battery and is so small I don't notice it in my rucksack.
panrider_uk
PostPosted: 23:39 - 10 Mar 2025    Post subject: Reply with quote
For some reason I didn't even think about a battery one.
Besides, I need all the exercise I can get.
hellkat
PostPosted: 00:49 - 14 Mar 2025    Post subject: Reply with quote
A fried egg and bacon sarnie on white bread.
No sauce just slightly runny egg yolk so it goes nice and gooshy on the bacon.
I haven't had one for probably five years.
It were 'andsome. Wub
The last post was made 1 year, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Page 475 of 499
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 140.83 Kb
