rusty chain
flyingcbf
PostPosted: 22:54 - 03 Mar 2025    Post subject: rusty chain Reply with quote
Hi Folks,
So I've cleaned the chain and applied gear oil. But the chain still goes rusty! Sad
https://lh3.googleusercontent.com/pw/AP1GczOWeVl2gqgwlA7iDn71VkCTQtTP4ij0K22WKzepx8FBxpn6kRpqNhhugSqDG5ivwPpgBjbsnHh00d063N1VaMAsJPShf4AtFZeM-sU_IeUoNfGv3jaaK45PEiII5vjojnMdZzqpfMbIX_bwDIOXvgi5=w1159-h869-s-no-gm-no
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
struan80
PostPosted: 00:32 - 04 Mar 2025    Post subject: Reply with quote
You've not cleaned it well enough. What I do is not give a fuck about chain maintenance. Only £70 for a new chain every 2 years,
Also have a scotoiler that drips oil on my slabs.
jaffa90
PostPosted: 01:29 - 04 Mar 2025    Post subject: Reply with quote
Back in the 70s all year riding i used gear oil and painted grease on the side plates, you have an O-ring rubber sealed chain there so silicone lubricant really.
doggone
PostPosted: 08:51 - 04 Mar 2025    Post subject: Reply with quote
Road salt is getting at it and starting on your swinging arm welds too.
Not much you can do but clean and lube more often or avoid salty roads.
Trouble is the salt is sticky and needs serious rain to wash it away properly. Putting lube over salt already on there is not ideal.
flyingcbf
PostPosted: 09:29 - 04 Mar 2025    Post subject: Reply with quote
jaffa90 wrote:
painted grease on the side plates, ally.
Painting grease on the side plates? So grab a paint brush and dab on the side plates? Sounds good idea. I have loads of general purpose grease and Comma CV500G CV Lith-Moly Grease too.
Silicone grease a expensive Sad
A100man
PostPosted: 12:08 - 04 Mar 2025    Post subject: Reply with quote
Chainsaw oil is cheap and sticky.
flyingcbf
PostPosted: 12:54 - 04 Mar 2025    Post subject: Reply with quote
i have loads of grease so would like to use that up Smile
flyingcbf
PostPosted: 14:25 - 09 Mar 2025    Post subject: Reply with quote
So now it's been cleaned using wire brush and Paraffin. Then splashed it with water and dryed using cloth.
Waited an hour for normal drying and slapped some chain lube this time. Not gear oil as I had some lying around.
I then painted some General Purpose grease on the plates...
https://lh3.googleusercontent.com/pw/AP1GczNrVFlX_CRkJFqBuEC9OuPfdjce1mcGZHmW2o0b72tZtphejHvDuRb9uZee1xDkrU1Np_FMQkjvOQdgaboCy_PhNOQXISiRmP5Kvy0MlVFrtoc-VBAdIiYN1RvvYvoN29w3KTBp-11C-sVILuMcOSKE=w1159-h869-s-no-gm-no
jaffa90
PostPosted: 17:53 - 09 Mar 2025    Post subject: Reply with quote
Shocked, you only need a thin layer of grease on the plates because some of that will fling off.
The last post was made 1 year, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 59.45 Kb
