| WarrSquirrel |
 WarrSquirrel Derestricted Danger
| WarrSquirrel |
| VengefulRat |
 VengefulRat L Plate Warrior
| VengefulRat |
 Posted: 10:23 - 09 Mar 2025 Post subject: |
Alright, so still struggling. Since the water got into the carbs, issues issues. So i took the carbs off and cleaned the bowls. Great, the bike would ride. But then suddenly had the issue of on idle, when you give throttle, it will dip and lurge for a second and then go. Also, doesn't want to idle higher than 1000 rpm. If you set the idle screw higher, the revs drop slowly. Anything from about 3k it will slowly drop down back to 1000rpm.
I don't know what I messed up but I can't figure it out. I did adjust the pilot screws at first, hoping that might be the issue but didn't make a difference. So I set them back to what they had been, which was factory standard, and that didn't make a difference. I did a bench sync, as what I did before, still doesn't make a difference. The bench sync is as close as I can get it with the eye, which is almost exactly as I had it before. So it should be running well, but it's not.
Everything else is exactly as it should be. Fuel tap is open, lines go into the correct spots. Once you go, the bike goes, no worries there. It's the bottom rpm that's messed up.
Also checked the floats, they're sitting at the factory suggested 17mm. Sounds super high and I get a lot of pops and bangs when letting off the throttle but that's what the factory suggested.
Any help? I'm at a loss now. |
| WarrSquirrel |
The last post was made 1 year, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
