| struan80 |
 struan80 World Chat Champion
| Kawasaki Jimbo |
 Posted: 23:12 - 10 Mar 2025 Post subject: |
It should only be dropping out when the engine is running. If it's dripping when parked, you either have the flow rate way too high so residual oil is dripping off the chain or there's something wrong.
From experience you usually set flow rate so you're only just getting a bit of oil on the wheel. The manufacturer suggest 2 drops per minute as a good starting flow rate. A drop is roughly 0.05ml so at 1ml/min you have 10X the recommended flow rate. This is probably the problem.
If it's dripping when the engine is off, it's probably one of very few things.
The oiler itself is very simple, it has a needle valve in the oil reservoir, normally held shut by a spring which stops oil running out. The needle valve is attached to a diaphragm. When the engine is running, vacuum from the carb sucks the diaphragm open which in turn opens the valve. Oil can then run down the tube to the chain. The turning of the top of the oiler sets how far it opens. That's it.
If oil is running out with the bike stationary:
The needle valve could be being held open, possibly by a bit of dirt.
The valve isn't springing fully closed.
There is an air leak somewhere in the delivery tube allowing the oil that's in there to continue running out when the valve at the top is closed. It should be reasonably obvious where because the delivery tube would be empty from the leak down after it's been sitting for a while. It would ordinarily remain full of oil.
There's an air bubble in the delivery tube, it needs to be primed so it's totally full of oil.
The delivery tube is running too near something hot which is causing the oil to expand and run out of the end when parked. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ZebraDriver |
 ZebraDriver Scooby Slapper
| struan80 |
| Kawasaki Jimbo |
| Polarbear |
 Polarbear Super Spammer
The last post was made 1 year, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
