| stinkwheel |
 Posted: 23:13 - 29 Apr 2025 Post subject: Anyone know about checking spigot to head clearances? |
It's on my fairly highly tuned 612 enfield bullet. I'm getting oil blowpast round the head gasket which I think is either because pressure is escaping an excessively wide spigot gap OR the spigot is to high and the head gasket isn't being compressed enough.
I'm pretty sure it's the former because there is no pressurised oil passing through the head gasket, only the return from the rocker box (which has an atmospheric breather fitted) or anything which has made its way up the studs from the bottom end (which has a negative pressure breather). The high pressure oil feed to the top-end is external. In either case, there's no pressurised oil there so I can't see how it would be blowing out unless assisted by cylinder pressure.
I'm running a modern cometic composite head gasket with a fire ring.
There's very little out there on how to measure it, I'm thinking pop the head off, plastiguage the top of the spigot and re-torque. Then the question is what gap to shoot for? In an ideal world it would be zero but if it is, how do you check the head gasket is sufficiently compressed. If there is a gap, what gap is acceptable or do you skim it for zero?
The head can be skimmed to close the gap and the spigot can be skimmed to widen it.
Or am I barking up the wrong tree and there's an easier way to do this? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| stinkwheel |
| virus |
 virus World Chat Champion
 Posted: 19:47 - 30 Apr 2025 Post subject: |
I think your about right in your plan there. Id be looking at going down the same path, possibly using spacers to vary head gasket thickness to suit if its not holding back compression, on account of it being easier to throw another spacer in than do the afformentioned machining.
What I would suggest is deffo try and get the plastigauge measurement with it hot / as close to running temp as possible, test with spacers til you get the 'right' measurement then machine to suit. For something like that i'd aim for a 0-0.1mm clearance at operating temperature.
The other option ofcourse if the spigot deals with all the combustion and the head gasket is just for oilways, is to machine a small countersink into the top of the barrel and fit an O ring for the oil ways and do away with the head gasket entirely. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| stinkwheel |
| Pete. |
 Pete. Super Spammer
 Posted: 20:43 - 30 Apr 2025 Post subject: |
Is this a viton coated MLs gasket or a more traditional type? The MLS gaskets won't have any discernable amount of compression IMO. If truly the spigot seals on the head with no gasket then IHow else ar you going say it will have to do that at the exact same time that the gasket is clamped up solid. This is the only way that you can be sure that the top face of the spigot is fully seated with the recess face in the head. With the four bolts outside the sealing ring it would be all too easy to pull it down cocked otherwise.
I think I would build it up dry with no gasket and clay/plastigauge the gap under the head where the gasket would be. If the clay mic's out the same thickness as the gasket then you wil be pretty sure. If the clay is thicker then it's riding on the spigot. If the clay is thinner then it's riding on the gasket.
Another method is if you could find an old very large micrometer you could turn a plug for the bottom of the cylinder and mic the distance to the spark plug land with the gasket fitted and not fitted. if the distance is appreciably less with the gasket fitted then it's not sealing on the spigot.
If you were nearby to me I would fit them up in my lathe and measure the distances with the DRO and a dial gauge. ____________________ a.k.a 'Geri'
| virus |
 Posted: 21:28 - 30 Apr 2025 Post subject: |
| stinkwheel wrote: |
If it wasn't for the oilways, I'd just lap the head against the spigot like you do with aircooled 2-strokes. It may not be a daft idea to do this anyway. Certainly would be the way forwards if the spigot gap is too small (which I doubt). If nothing else, lapping it with some sharpie on the head recess to check it's all paralell and flat would be a good move.
I feel my weekend is going to involve a workout for all my precision measuring stuff |
Oh god yeah, make sure the faces are running paralell to each other for sure otherwise its all a bit of a wasted effort. I imagine they probably arent 0.005 deg flat from stock mind  ____________________ own: 81 xs1100g...
| stinkwheel |
| sickpup |
 sickpup Old Timer
| jeffyjeff |
 jeffyjeff World Chat Champion
| virus |
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 14:49 - 02 May 2025 Post subject: |
The amount of oil is what I'd call excessive, it's landing up on the front of the rear mudguard. I though it might have been pressurising the rocker area and forcing oil out past the gasket that way (there isn't much of a gap as you can see on the head gasket)but it now has a breather there so it can't be pressurised.
I do know if the spigot clearance is excessive, it can lead to errosion of the cylinder head over time.
I'm going to measure up this weekend and I'm just off out to go see an old school mechanic i knowa dn ask him about it. He'd be doing any machining/skimming if it's anything beyond what can be achieved with glass and emery paper/grinding paste. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 09:23 - 03 May 2025 Post subject: |
It's a pretty small amount given how much it breathes and burns through the unsealed valve guides so oil consumption is what I'd call acceptable. It is however making a real mess of the bike which then gets all over both me and my clothing and luggage.
Happily it's an overhead valve engine, the cams are splash lubricated in the bottom end and the valve rockers are seperate units which bolt to the head and are directly lubricated via an external oilway. As such, any head work I do will only affect compression and valve to piston clearance. The former can be bealt with by setting deck height and the latter you cold drive a bus through (but will be checked anyway).
I have another bullet which does weep a little oil round the edge of the head gasket but it's nothing to write home about. Certainly not enough to get on the back mudguard and luggage which this one does after a few hundred miles. Admittedly the other one is running at much lower compression but is also used for trials so it gets really hot. Both are using the same head gasket. It might be the spigot clearance is bang-on but I do want to check it.
I'd post a photo of just how much oil is flying about but I pressure washed it yesterday in anticipation of todays tear-down.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| virus |
| stinkwheel |
 Posted: 12:33 - 03 May 2025 Post subject: |
Well, initial teardown is informative.
Looks like the fire ring is pretty much holding. Also clear that oil can passively get up/down the studs into the vicinity of the head gasket but isn't blowing through in a massive way. Piston colour looks good, maybe slightly the lean side of perfect but no hotspots and no evidence of burning significant amounts of oil.
There is quite a bit of carbon on the face of the spigot suggesting clearance may indeed be too large. At the 2 o clock position on the spigot on the picture below (front left of the engine), there's an area of more completely burned carbon which might suggest an area where hot exhaust gas blowthrough is breaching the spigot. This, combined with oil going down the studs might explain oil blowing out of the left side of the head gasket.
https://lh3.googleusercontent.com/pw/AP1GczN1Rx1774Usz8-6o57fbcKncDojnVQxX6g02t4iLDdeenJgxcTpidYcIFKEZgWY53FfpncBB1UjjVW3XeswwzEKG3Tp7PpHH81J2nGMwSZseXx6Wl_IWZ_An72_USZh4PvgEttUSpazzDjD4rCZTkAP=w1557-h876-s-no
You can see the corresponding area on the head (again, about 2 o clock on the picture below) and a fair bit of carbon on the spigot area. You can also see more brown swirl marks where the hot combustion gasses have been running and burning off the carbon on the head. To me this indicates my plan to double plug this head is probably a good idea. maybe get a more even burn.
https://lh3.googleusercontent.com/pw/AP1GczM7b6K59CSElFnknUV22uD_fUmAfu2uZCualLhJa2sW1_vIIddABAyG-jXot7ibxqZUnLOU7DEGk53exyKg12P9Nk26RgR1m93CQVd6UbuM8CMzpVRAl0XsGpPwMAFGZ8JJyPJh1IzhoVQTJtccpjBB=w1557-h876-s-no
Swirl marks highlighted:
https://lh3.googleusercontent.com/pw/AP1GczN0skocxAr3iOh8mEmxC6bXR-i2t2VtZ_M3KIvwqYcjj2RUbtoo69HLq9Re-C4YtmHnMDspWcNoTEM76mbp-WlzxBdDd0MZnWliAJ10ShUdPOjUecHTTEygIxHmv_RedNAmvxxFXSVPkDf93lt67aEm=w1557-h876-s-no
Other things of note are that my breather system seems to be working well, there's distinct resistance to turning the piston up and you can hear air being slowly sucked in through the breather hose/valve as it approaches TDC, then a nice blowoff of air as the piston goes down. It's to the point it's noticeably sucking the piston back down as you turn the engine up towards TDC.
I'm going to pop out now to see if I can speak to an old school mechanic I know about what to do next. Then my afternoon will contain a lot of carbon scraping in preparation for measuring that spigot clearance. All looking like it'll need a little bit off the head gasket face, the question is how much. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
 Posted: 17:39 - 03 May 2025 Post subject: |
Well, spigot gap is relatively huge. By bolting down onto the old gasket, it didn't register on the plastigauge. I got a really good measurement with lead solder though.
The gap is 1.457mm measured over 6 points with a maximum deviation of 0.032mm. (with a micrometer). At least it's relatively level and concentric.
My engineer friend couldn''t come up with a definative measurement to aim for either but we both agree this is far too big. "on the plastiguage" is going to be a working minimum but shooting for 0.1 - 0.2mm range is going to leave enough slop for the head gasket to fully compress.
Options are a thinner gasket or skim some off the head. Off to measure the gasket thickness and gasket surface clearance with the head bolted to the spigot. Perhaps aim for zero then lap the head onto the spigot a bit to produce a tiny but consistant gap. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 20:01 - 03 May 2025 Post subject: |
Easier to turn the top of the barrel casting than skim the underside of the head IMO, and you won't rik thinning the bottom fins. I'd definielty lap that head flat though. ____________________ a.k.a 'Geri'
| virus |
| stinkwheel |
 Posted: 22:07 - 03 May 2025 Post subject: |
Done more measuring. The head to barrel clearance with the spigot fully seated is 0.307mm mean over 6 points with a maximum 0.375mm and minimum 0.265mm.
Once again, the lead solder did a very neat job for measuring this.
The current composite gasket is 1.1mm compressed.
If i fit an 0.5mm copper gasket (which are available), this will take the spigot clearance to 0.25mm.
Using my calculations from when I built the engine, that would give a compression ratio of nearly bang-on 9:1 which I think is the working maximum for these engines on pump fuel. Twin plugging it will probably help a cleaner burn (and replacing the decompressor valve with a plug will marginally drop the cylinder head volume).
I could also lap the spigot true (although it seems pretty damned close from the previous measurements, wont need to take much off if at all, I'l sharpie it up tomorrow and see how it's looking contact-wise). Then take 0.1mm or a touch more off the head here using the old fashioned sheet of glass method to take the spigot closer and throw an extra base gasket in to keep the CR sane. Should be golden.
Then re-assemble and take it apart a couple more times to check everything is how I expect it to be.
Seems to have been a lot of faff, buit that spigot clearance was way too big. On cleaning up the head, I can see nibbling round the edge of the head on the edge of the spigot recess. This is probably where gas has been coming round the spigot and hitting the fire-ring.
https://lh3.googleusercontent.com/pw/AP1GczNu_heMiQe76GCbGK3kJTuS6gMBMKNjZPxxtZPGkTWaRyAmCch6unI8Zoc-cN8rvj0CjSIhekUOWKs55aFvFbjPV9_C9vCR74gDr6EL6Jzp6qEbbOmdp9oMeSBgRV8xmCd4r-J6ztILNZDIWpjv582K=w1557-h876-s-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
| Pete. |
 Pete. Super Spammer
 Posted: 09:40 - 04 May 2025 Post subject: |
That nibbling is indicative of detonation damage.
I think that closing that gap to the barest minimum is the way to go. This is pure conjecture but if the spigot OD is a tight fit in the head recess then that might be constraining the fuel air mixture in that tiny gap so much that if/when it ignites the pressures in that gap might be sky high, certainly enough to promote detonation. Could even be these pressures that are blasting the oil out past the gasket.
if there's no gap, no fuel/air, no bang. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 11:04 - 04 May 2025 Post subject: |
| Pete. wrote: |
if there's no gap, no fuel/air, no bang. |
Yes, not good, but I think I've caught it in time. It must have been doing very odd things.
I found an old copper head gasket in good condition (I don't throw useable stuff out, score 1 for hoarding). On re-measuring using that gasket, it's taken the spigot gap down to 0.65mm. Take that much off the head then adjust deck height for compression and i should be golden. It will also remove the worst of that pitting.
Means fucking on with gasket sealants for the copper gasket (which has bitten me before, wellseals claim to never set are vastly exaggerated) but I've fitted removable barrel studs to this bike so if it glues the head to the barrel, I can still get it apart and free the head off on the bench.
Off to find a sheet of glass now. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stinkwheel |
 Posted: 00:35 - 11 May 2025 Post subject: |
Well, that escalated quickly. Having skimmed a bit off the head, I took the barrel off to adjust the deck height.
Umm, yeah, I'm pretty sure that's not supposed to be like that:
https://lh3.googleusercontent.com/pw/AP1GczOT-JG_jEA8xNF7YykiTrPg83uSl7WN55uinWu4alyFFSFp71rPUlBWYKfmphgyhi3MEluz6h9z29NUaM6y-lD2z6dlqi2qXpUxz5XepqWeaXm0yx3riHpbvOt3ExiCKpMswXh-Eys-gMgK62yw5Tq-=w1557-h876-s-no
I hate doing jigsaws but needs must...
I'm pretty sure this happened quite some time ago. I had an incident where the engine got absolutely smoking hot and it turned out the decompressor cable was trapped under the tank making it run lean as hell.
That's the top ring. Amazingly, it seems the second ring was holding compression, absolutely no blowpast below it. Piston is in good order after a clean (thankfully, they are stupidly expensive forged omega pistons). Even a set of rings for it was £47.
Bike was running fine before disassembly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 1 year, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
