2025 MT-07 Torque setting
MilleD
PostPosted: 12:15 - 12 May 2025    Post subject: 2025 MT-07 Torque setting Reply with quote
Hi,
I'm looking at installing some frame sliders/bungs on my 2025 MT-07.
Does anyone know the torque setting for this? The instructions on the part says to tighten to that shown in the manual, but I can't see it mentioned in there.
Thanks in advance.
Claire
Zen Dog
PostPosted: 12:32 - 12 May 2025    Post subject: Reply with quote
The bungs are probably going to be attached using (or replacing) some existing bolt (probably on the frame), so it's the torque setting for that bolt you need.
If that existing bolt is for something relatively unimportant (fairing mounting, radiator etc.) then a general torque setting for the size of bolt will probably do. But if it's reusing an engine mounting bolt, yeah you really need the exact torque setting. If you have a picture of the bolt on the bike you're going to be mounting them on, or a link to the instructions, it'll probably help people advise you better.
MilleD
PostPosted: 13:32 - 12 May 2025    Post subject: Reply with quote
Hi, thanks for your reply - it's the frame mount bolts so I think pretty important.
The instructions are on this link and it mentions the torque, I just can't see the amount listed anywhere in the owner's manual.
https://evotech-performance.com/collections/yamaha-mt-07-2025/products/evotech-crash-bobbins-yamaha-mt-07-2025
Zen Dog
PostPosted: 13:39 - 12 May 2025    Post subject: Reply with quote
It won't be in the owners manual, you'd probably need the factory service manual. If you can't get hold of a copy of one of those, and since Haynes manuals aren't a thing anymore for newer bikes, your easiest route is probably to go and see your Yamaha dealer, and see if you can speak to a friendly mechanic and ask them (they'll have access to the service manual).
rpsmith79
PostPosted: 13:40 - 12 May 2025    Post subject: Reply with quote
It won't be in the owners manual, it will be in any maintainance manual (Haynes or similar) that is available
Owners manuals these days only tell you not to drink the battery acid, not how to service/maintain your vehicles
A google/Facebook search would be your friend
MilleD
PostPosted: 16:36 - 12 May 2025    Post subject: Reply with quote
Cheers, I've emailed them but not getting anywhere yet. Will have to give them a ring.
MilleD
PostPosted: 16:37 - 12 May 2025    Post subject: Reply with quote
You're not wrong. Don't do this, don't do that, but no actual help for things you need to do...
MilleD
PostPosted: 17:06 - 12 May 2025    Post subject: Reply with quote
I've found a workshop manual and I'm really none the wiser.
A search seems to say it could be 55nm. Which there is that on the engine mounting diagram, but.....there's also other ones.
Who knew this basic bloody thing would be so difficult Brick Wall
rpsmith79
PostPosted: 08:02 - 13 May 2025    Post subject: Reply with quote
Probably best to get onto an MT-07 Facebook group, i'm sure there will be plenty
You should get an answer in minutes
MilleD
PostPosted: 09:09 - 13 May 2025    Post subject: Reply with quote
Thanks Smile
I think I've figured it out. Think it's 75nm. Torque wrench ordered Very Happy
What's the worst that can happen?? Laughing
to v or not to v
PostPosted: 09:17 - 13 May 2025    Post subject: Reply with quote
have you tried asking the maker of the crash protectors?
Moto Guzzi V7.
PostPosted: 09:26 - 13 May 2025    Post subject: Reply with quote
https://docs.google.com/spreadsheets/d/1EtiFMQItNgPWe6ZUkuZf0Fna-aiwJnq9gn9NqTxkAg0/edit?usp=sharing
There's not going to be any difference between the MT and the FZ.
MilleD
PostPosted: 09:29 - 13 May 2025    Post subject: Reply with quote
They just say "as per manufacturers instructions".
Helpful Very Happy
MilleD
If that's the case, that seems to tie up with the 75nm.
Thanks for that.
The last post was made 1 year, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.3 - MySQL Queries: 13 - Page Size: 81.77 Kb
