1990 ZZR600 fork cap removal
Diddums
PostPosted: 17:12 - 09 Aug 2025    Post subject: 1990 ZZR600 fork cap removal Reply with quote
Hello! I'm about to lose my mind over these caps. I'm trying to replace the fork seals and dust seals on my 1990 ZZR600, and I'm coming up against these caps which I don't seem to be able to remove:
https://i.imgur.com/T4rNGlZ.jpeg
Anyone got any ideas?
Cheers![/img]
Diddums
PostPosted: 19:01 - 09 Aug 2025    Post subject: Reply with quote
Screw it, despite doing everything myself on the bike, this is where I have to draw the line. I'm gonna end up injuring myself if I carry on with these forks, they're going to a mechanic on Monday who will do them for me.
A100man
PostPosted: 19:14 - 09 Aug 2025    Post subject: Reply with quote
Yeah you need a (soft jaw) vice and a hammer/drift if they're stuck - squirting some plus gas might help. Once they are moving you can hold it down and remove the circlip. might be easier with a mate to help - wear eye protection
Raffles
PostPosted: 06:13 - 10 Aug 2025    Post subject: Reply with quote
If you don't have a suitable vice available you could always re-install the fork legs back into the yokes and clamp 'em up. That way you will have both hands free to work on the fun bit.
Once you've got the top plug moving (see post above) simply depress it and apply DOWNWARD pressure on the retaining ring at either of it's ends and out it will pop.
PostPosted: 11:35 - 13 Aug 2025    Post subject: Reply with quote
Put it back in the yokes then you can hook the legs of a 2 or 3 leg puller under the top yoke and the screw will fit nicely into that dimple. You can then relieve the spring tension and fish out the circlip that holds it in place and (importantly) let the tension off slowly so the cap doesn't fly in the air then land on your tank, chipping the paint. Although best to put a rag on the tank anyway.
I've also done it using a t-bar on a socket extension, a 2-man job, one pushes down on the T-bar, the other fishes out the circlip.
Diddums
PostPosted: 12:32 - 19 Sep 2025    Post subject: Reply with quote
Cheers for the responses all. I took the forks to a workshop who did it for me at a very reasonable price
(shoutout to N-Dec motorcycles, if anyone's in Surrey and needs work done, I can't speak highly enough of these guys - https://n-dec-motorcycles.ueniweb.com/?utm_campaign=gmb)
The last post was made 1 year, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 47.87 Kb
