| Farmingstock |
 Farmingstock Spanner Monkey
| A100man |
 A100man World Chat Champion
 Posted: 22:49 - 02 Jul 2025 Post subject: |
compression check? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Farmingstock |
| sickpup |
 sickpup Old Timer
| Farmingstock |
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 10:15 - 09 Jul 2025 Post subject: |
it does sound like you need to investigate "changed the choke to manual" a bit more.
there is nothing that changes the starting procedure between hot and cold, besides the choke. Going over what you said, power is fine, hot starting is fine..restarting is fine.
so check out choke a bit. If you changed it to manual was it because you had good information that the automatic choke wasnt working? etc etc...go over that part of your thinking and redo if you find error in the logic. You perhaps have more info now, than when you did this specific mod that may contradict an earlier finding.
as a far flung "hey but what if it isnt the choke coz Ive checked it 100 times" then assuming all else what you said is true there is nothing else to check. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| Ayrton |
 Ayrton World Chat Champion
 Posted: 10:50 - 09 Jul 2025 Post subject: |
Sounds daft but have you checked the air filter? I spent ages trying to figure out why my scooter wouldn't start and a new filter fixed it The old one just became too blocked up even though it didn't look too bad. |
| Farmingstock |
| sickpup |
 sickpup Old Timer
| Farmingstock |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Farmingstock |
 Posted: 21:46 - 07 Aug 2025 Post subject: |
| jeffyjeff wrote: | | Farmingstock wrote: | Bought a new autochoke, however the problem is still there! Auto Choke works as it should!
Think the issue is fuel delivery to the carb, if I blow into the tank or cover the air filter side of the carb while turning it over so more fuel gets sucked in the bike starts fine! |
Why do you say that the auto choke works as it should? What you are saying here defies logic. 1. An operational choke will restrict airflow into the venturi throat of the carburetor. Placing your hand over the intake will do nothing, since airflow is already restricted by the choke. Rather than a choke plate, your carburetor probably uses an enrichment valve (most bike carburetors do). Even with a new valve, a blockage in one of the carburetor passages could render the enrichment valve ineffective. 2. Blowing into the tank to aid starting makes no sense. The carburetor float and needle valve will seal the fuel inlet to maintain the prescribed fuel level in the carburetor float bowl. You could blow into the tank until you are blue in the face and still not force a drop of fuel into the carb.
Carburetor disassembly and cleaning is apparently in order. |
So the autochoke works by lengthening to close and shortening to open, without trying to sound condescending, I have checked this works! I know the autochoke works!
The bike uses a vacuum pump to pump fuel, this is fed by suction on the inlet, when I cover the carb air filter side with my hand it sucks more and lets fuel into the carb! By a process of elimination, my guess is the tank vacuum pump is faulty! Again I know the carb is clean, the autochoke works and the bike starts ok when I know it’s getting fuel to it from the tank with the hand over and more vacuum trick! So my next step to prove my theory as I know the carb is clean and the autochoke works! Is to use a temp tank gravity fed and see if it starts ok, if it does then the problem is 100% the vacuum pump! |
| jeffyjeff |
| Farmingstock |
| that_impulse_guy |
 Posted: 10:12 - 08 Aug 2025 Post subject: |
i admire whats going on, but when you consider the original post says the bike starts fine when its hot then you're left wondering if a vacuum fuel tap not getting vacuum can actually be the problem. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
| bugeye_bob |
 bugeye_bob World Chat Champion
| Farmingstock |
 Posted: 18:05 - 08 Aug 2025 Post subject: |
I have tried fuel directly to the carb and its still no better!
When I said in the first post it starts fine when warm, I should have been more specific:
When the bike has been left for any period of time over 30 minutes or so, it will turnover for 20 seconds and not start, with no matter what I do with the throttle on/off/ then all of a sudden it will start after turning it over and over, then once started, I can turn it off instantly (not warm) and it will start fine over and over again until left for a while!
However!
If I take the air filter intake off cover the carb with my fingers and turn it over (fingers wet with fuel) it will start better!
It won’t start with kick start at all until it’s been started with electric start, then it’ll kickstart everytime!
I have checked the autochoke, tried a manual choke, sprayed carb clean around the carb to check for air leaks, checked the vacuum and fuel pipe for leaks, checked the valve clearance, replaced the spark plug and air filter!
Once the bike starts it rides absolutely fine.
Hopefully that clears everything up! But the problem still remains |
| Easy-X |
 Easy-X Super Spammer
| Farmingstock |
| Easy-X |
| Farmingstock |
| jaffa90 |
 jaffa90 World Chat Champion
| Farmingstock |
| jeffyjeff |
| Farmingstock |
The last post was made 1 year, 52 days ago. Instead of replying here, would creating a new thread be more useful? |
