Honda NT650 Not going into neutral while running
NeverEnds
PostPosted: 06:05 - 12 Aug 2025    Post subject: Honda NT650 Not going into neutral while running Reply with quote
Hi all,
My NT650 doesnt seem to be able to go into neutral while the engine is running, I have to turn the engine off (or stall it) before i can change into neutral, when the engine is off it changes perfectly fine.
All other gears work fine.
any idea what could be causing this issue?
PostPosted: 08:46 - 12 Aug 2025    Post subject: Reply with quote
If it's an NT650 is it a shaft drive? If it's a BROS then it's chain, and I'd check the chain adjustment. If it's a shaftie, then I have no idea I'm afraid. Maybe change the oil?
jaffa90
PostPosted: 09:44 - 12 Aug 2025    Post subject: Reply with quote
What is the idle / tick over speed / r.p.m., also what engine oil ( make, type ), is in the engine and is the oil level correct???
WD Forte
PostPosted: 10:51 - 12 Aug 2025    Post subject: Reply with quote
First thing I'd check is the clutch cable adjustment
bikers smell of wee
NeverEnds
PostPosted: 07:04 - 13 Aug 2025    Post subject: Reply with quote
Thank you for the replies,
It is a drive shaft model.
I noticed when i brought it that clutch cable was fraying at the engine end, so i already had the intention to replace and adjust it, so i will see if that makes a diffrence.
The bite point was very low on the clutch as well (although wasn't sure if that was just because its a bigger cc than i am used to as it is my first bike above 125, or because its frayed)
jaffa90
PostPosted: 09:14 - 13 Aug 2025    Post subject: Reply with quote
Riding around with fraying cables, Shocked
NeverEnds
PostPosted: 13:49 - 13 Aug 2025    Post subject: Reply with quote
I'm not using it, only had a quick test ride around the farm when i picked it up haha, this is when i struggled to get it into neutral and the seller said about it not working properly.
i haven't got my full licence yet, so still on my 125 Thumbs Up Laughing
doggone
PostPosted: 16:40 - 13 Aug 2025    Post subject: Reply with quote
I think there's a little bit of drag due to clutch not clearing fully so gears are being pressed together when engine is on.
You might get it to work during the second or two unloading drive when decelerating.
TBH a lot of bikes are tricky at times and there's a knack you eventually do without thinking.
The last post was made 1 year, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 55.31 Kb
