| doggone |
 doggone World Chat Champion
 Posted: 13:26 - 15 Oct 2025 Post subject: Bultaco sherpa 250 |
So... we have been given this as 'running five years ago'.
Having been built up from parts in a box by previous owner
But it won't start.
After cleaning points there's a good spark and it should be timed right.
Carb seems to be getting fuel and plug gets wet with fuel - when it doesn't start after prolonged turning over by running down a steep hill.
Two strokes are known to be temperamental but would have hoped to get a few pops and bangs even if it wouldn't run properly.
We have heard crankase seals can go and that will make it not run at all.
Is this next thing to be checking.
Had carb apart to clean out and it was surprisingly good in there TBH.
I'm guessing its from about 1980 but has the look of being cared for e.g. grease on things like chain... |
| doggone |
| doggone |
| A100man |
 A100man World Chat Champion
 Posted: 18:29 - 15 Oct 2025 Post subject: |
Like Stinkers mentioned..
I'd go with weak spark (plugs, points condensor, coil - change 'em all)
and/or poorly timed.. I'd expect it to run even with bad seals - although it might not be able to pull the skin off a rice puddin'. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| ZebraDriver |
 ZebraDriver Scooby Slapper
| blurredman |
 Posted: 10:10 - 16 Oct 2025 Post subject: |
Have you actually verified timing yourself? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| doggone |
| doggone |
| doggone |
 Posted: 14:29 - 20 Oct 2025 Post subject: |
It was still proving temperamental to start from cold but it appears the choke was not working.
It has an amal mk2 concentric carb.
The choke doesn't work by restricting air but gives a richer mixture by drawing additional fuel through a fine jet when you operate the lever.
The jet is hidden in a thin channel that draws from bottom of float bowl, and it was blocked at the L shaped bit at very bottom.
With hindsight once we had spark and timing something like, the lack of choke could have been the main problem.
Once that was cleared and reassembled it has been starting first kick and not a lot of effort needed either.
So a quite usable bike for very little money - however now it is running OK we need new rear mudguard (plastic), brake shoes for rear and hose to airbox (it has been running without for testing).
The rear wheel has some loose spokes we might be able to improve things ourselves rather than sending it off with any luck.
Probably around £150 to sort it out.
https://www.inmotiontrials.com/ seem to be a good source of most parts if not always cheapest. |
| A100man |
 Posted: 15:48 - 20 Oct 2025 Post subject: |
| doggone wrote: | It was still proving temperamental to start from cold but it appears the choke was not working.
Good work - Mikuni (derived from Amal) often have the same choke /enrichening circuit.
Obviously I now feel suitably meek for my electrical mis-diagnosis.  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 1 year, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
