GT535: what if we replace the engine with a pneumatic drill?
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2
mentalboy
PostPosted: 01:01 - 12 Oct 2025    Post subject: Reply with quote
Can you retrofit a kickstart to these?
I don't think a large single cylinder machine can be fully appreciated until you've tried to kick it into life on a chilly winter morning... Laughing
Make mine a Corona.
PostPosted: 08:15 - 12 Oct 2025    Post subject: Reply with quote
Any I've seen had a kickstart from the factory. They kickstart no problem as long as the battery is charged.
One thing is though that if the battery isn't holding enough charge to turn it over on the E-start, it doesn't have enough to power up the EFI. So the kicker isn't really a backup, just a vanity feature on most of them. May be different on this one where the OP has retro-fitted a carb.
blurredman
PostPosted: 10:18 - 12 Oct 2025    Post subject: Reply with quote
Kickstart in itself is not a way to get around a flat battery. It's just a manual way of starting an engine. Unless the bike has an AC ignition then a kickstart is no use when you have a flat battery.
Easy-X
PostPosted: 10:23 - 12 Oct 2025    Post subject: Reply with quote
Yes, factory kickstart. I have tried kicking it over a few times but I'm not very good at it Smile
While technically you could fire it up without a battery, my experience with trying the same on an old Triumph involves a fair few "primer" kicks to charge a capacitor and a really swift one to get it going. Adding a battery ups the odds of success and reduces the number of initial kicks to whatever's needed to get the carb interested in what you're up to. Something like half a dozen kicks, ignition on, swift one, 50% chance of success versus two or three, ignition on, swift one, 90% chance of success.
What a kick start really does is bypass the need for cold cranking amps. A battery might hold >12 volts but fall on its arse when trying to turn the engine over, especially in cold weather. I've fitted a lithium ion battery to the GT so while there's near infinite capacity in it to shred sprags it wouldn't fair so well in the cold. A kick start may still prove to be useful in the future Smile
*edit for blurredman: these engines run a DC set up (as did the Triumph I cited). Converting to AC? Hmm, unknown territory. I'm not sure/if when Royal Enfield ran an AC system but not on their recent models, that's for sure. At the moment I'm using all standard parts so this is a Lego-brick job, nice and easy.
PostPosted: 10:59 - 12 Oct 2025    Post subject: Reply with quote
Not strictly true. Both of my pre-unit enfields can be started with a flat battery and they only have a kick. They are a DC ignition (single phase alternator, reg/rec and points).
They wouldn't do this as standard but I fitted a reg/rec with an internal capacitor on one and have a plug-in capacitor on the other. This holds enough charge to produce a spark.
Easy-X
PostPosted: 17:20 - 12 Oct 2025    Post subject: Reply with quote
Thank you, Mr. Stinkwheel. I'll just get that in pre-emptively Smile
Sun came out this afternoon, "maybe I will run the oscilloscope over the pickup coil." And as I'm wrestling the plug loose the one from the stator plops out. Most likely I didn't push it in the whole way when messing with it yesterday but essential I was running around this morning just on battery charge Shocked I dare say if it was still the original lead-acid I'd have got stuck somewhere and got very good with the kick start very quickly. So yeah, glad I went to check.
Anyhoo, a quick AC reading shows ~3V peak-to-peak from the coil and the scope confirms that:
https://www.bikechatforums.com/files/screenshot_2025-10-12_170142.jpg
I've arrowed an odd looking peak that crops up. I took a video and it does look like this appears as 1 in every 24 when I counted. I doubt the tacho is built so clever it's looking for this odd peak, I suspect it just does a divide by 24 to get the RPMs.
As a bonus item I bought a cheap temperature gauge off eBay a while back that's been sitting in a drawer. The probe you're meant to screw into an engine case or radiator seems to read around 2 kilo-ohms at room temperature and if I warm it with my hands it starts dropping down to ~1.5 - a reverse coefficient thermistor. "I wonder what the one on the GT reads as?" 1.7 kilo-ohms on a warmish day, same sort of animal I guess Smile Rather that try and fit the supplied probe I'll reuse the existing one, see what happens.
AFAIK the Hitchcocks carb-conversion kit recommends reconnecting the temp probe to the ECU purely for aesthetics. Plenty of people have left it disconnected, from what I've read, with no noticeable effect. I'd be curious to find out how sitting in traffic affects the engine and how quickly it cools down once moving again.
blurredman
PostPosted: 08:24 - 13 Oct 2025    Post subject: Reply with quote
stinkwheel wrote:
They wouldn't do this as standard but I fitted a reg/rec with an internal capacitor.
There we are then Laughing
Easy-X
PostPosted: 01:08 - 16 Oct 2025    Post subject: Reply with quote
I have loads of Arduinos and Picos lying about, how hard would it be to make a 1:24 multiplier?
For output a Pico has loads of PWN generators. For a feature so basic I had a hard job finding example code with a decent explanation. Anyhoo, I now have some code that basically goes: pick an output pin, set frequency and duty cycle, go! And seems to work well enough for 50Hz ~ 125MHz Smile Red line on the GT is diesel engine speed so say 7,000rpms to match the gauge, 24 x 7,000 = 168,000 which a Pico should handle easily. The great part is the PWM function is fire and forget so it's not a problem if the frequency changes are a bit "lazy". Set 1000Hz and it'll keep doing it until you say otherwise.
The Pico pin output is zero to 3.3V which translates to ~1.6V peak to peak. I doubt that'll be enough to trigger the rev counter but you never know. There's also a 5V supply I can tap into which should bring things within spitting distance of the 3V p2p I saw from the pickup coil.
Next up, find a digital tachometer project. I can test it by feeding this first Pico project into it Smile
Easy-X
PostPosted: 01:28 - 19 Oct 2025    Post subject: Reply with quote
To tap an RPM signal the GT currently splices into the pickup coil which as we've seen is ~3V p2p. I've ordered some bits so to start with I'll try and opto-isolator with a "micro-controller friendly" logic output. The specs say it can handle 5V reverse voltage so would 3V AC do it any harm? (with the appropriate series resistor, 200 ohm I think)
Alternatively, Hall Effect switches are very cheap. I'm wondering if I just glue one to the pickup coil there'll be enough "going on" to trigger it. The advantage would be complete isolation from the ignition electrics. For the output side I'm again going with an opto-isolator, the transistor sort, so I can experiment with various output voltages till I find what the tacho likes and also to isolate my Arduino or Pico from the bike electrics as much as possible.
From what I'm seeing of various tachometer projects, the Pico's PIO thingy (which I'm yet to fully understand) can sample frequencies. I already know the PWM system can generate frequencies so the actual CPU will act as the man in the middle and pretty much twiddling it's thumbs as its minions go to work Smile
Easy-X
PostPosted: 19:35 - 19 Oct 2025    Post subject: Reply with quote
Gone down a rabbit hole Smile
I'm trying to compare the engine we got in Europe that only came in Euro-3/4 flavours to the carb version sold in India and it's not easy to get hold of a parts list, Google continually wants to point me at Hitchcocks Sad Anyhoo, I've tracked down a "retired parts list" and on the cover is a Thunderbird Twinspark which looks like the same engine but with a CV carb fitted. Finally! We have a winner Smile
Stator and pulsar* assemblies are listed in two flavours 147058/A and 570720/A which only differ by mounting hole diameter - M6 or M5 bolts respectively. My GT has 570863 Neutral Visually 570720/A and 570863 look the same but the former has an extension cable. But! the 570720/A is also listed as the stator in a 2008, 500 Electra EFI so I'm still thinking the stator already on my GT will be fine.
As for the rotor, an EFI bike has the 24 pips on the outside, part 571062 for both the 2008 Electra and my 2015 GT whereas the non-EFI rotor is listed as 570606/A or 592237/A and has the single big pip.
tl;dr The internal engine differences between an EFI and non-EFI 350/500 engine is the only rotor and not the stator. I have one on order from India for the princely sum of £26, fingers crossed Smile
*Royal Enfield's term for pickup coils.
Easy-X
PostPosted: 21:04 - 24 Oct 2025    Post subject: Reply with quote
Parts order turned up Smile
I'm still weighing up whether to go with a Hall Effect switch or splice into the pickup coil output. The former means gluing a sensor somewhere and running an extra cable out the crank case whereas the latter requires interfering (in a very minor way) with the existing electrics.
I shall try the Hall Effect route first and the simplest is a unipolar variant billed as a digital reed-switch replacement. Regardless of orientation you can vaguely waft a magnet near it. I have the rotor but the big single pip doesn't seem magnetic enough to trigger it Sad
There are some recesses on the rotor (see picture attachment) so I'm thinking glue a little neodymium magnet in the marked region. It's far enough away from the area the pickup coil is interested in and I doubt a gram or so will unbalance the rotor (feel free to slap me if I'm wrong!).
Of course, all this assumes fitting this older style rotor will get the engine running with the TCI box.
Easy-X
PostPosted: 14:03 - 26 Oct 2025    Post subject: Reply with quote
Spinning the rotor past the Hall Effect sensor works to generate pulses. How to mount it in the actual engine? The stator and pickup coil are bolted to the RH engine case with the stator obviously placed to sit inside the spinning rotor with the pickup out seeing the outside of the rotor flashing past.
https://i.ebayimg.com/images/g/B5oAAOSweZNlgBca/s-l480.webp
I can't find any decent photos to represent this so you'll have to make do with this:
https://i.ytimg.com/vi/OBGPH9I84Vs/maxresdefault.jpg
Anyhoo, there's nowhere around the outside of the rotor to hang a little transistor-sized sensor apart from the pickup coil shell. I think there's potential for electro-magnetic interference between the two Thinking
The other thing I've noticed is all the pickup coils for TCI units are cased in grey plastic and all the EFI ones are black plastic which hints the internals may be different. It's extravagant but to be on the safe side I've ordered the older style stator assembly (hopefully with the correct mounting holes!). I shall strap the sensor to the pickup coil, set something up on my workbench to spin the rotor and see what happens.
The bonus with this approach is if the Hall Effect sensor is a bust I then have a test setup for sampling the pickup coil output instead.
Easy-X
PostPosted: 01:57 - 03 Nov 2025    Post subject: Reply with quote
While I'm waiting on the stator/pickup coil from Indian I'd better get something done Smile
Plan A: Hall Effect Sensor > Pico > Tachometer. I may need to add an opto-isolator between the Pico and tacho if something blows up. The expected input is one pulse per revolution from the old-style rotor. The Pico will multiply this by 24 to simulate the EFI-style rotor. And hopefully, as if by magic, the tacho will work.
I'm pretty good with coding but trying to piece together all the bits is a chore so I asked Grok after the Bad Obsession fellas said they'd used it for Arduinos. TBH it was surprisingly helpful! I wouldn't necessarily recommend it for a complete novice but if you were familiar with Arduinos and clueless about Picos it'd be a welcome jump-start.
Anyhoo, I described the sensor and Grok worked out little details like it'd need a pull-up resistor and gave me code for RPM output. I hooked this up to some LCD code I'd already written and it pretty much worked first go! Needed a bit of smoothing and averaging to make it less jittery but Grok pretty much guessed I would be needing that anyway. I then moved to PWM output and Grok refined the code I'd already got running to be a little more accurate.
Here's the part where I'm optimistic: a simulated 1,000 RPM equates to 16.67Hz, multiply by 24 = 400Hz. The oscilloscope showed 395Hz - pretty close - but the peak-to-peak showed 2.92V which is somehow exactly what the original pickup coil was outputting! How the... what... huh? I'm either super lucky or I done fucked up somewhere Thinking
I'll still need to adjust the duty cycle. Default in code is 50% and looking at what I posted earlier it'd need to be more like 20~25%. There's still the question of the 24th pulse being slightly different, hopefully the tacho won't miss it.
Easy-X
PostPosted: 18:56 - 10 Nov 2025    Post subject: Reply with quote
Finally! The old-style coil has turned up Smile
I'm now starting to understand the system a little better. The pickup coil is what's termed a "variable reluctance sensor" - consisting of a coil, a permanent magnet and a ferro-metallic core. If this assemblage passes close by another ferro-magnetic material, i.e. the tab (or tabs for EFI) on the rotor, the magnetic field is disturbed and a voltage change induced across the coil. End result: a simple sine-wave output.
Some interesting properties to note: the pulses are obviously proportional to the speed of the rotating rotor, e.g. 6,000 rpm = 100Hz but so also is the voltage. Hand cranking may generate a few volts at best, kickstarting or a starter motor would manage 3 or 4 volts (which I've seen already) but as you approach the redline there might be over 120V AC Shocked (albeit with a very small current)
Plan A was to install a parallel system to detect RPMs with a Hall Effect sensor. I can see some practical issues:
1) Strapping the sensor to what we now know is a permanent magnetic.
2) The neodymium magnet I attached to the rotor might disturb the output of the reluctance coil.
3) Modern construction of the coil/pickup assembly now features a fully moulded grommet, i.e. there's no gap to slip a few extra wires through (the current grommet on my GT could feature as a secondary engine breather!)
Oh dear. How about Plan B? Tie into the pickup coil output:
1) Any digital circuitry will be expecting 3.3V (5V at a push) so electrical isolation/limiting is a necessity.
2) Care must be taken not to affect the output to the extent the TCI box fails to fire.
3) On the plus side nothing needs to go inside the engine case.
Some good news for Plan B, according to wikipedia there are off-the-shelf chips designed specifically as variable reluctance digital converters: MAX9924, LM1815 and NVC1124. I might get hold of one or alternatively study how they limit the voltage and drive my Pico directly Thinking
Firing up my prototype Pico RPM counter unfortunately does show the magnet in pickup coil can affect the Hall Effect sensor. Maybe a unipolar sensor could be used with the neodymium pole set opposite to the one in the pickup but it's a lot off faffing about. Nope, not the way Sad Plan B then! I'll fit the single tab rotor, swap over the stator/pickup and, assuming it fires up okay, worry about the tacho later.
I suspect the "grey pickup" has a different number of windings to the "black pickup" on EFI engines given the former is expecting one big tab and the latter 24 small ones. Differing coil resistances would tend to confirm this, if I remember to check them Smile
Easy-X
PostPosted: 23:31 - 04 Dec 2025    Post subject: Reply with quote
I haven't done any serious work on the bike in case I need it. Stripping the electrics is a non-trivial job Laughing The good news is I have to use up my holiday before the end of the year so one more week and then I'm not back till the New Year Dance! In even better news, the Old Fella has fitted a diesel heater to his garage/workshop so I might drag it round there.
Anyhoo, more detective work! I have this PDF with the parts diagram of the Royal Enfields with my engine but carb from the factory (Indian market only) and something in my subconscious went "hmmm?" looking at the carb: no TPS Thinking "Okay, so what? They didn't plug anything in the TPS socket on the TCI unit." Oh, but they did...
Turns out (for the Thunderbird at least) the throttle cable is a dual-pull like wot u have on a dirt bike. Instead of working an old pump, the second cable pulls a "throttle position switch".
Cable 580387:
https://i.ebayimg.com/images/g/gd4AAOSwarFgK6f9/s-l800.jpg
https://www.ebay.co.uk/itm/133666385616
Throttle position switch 580288:
https://i.ebayimg.com/images/g/NOoAAOSwPDxknBs5/s-l800.jpg
https://www.ebay.co.uk/itm/134632707790
Note the cable ends, chunky "lever style" one for this cable operated TPS and a smaller end I assume is for a carb. Maybe it's the other way round but re-doing ends on cables is easy enough.
Now, whether the pull required to operate this "switch" is the same as the travel on my Amal carb... don't know! But they're not expensive parts, even if it means taking them apart to see how they work.
PostPosted: 08:31 - 05 Dec 2025    Post subject: Reply with quote
Interesting and presumably quite exploitable too in that you can probably mechanically mess with the advance curve using cable tension and length of pull without resorting to electronics.
Easy-X
PostPosted: 13:15 - 05 Dec 2025    Post subject: Reply with quote
And you could also take it way back in time and have the advance on the left hand side of the handlebar Laughing
Easy-X
PostPosted: 17:26 - 07 Dec 2025    Post subject: Reply with quote
Ordered from eBay, delivered by Amazon Rolling Eyes
The "throttle position switch" turns out to literally be what it says, much the same as a rear brake light switch. Plunger in = open circuit, plunger half way out = closed circuit. (There is a painted line half way along the plunger but actually the switch closes a little before that.)
Referring back to the TCI unit, I thought it odd that "TPS" was only a two-pin connector. Actual TPS on a throttle body or carb is either a potentiometer or something digital (+V, ground, output) so either way a minimum of three connections to work. This is just a simple switch that says "use the alternative timing curve".
Looking at the dual-pull cable, the smaller end mates with this throttle switch which means the larger end is intended for the butterfly on a CV carb. It's way too big for any slide pull carb. I will compare the pull length to the existing one on my Amal to see if it's worth swapping the end for a tiny one but I've hand made dual-pull cables before. There's not much tension compared to say a clutch cable so you can get away with brass ends and lead-based solder (vs. silver solder or brazing) so pretty easy-going stuff.
But as to your earlier point, Mr. Stinkwheel, yes very easy to adjust. I'd imagine you could set anywhere between half and wide open throttle as "alternative timing".
There is a gap of 234 days between these two posts...
to v or not to v
PostPosted: 07:38 - 30 Jul 2026    Post subject: Reply with quote
how are you getting on with the Enfield? you dont mention it much.
Moto Guzzi V7.
Easy-X
PostPosted: 15:07 - 02 Aug 2026    Post subject: Reply with quote
For the wiring stuff, I have all the parts lined up. It's trying to find the time to do it after sorting out every other cunt's bike Laughing
As for being out and about on it, I've mostly been cycling this year so it's been sat under the cover sobbing quietly. I don't mind though, it's an ideal bike to have sitting around - tax, insurance, maintenance and fuel cost fuck all.
Easy-X
PostPosted: 00:11 - 13 Sep 2026    Post subject: Reply with quote
Back to it and a quick summary of where we're at.
The central theme is minimalism. Enfields are simple bikes but we can do more (with less) errr.... Anyhoo, in a previous episode it was discovered that EFI bikes have a rotor with 23+1 pips (one large one for spark timing, the rest for engine rotation position/speed). On a carb bike - either aluminium UCE engines or the older iron ones - the rotor only has one big pip.
I went to swap over the rotor and to be on the safe side, the stator and pickup coil. Step 1: drain the oil. Noooo! Way too much effort. (Click picture for full image)
There's an old trick the Classic/Bullet guys use: lean the bike over.
https://i.ibb.co/QvRHVgnR/20260905-113851.jpg
I hadn't got round to removing the old horn brackets so the Old Fella found some scrap metal and drilled some holes.
https://i.ibb.co/zWMq6FG6/20260905-114335.jpg
Bike at 45 degrees!!!
https://i.ibb.co/XrGV8n5f/20260905-115909.jpg
Next is the standard cardboard map for the bolts.
https://i.ibb.co/27TfZTHH/20260905-120217.jpg
Most of the oil has fucked off through the marked passage. Note the O-ring that's gone walkies (red arrows) and the rotor of many pips.
https://i.ibb.co/xtdGf1R1/20260905-124057.jpg
O-ring back in place, and the new rotor has one big pip.
https://i.ibb.co/hxfmZkJt/20260905-124224.jpg
The old stator has a black theme going on. The red arrow marks the surface where the O-ring would interface. The oil filter is the other side.
https://i.ibb.co/0VWzyQgm/20260905-132033.jpg
Grey and white for this stator/pickup combo. I suspect the stators are identical but they're sold as one unit and not massively expensive.
That was Day 1, onto Day 2.
https://i.ibb.co/QvLm5ZpN/20260912-131557.jpg
Hooked up the new loom temporarily. Pickup, neutral light, battery, starter, TCI unit and spark plug coil. (Didn't bother with lights or reg/rec).
https://i.ibb.co/RphY5zyr/20260912-135651.jpg
At the front: only the ignition, right hand switch cluster and the new addition of an ammeter. (I think this loom is from a Classic).
Will it start?
Umm... sort of. Actually (once I got the hang of it) better than it did before. Rewind to what I'm used to: drop the choke, tickle the carb, crack the throttle 10%, hit start. Nope! Didn't like any of that, coughed and backfired badly. What it did like is no choke, carb already tickled so skipped that, throttle left alone, hit start and it was purring like a kitten. Huh, okay Laughing
I tried a little throttle, nope! Backfiring again. Hmmm... well it was working before so fuelling ain't the issue, only timing. Then I remembered the throttle switch (scroll back a few posts). I hooked that up and gave it another go... much better! Hmmm. Much hmmm-ness. Time for a cup of tea Smile
I did a little research on the "TCI-units" as they're called. Royal Enfield aren't very imaginative so there's a very straightforward progression with these things:
Black units - the very first transistorised ignitions when they switched from points to the pickup coil on the rotor.
Green units - dual-curve timing and the unit I currently have. There are two timing curves: idle/decel and give it the beans. Maps are selected via the previously mentioned cable pull switch.
Blue units - "digital" timing, no switch required! Apparently the rise in RPMs is calculated and appropriate timing chosen. Created because Royal Enfield were sick of pull switch failures.
Brown units - multi-curve. On the very last Classic/Bullet 500 UCE bikes (Indian domestic market only) but requires a UCD33 CV carb with TPS.
Given retrofitting TPS to a slide carb is impossible, I've ordered a Blue unit rather than strip out the throttle cable and figure out where to mount the pull switch. I still need to strip the old loom and refit the new one but I'll wait till the new unit turns up.
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 135.69 Kb
