Space heater.
Kawasaki Jimbo
PostPosted: 19:58 - 05 Dec 2025    Post subject: Space heater. Reply with quote
I fancy doing some winter motorcycle maintenance in my garage but, y’know, it’s winter. The garage is off-site (though just a few feet away), it has no mains electricity and I’m renting so I can’t do much to it. Would a propane/paraffin/diesel space heater under the up-and-over door project fumes and condensation into the garage? I think I’ve misunderstood how they work, they surely can’t be blasting combusted fuel into the space?
Something like this -
https://www.toolstation.com/sip-fireball-342-propane-space-heater/pAH924
Anyone using similar?
doggone
PostPosted: 21:03 - 05 Dec 2025    Post subject: Reply with quote
that must need mains power for the blower.
You seem to be describing a 12v diesel heater or something more like portable gas heater with ceramic burners - these chuck out a lot of heat and radiate to wear you need it.
The chinese diesel heaters are OK but take five minutes or more to get going and you need a 5 minute cool down its inadvisable to just shut it off when red hot inside.
You can have it blow where you are working - they are a bit noisy but not outrageous.
Kawasaki Jimbo
PostPosted: 22:18 - 05 Dec 2025    Post subject: Reply with quote
Oh yes, the specification does say 230v. I thought it was solely propane-powered. Why would anyone choose that over a mains-electric heater? Running cost, I suppose, but I’m not looking for a long-term heater, just a weekend afternoon jobbie to keep me warm while I’m in there.
lingeringstin...
PostPosted: 03:46 - 06 Dec 2025    Post subject: Reply with quote
I use the internal heater gubbins from something like a Valor 12D. It's a big standard paraffin heater like what used to be touted as a room heater for homes only I don't bother with the big tin housing. It barely sips paraffin and throws out decent heat for a garage. Cheap to run and barely smells. Use decent paraffin and it works a treat.
blurredman
PostPosted: 13:01 - 07 Dec 2025    Post subject: Reply with quote
Don't they say that if you're still cold whilst working then you're not working hard enough? Razz
Kawasaki Jimbo
PostPosted: 23:50 - 07 Dec 2025    Post subject: Reply with quote
I’m not expecting to work up a sweat by twirling spanners but I know what you mean. I was briefly in the garage this afternoon moving stuff around without actually doing any work. The air was mild but damp. I think I’m just looking for justifications as to why I’m not getting jobs done when really it’s lethargy. I think I have the hibernation gene but modern life requires I resist it.
WD Forte
PostPosted: 00:37 - 08 Dec 2025    Post subject: Reply with quote
Wear a coat then ya big softy
bikers smell of wee
sickpup
Old Timer
PostPosted: 00:58 - 08 Dec 2025    Post subject: Reply with quote
Look at throwing down some rubber floor tiles, an insulated floor makes a huge difference.
blurredman
PostPosted: 11:10 - 08 Dec 2025    Post subject: Reply with quote
Agreed. I also procrastinate pathetically, but just a bit of acclimatising and doing 'something' in the shed or garage whether it cleaning or simply just doing the damn task means I don't even think about it after a minute or two. Bring a cup of tea, is a good idea.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 62.62 Kb
