| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 14:10 - 05 Feb 2026 Post subject: Strange Dyno Result - 2011 Honda Hornet 600 |
Dear depraved inhabitants of BCF. I put my bike on the dyno, and the results are.... odd.
Some context -
Bike is a 2011 Honda CB600F Hornet ABS - https://www.motorcyclenews.com/bike-reviews/honda/cb600f-hornet/2007/ I bought it a couple of months ago. It's in generally very nice condition. It's done 16k miles and just had the valve clearances done. It has a Healtech gear indicator, and a quickshifter (which is ignition only). I don't like the quickshifter so it's been disabled/bypassed and wasn't powered when the dyno run was done. The previous owner fitted a set of aftermarket headers and silencer, replacing the original system. But he didn't get it remapped. This last point is the reason I put it on the dyno, as I was worried it might be running too lean with the reduced backpressure of the new pipe.
So, the dyno graphs. There are 3 runs on the printout.
1 Slow Throttle Roll On
1 Wide Open Throttle (WOT) without load
1 Wide Open Throttle (WOT) with load.
The dyno tester is a specialist in classic bikes, modern FI bikes aren't really his forte. But he didn't seem worried about most of it, particularly the air/fuel ratio which he said was "acceptable". Also the big spike in the WOT load run is because he was getting a dirty signal from the ignition (this is also the reason there is no measured torque), so that can be ignored.
What he did seem very confused about is the power just flatlining at 70hp. This bike is listed as being 100hp (at the crank). That should be around 85hp at the wheel/dyno. He said it looks as though the bike is going to make exactly that, and then it just stops making any more. He asked me if it was electronically limited, or an import, or if I'd heard of any speed limiters applied to this model. As far as I know, none of those things are true, and the bike is completely standard apart from the mods I've mentioned.
I did find this thread on reddit, and the symptoms aren't the same, but I wonder if I could be seeing early signs of this issue - https://www.reddit.com/r/MotorcycleMechanics/comments/1nk8ddx/honda_hornet_600_2012_bike_wont_rev_past_7k_under/
So, what could be the cause? And how can I fix it? ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| stinkwheel |
 Posted: 16:37 - 05 Feb 2026 Post subject: |
The bikes own gear sensor and clutch switch both working as they should? Effectively does the bike know it's in top gear with the clutch out?
They'll sometimes pancake the power curves if the bike thinks it's in got the clutch pulled or is in neutral/a lower gear to stop you rev-bombing it to death or flipping it.
Both systems may have been messed with if you have an aftermarket gear indicator and a quick shifter. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Zen Dog |
| A100man |
 A100man World Chat Champion
 Posted: 21:35 - 05 Feb 2026 Post subject: Re: Strange Dyno Result - 2010 Honda Hornet 600 |
Does yours rev to the limit? The solution for the Reddit guy was a new fuel pump - cheap enough to eliminate that possibility right? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| stinkwheel |
| Zen Dog |
 Posted: 11:02 - 06 Feb 2026 Post subject: Re: Strange Dyno Result - 2010 Honda Hornet 600 |
| A100man wrote: | Does yours rev to the limit? The solution for the Reddit guy was a new fuel pump - cheap enough to eliminate that possibility right? |
Yes, it revs all the way up on the road, at least at the moment, but the guys on that reddit thread mention not being able to go over a certain speed, which implies that theirs was also making up to a certain power and then stopping. And you'd think a fuel pump would be a cheap fix, but officially they're £750 (and unavailable). You can get chinese versions on ebay for £100. Which I'll happily pay if it's definitely going to fix it, but it seems a lot for a punt. I think I'm going to have to try it though. One thing that I'm thinking about now is that the previous owner said he was selling it because it "wasn't fast enough". I took this with a pinch of salt because he was a young guy and wanted an MT-09, but now I wonder if he was seeing something.
| stinkwheel wrote: | My knowledge of FI bikes is pretty limited but I do know a lot of them use a different ignition and fuelling map for different gears. So there's a rev limiter in some of the lower gears and neutral for example. Your curve looks like it's deliberately cut-off. Maybe that kind of thing came in after 2010? |
Yeah, that's definitely a thing. In fact the dyno tester has told me if I bring it back, he'll run it again in 2nd gear to see if it's any different, but I want to feel like I can discount multiple possibilities if I'm doing that. I've got the original exhaust so I'm probably going to fit that, probably a new fuel pump, and maybe see if I can disconnect or remove the quickshifter and gear indicator.
It's just such an odd issue as the bike feels fine generally, revs cleanly etc. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| stinkwheel |
 Posted: 00:22 - 09 Feb 2026 Post subject: |
Also check it's an official UK model. I bought a VFR750 a few years ago and it wasn't until I found an optical switch taped up in the back of the clocks I did some more digging and found it was a Japanese import with UK clocks fitted.
Restricted in various ways to about 30% less power than the UK model. I'd thought it was a bit lacklusture compared to my previous one and had put it down to it being an older model. Not all of the differences were reversible either. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| stinkwheel |
| A100man |
 Posted: 12:55 - 09 Feb 2026 Post subject: |
| sickpup wrote: | I can't find any information on it but I'm wondering if it's restricted?
There was a European country, I think it was Germany who used to have stepped licensing. First step at 40ish BHP and the second step at 70ish BHP.
There was also a Japanese restriction of 70ish BHP, I worked on a GSXR750M that was restricted via ignition, carbs and cams.
If it was mine, before I did anything I would check whether or not its an import and whether or not it's a UK spec bike. The print out does suggest its restricted to me. |
Intriguing .. I searched and found this thread on line too..
https://netrider.net.au/threads/japanese-restriction-whats-that-got-to-do-with-us.93618/ ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| sickpup |
 sickpup Old Timer
| Zen Dog |
 Posted: 19:22 - 15 Feb 2026 Post subject: |
Thank you for the suggestions. I've been doing some investigating.
Restriction was my first port of call as it fits the symptoms so well. The ECU is marked 38770MFGD02 Keihin, made in the UK, which seems to be standard (according to fowlers parts fiche). Checking for airbox/intake restrictions is harder than I expected. The airbox access for changing the airfilter is separated from the intake trumpets by a mesh divider, and (due to the spine frame) getting past that requires removing the entire EFI system off the bike. So I got a torch and spent a long time shining it through the mesh instead. They look exactly like the ones in the italian service manual I found to me, but because I can't actually get my fingers/eyeballs to them properly, I can't be 100%.
The bike gives every impression of being a standard UK model. Labels are all in english, I've got the service book and owners manual and they're in english too. HPI check says it was first registered 2011. Code under the seat says it's a CB600FA9. That may mean it's a 2009 model, but I can't find anywhere that can properly confirm that. So it's possible it was somewhere else for 2 years and imported. It's also possible it sat in a Honda dealer for 2 years. This is exactly the period that everyone who wanted a naked 600 bought a Street Triple. Overall I'm not sure how I can 100% confirm it's a UK model, but I'm going to say it probably is. If it's not a UK model, that fact has been deliberately obscured.
I've removed the quickshifter. The previous owner had fitted it, and lets say the attempt was amateurish at best, and I say that as an amateur. One of the new quickshifter coil connections was taped to the old one in order to make the connection. It's now been completely removed, though I did have to leave one wire tap in place and just cut the connection to the quickshifter. I wonder if this was the cause of the "dirty ignition signal" issues the dyno guy reported.
I've also been riding it a bit. Partially this is just to run the tank down so I can get in there and have a look at the fuel pump. But it was also to see if I could feel the power flatlining. Straight after I picked the bike up from the dyno, I took it out and redlined it a couple of times, and it felt like it wasn't giving more above 10k. But I took it out today and now I'm not so sure. The bike is so high geared it will do about 70mph in first, so opportunities to rev it out properly aren't actually that easy to come by, and IL4s increase power in such a linear fashion that the expected change in feel between it continuing to increase power, and "only" giving 70hp, can feel pretty subtle. There were times today that I felt it kept building power to the redline, and other times that it lacked that final zing at the top. But I can't be sure that either feeling wasn't just in my head. Partially this difficulty and subtlety makes me wonder if it's even worth worrying about. But now I know there's an issue I need to get to the bottom of it.
Sickpup, hopefully some answers to your other questions. I've been thinking about throttle movement/body restrictions. I don't think movement restriction is likely, because I'd expect the resulting power curve shape to be normal, but it would happen to top out at ~70hp. Not this strange flatline. Body restrictions are definitely possible, but again like checking the intake trumpets, I'd have to take the whole EFI system off to check and honestly it's like spagetti with all the pipework and wiring. I'm going to try to exclude some other possibilities first.
The exhaust is a set of Black Widow headers, and some cheap baffled silencer (I can never remember the name for some reason). They are definitely not fancy, but they don't look obviously awful, if you know what I mean. The lambda sensor has been refitted. I've got the original exhaust, and I'm tempted to refit it, partially to exclude it as a cause, and also because I'm not really into anti-social exhausts, and this one is borderline. But I need to check over the old exhaust and check all the parts are there, as the previous owner may have not given me everything, may have buggered the thread for the lambda sensor getting it off etc. etc.
Fuel pump is definitely a possibility, I've seen it mentioned multiple times by owners, and it was a known issue with the generation of CBR600RR that the Hornet's engine was based on. Officially the fuel pump and filter are all one (incredibly expensive, and now unavailable) unit, so no one ever changes them. I'm just about to order a chinese replacement, then I'll take it apart and compare them. I'll probably try to keep the original pump unless theres something obviously wrong with it, and just change the filter, but we'll see.
I'm not sure on the cause of the dirty signal. But I got the impression that the dyno guy was having a problem getting a good reading, not that he thought there was something wrong with the bike's ignition. But I didn't question him further about this. The plugs have been changed, the previous owner gave me the old ones, they look ok to my unpracticed eyes.
I don't think the bike was connected to a diagnostics reader when it was on the dyno. That does remind me though, I found the procedure for reading any stored codes, so I need to do that and see if there is anything in there. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 00:48 - 23 Feb 2026 Post subject: |
I've done more stuff. I bridged 2 of the pins in the diagnostic port, which the Haynes manual says is supposed to illuminate the FI light, and then flash in sequence with any stored codes. However, the bike doesn't actually have any lights marked FI. It does have an EMS (orange engine symbol) warning light though, which illuminated (it doesn't normally) and then didn't flash. So I'm assuming that's no error codes stored.
I've had the fuel pump out. Each of the nuts attaching it to the fuel tank had a paint smear on it and the bolt, and they lined up, so I'm assuming it's still the original pump/filter assembly from new. Taking it out though, it looked fine. I then spent about 20 minutes trying to take it apart so I could have a proper look at the rubber bits for potential splitting etc. But I failed, I still can't work out how it comes apart. With the garage slowly filling with petrol fumes, I gave up and just fitted the new chinese filter and pump assembly as a whole unit. It seems to work fine.
I've worked out slightly more precisely at what revs the bike stopped making power on the dyno. In 6th gear, the bike is at 8k rpm when doing 95mph. So I reckon at 100mph (which is when power stopped increasing on the dyno) it was probably doing 8500-9000 rpm. One of the times I tried it today, it was definitely making more power above that. Power felt like it was tailing off about 12000 rpm, which seems pretty normal. So either one of the things I've done has fixed the problem, or it's intermittent. I don't know why, but it feels like it might be intermittent.
One thing this testing has really brought home to me though, is the sound from the exhaust. Getting the best out of this engine means being in the top third of the rev range, and this bike screams. If I'm riding fast, I would prefer as few people knew about it as possible. I'm going to have to put the original exhaust back on, despite it probably adding 5kg to the bike, and not looking as good. Though I actually do have a soft spot for the attempt to make it look like the 400/4 exhaust, and make it look as inoffensive as possible. Loads of modern bikes have wilfully ugly exhausts. And a factory fitted stainless exhaust should be applauded too really. I do wonder if putting the old exhaust back on will also improve some slightly odd characteristics. At very low throttle loads, it's a bit stuttery. I end up riding in a higher gear just to load it a little more, and it's fine then. My VFR800 does it a tiny bit, but it feels a lot woolier. I'm not sure if that's just an FI/emissions "feature" really. The other odd thing is the way the revs drop. I've tried to take a video of this, but basically, if you blip the throttle, the revs don't drop cleanly down to idle. It's like the engine gives a couple of micro-revs to arrest the drop on the way down. In itself, it's not a problem, and you don't feel it when you're riding, but it's just odd, and I've never seen it before, so I wonder if it's related in some way to the power problem.
So that's where I'm at. If anyone has any tips on tarting up slightly-scabby stainless exhausts, I'm open to suggestions!
Oh and I've attached some pics. All threads need pics.
- General bike pic.
- Inside of the airbox, with the mesh that stops you getting a proper look at the intakes. This bike really is super clean.
- Attempted pic of the intake trumpets. They look like the rubber intake variant. Why are there two apparently equally valid variants???
- Screenshot from the Italian Service Manual. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 00:55 - 23 Feb 2026 Post subject: |
Odd rev drop vid. It does it a bit more when it's cold, but the bike was fully up to temp here, so it only does it once or twice after each blip. Hopefully the sound comes out well enough. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Zen Dog |
 Posted: 11:35 - 15 Mar 2026 Post subject: |
Bike seems fine now, I've put a couple of tanks of fuel through it and it certainly feels like it's got that zing again. I assume it was the fuel pump/filter. It's booked in to go back on the dyno and confirm in a week or so.
It's still on the aftermarket exhaust at the moment as I'm cleaning up the original. Thread to come in "Show and Tell". ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 104.35 Kb
