Engine cut out problem
cresad
PostPosted: 15:52 - 17 Mar 2026    Post subject: Engine cut out problem Reply with quote
Hi all
I've got a 2002 Suzuki bandit 600s that cut out on me just after turning at a set of lights. I pressed the indicators off and the engine just stopped. I've got nothing happening when I press the starter button and it has blown the ignition fuse.
I've tried changing the flasher relay , as it happened when I pushed the indicators off , and the starter relay with no change. I've also disconected the – flasher relay , horns , neutral switch , clutch switched , the new headlight relays that I'd put on amd then the whole new wiring all with the same result blown fuse.
Both of my multimeters are marked 10amp on the current measurement so no good when I'm blowing 10a fuses.
Not sure where to go from here
Thanks , Adam
PostPosted: 16:01 - 17 Mar 2026    Post subject: Reply with quote
I'd be looking at the headstock to check for wires that had lost some of their insulation. It might be related to the switch press to deactivate the indicators, but might it also be related to turning the bars perhaps? Sounds like a short somewhere, I'd be looking at a wiring diagram and continuity testing everything from the bars backwards.
A100man
PostPosted: 16:50 - 17 Mar 2026    Post subject: Re: Engine cut out problem Reply with quote
Ah, recent - why new relays?
WD Forte
PostPosted: 18:47 - 17 Mar 2026    Post subject: Reply with quote
As per Marjay, that bike could have all manner of age related issues
that go ignored until they play up.
I picked up an old bike dead cheap once where the PO had played
'swap and hope' to no avail and basically gave it away.
A quick continuity test showed a cable near the headstock which supplied power to the solenoid had broken and for me, it was a quick fix.
bikers smell of wee
A100man
PostPosted: 19:08 - 17 Mar 2026    Post subject: Reply with quote
This happened to my brothers R100 beemer, and since Ze Germans didn't think it appropriate to fuse the cicuit it smoked and melted half the loom. Rolling Eyes
PostPosted: 19:14 - 17 Mar 2026    Post subject: Reply with quote
I have a wee trick I sometimes use to find an intermittant short. If you fit a bulb holder with two flying leads with spade connectors on, you can install it where the blowing fuse goes.
Since you now have a load in there, it's no longer a short circuit. The bulb will light instead of the fuse blowing. Then start disconnecting stuff methodically until it goes out/dims and you've located the short.
cresad
PostPosted: 23:10 - 17 Mar 2026    Post subject: Reply with quote
Thanks for the quick reply’s
The new relays are a pair , one each for the 2 lights , low and main , as they were both dim . Since the new year dogding the rain I’ve changed the headlight unit ( faired bandit ) and fitted the relays to brighten them.
Just ordered a 20a multimeter to try a similar thing to using a bulb
Thanks , Adam
PostPosted: 23:30 - 17 Mar 2026    Post subject: Reply with quote
Thanks , Adam
If it's a dead short, it'll just pop the meter anyway. If it doesn't, it'll cook the wiring The flasher wiring isn't thick enough to cope with 20A.
If you want to use a meter to do that, set it to measure resistance, take out the fuse, put one lead in the fuse holder and connect the other to earth. When there's a short it will read a very low or zero resistance. When you've moved/removed the part where the short is, the resistance will increase.
ZebraDriver
PostPosted: 07:42 - 18 Mar 2026    Post subject: Reply with quote
Just be aware that a 20 Amp multimeter will only be rated to carry current for a short time - something like 10 or 20 seconds. You can't just put it in circuit and let it operate while you look for the fault.
PostPosted: 10:20 - 18 Mar 2026    Post subject: Reply with quote
I suppose it would find the fault though. Just hook up a 20A meter in place of the fuse then replace all the wires that are on fire. Laughing
Copycat73
PostPosted: 17:58 - 18 Mar 2026    Post subject: Reply with quote
continuity check on the alternator .. looking for a burnt out phase...
caveat emptor
jeffyjeff
PostPosted: 23:38 - 18 Mar 2026    Post subject: Reply with quote
If the short is blowing the bike's 20A (30A?) main fuse, it will blow the 20A fuse in your 20A rated meter just as quickly. Stinkwheel's lightbulb idea is brilliant. If you insist on using an ammeter to troubleshoot a short circuit, at least use it in series with the light.
cresad
PostPosted: 21:47 - 02 Apr 2026    Post subject: Reply with quote
Hi All
After a lot of troubleshooting I decided to remove the 2 headlight relays and wiring and put it back to standard , I still have the spot lights that are relayed and triggered by the side light. The bike is now running as good as before ( I'd just done the yearly brake and carb strip and clean ) so I'm going to have to stick to the original headlights.
I'm guessing that having 3 extra sets of wiring taking a direct feed from the battery through relays was to much drain for the system.
Thanks , Adam
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 78.55 Kb
