CBR600FY, two different types of clutch plate?
PostPosted: 12:00 - 01 Jun 2026    Post subject: CBR600FY, two different types of clutch plate? Reply with quote
Servicing the clutch on Mrs stinkwheels CBR600FY (The "Goldilocks" first of the alloy frames, last of the carbs model).
The workshop manual and parts list show the two outside friction plates as being somehow different to the middle five. The manual takes pains to tell you not to get them out of order, and they have different part numbers on the parts list.
The ones in it are OEM Honda plates but they all look and measure identical with one exception. That being the outside plate which has a green colour on the end of one of the tangs and has KA3 10 7 stamped on the tang, all the others have KA3 10 8 and no green. It is in all other respects identical as far as I can see/measure and all the others are identical.
I'll add, I doubt the clutch cover has ever been removed and if it has, they did so very carefully and were expert at putting hondabond on the mating surfaces.
So the question, anybody know the difference between the two outer and five middle friction plates?
I stripped it because it has a slightly vague bite point when slow riding, a touch on the grabby side. The plates all measure up well within spec, the springs are at the lower end of acceptable free length so they're getting replaced. Everything I read says there should be two different sorts of plate in there and perhaps this is the problem?
It's supposed to have two of these: https://www.cmsnl.com/en-gb/products/diskclutch-frict-nas_22201mae000/ and five of these: https://www.cmsnl.com/en-gb/honda-cbr600f-hurricane-2000-y-england_model2383/disk-clutch-frict-nas_22201mase00/
Parts list for clutch: https://www.cmsnl.com/en-gb/honda-cbr600f-hurricane-2000-y-england_model2383/partslist/E__0600.html
to v or not to v
PostPosted: 20:41 - 01 Jun 2026    Post subject: Reply with quote
manual said similar about my Thunderace.
when i ordered new friction plates from Yamaha they were all identical.
the plates had be revised on later models and were backwards compatible.
Moto Guzzi V7.
PostPosted: 13:16 - 03 Jun 2026    Post subject: Reply with quote
Ok. I now have both sorts of OEM plate in front of me. The friction pads on the two end plates are 0.5mm wider than the ones on the 5 middle ones. Same number of pads.
Seems like a very small difference but thinking about it in terms of surface area over 48 pads on two plates (4 sides) that makes 1142mm^2 more friction material surface area.
blurredman
PostPosted: 07:59 - 04 Jun 2026    Post subject: Reply with quote
Honda CX has the same.
Pete.
PostPosted: 08:33 - 07 Jun 2026    Post subject: Reply with quote
The Hayabusa has two plates that are slightly thicker than the rest.
a.k.a 'Geri'
PostPosted: 13:24 - 07 Jun 2026    Post subject: Reply with quote
Someone had definately been at it. On reassembly, I noted the outer plate, as well as being different, goes in a different slot in the basket. It wasn't when I took it apart.
Took me a minute to twig the cover dowel pins and bolts are at an angle to the gasket face so you need to fit it slightly offest then it pulls down and across as you tighten it down.
Fitting a cover with sealant only (no gasket) always gives me a squeaky bum. Got a good tip off the permatex website though which is to tighten the bolts finger tight which forms the gasket then wait an hour before torquing it fully. Then the gasket is fully formed and any squeeze-out (hopefully none but how do you know?) remains firmly bonded to the gasket.
Hopefully have a nicer clutch action after this.
Pete.
PostPosted: 16:49 - 07 Jun 2026    Post subject: Reply with quote
Again, this is somewhat similar to the 'busa clutch. I know not why.
Reducing squeeze-out it easy if you paint the sealer on with an artist's brush. No need to wait then.
a.k.a 'Geri'
sickpup
Old Timer
PostPosted: 20:08 - 11 Jun 2026    Post subject: Reply with quote
It's to do with the stack height of the clutch I believe. The plates are the same I believe or at least inter-changable other the thickness. As the clutch wears you can simply change one or two thin plates for the thick ones and it takes up any slip but over do it and you can't pull in the clutch.
It may say on the next page of the manual what the stack height needs to be, min and max, I'm pretty sure it says in the SRAD manual so likely says in the Busa' one.
Honda have used a different outer plate for years.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 63.32 Kb
