| Raistlin |
 Raistlin L Plate Warrior
 Posted: 11:17 - 30 Jun 2026 Post subject: GSX-R 1000 L6 cutting power at 10,000 RPM (No FI Light) |
Hi everyone,
I'm having a frustrating issue with my 2016 Suzuki GSX-R1000 L6, and I'd really appreciate any advice from those who may have experienced something similar.
The Problem
When I'm riding and open the throttle, the bike accelerates perfectly up to around 10,000 RPM. As soon as it reaches 10,000 RPM, the engine suddenly cuts power, as if it's hitting an unexpected rev limiter or momentarily losing power. The RPM then drops slightly, after which the engine pulls normally again until it reaches 10,000 RPM, where the same issue repeats.
Additional Details
There is no FI (Fault Indicator) light on the dashboard, and no error codes are displayed.
Low and mid-range performance is completely normal, with crisp throttle response.
The problem only occurs under load at high RPM. The engine revs normally in neutral.
Since there are no FI warnings or stored fault codes, I'm wondering if anyone has experienced this exact issue before or has any suggestions on what I should inspect first.
Any advice would be greatly appreciated.
Thanks in advance! |
| A100man |
 A100man World Chat Champion
 Posted: 14:50 - 30 Jun 2026 Post subject: |
Has it always don this in your ownership or is it something that just started recently? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Rob W |
 Rob W World Chat Champion
| Raistlin |
| Raistlin |
| Raistlin |
 Posted: 18:37 - 30 Jun 2026 Post subject: |
I found the problem, thanks for trying to help.  |
| Pete. |
 Pete. Super Spammer
| Raistlin |
