| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 19:09 - 12 Jun 2026 Post subject: YBR ESD Power Loss |
12 June 2026
https://live.staticflickr.com/65535/54575078048_e81c6eccd1.jpg
2015 YBR125 ESD purchased new (old dealer stock) in 2019, 23100 km on the odometer. The ESD model has a carbureted engine (Mikuni BS25) sold primarily, dare I say, in the third world. The Pakistani YBRs are ESD models as are YBRs sold in Central and South America, to my knowledge. No electro-mechanical issues other than a TPS replaced at 20800 km. The bike is well-maintained (over-maintained to be honest) and runs better than it did when new…up until yesterday.
I was riding on Moroccan highway N6. It was 35 degrees C, and I was about 60 km into my trip and riding at 80 kph. Several km after turning the fuel tap to "reserve", the bike suddenly lost all power. To wit: instantaneous loss of throttle response and uncontrolled deceleration. After slowing to around 60 kph, the power magically returned. I kept riding, and after an uneventful 10 km, I started to think, "maybe that was just a little hiccup, nothing to be too concerned over." Then it happened again. No hesitation, no stumbling, nothing to indicate that the carburetor was starving for fuel; just an immediate loss of throttle and resulting deceleration. I thought "ignition power loss," but then I noticed my high-beam indicator illuminated even as the bike was in the state of power loss. As I slowed, the power immediately returned when I downshifted from 5th to 4th. Well that's odd. The glitch recurred 3 times over a 12 km stretch, and each time I was able to recover power by downshifting, except the last time required two downshifts to third before power returned. Six uneventful kilometers to the petrol station, where I filled the tank. I rode twenty-eight kilometers to home (after filling up) without any recurrence whatsoever. I had the fuel tap on reserve most of the way to see if that might be a contributing factor.
The instantaneous onset of power loss suggests ignition system failure, but it is odd that downshifting the transmission could bring about such an immediate return of power; coincidence? Maybe, but I have never experienced a repeatable coincidence like that.
I would normally dismiss the fuel system as the cause due to the split-second onset of symptoms, but it is hard to ignore that the problem manifested shortly after turning to "reserve", and only occurred when the engine was drawing fuel on the reserve standpipe.
I'm in Morocco until September. When I return, I'll probably have a spare fuel cock and an extra ignition coil in my bag. In the meantime, I intend to keep the fuel tap in the reserve position to see if that makes a difference. I checked the fuel filter (part of the petcock) and it was unobstructed. Once I run the tank down to less than 5 liters, maybe I'll drain it and remove/inspect the petcock. Specifically, I will be looking for a crack, hole, or damage to the shorter standpipe.
If anyone can suggest actions or observations I might make in the meantime, I'm all ears.
Thanks for reading. ____________________ History shows again and again how nature points out the folly of men - BOC |
 Posted: 20:51 - 12 Jun 2026 Post subject: |
Well, a fuel tap obstruction seems possible.
Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 Posted: 19:36 - 17 Jun 2026 Post subject: |
| stinkwheel wrote: | ...Or even vapour locking in that kind of heat with a prolonged ride (fuel in the float bowl boiling). Especially with a small amount of fuel in the tank to get heated up. |
Thanks for that idea. I had not considered vapor lock, last week the temperature around here got up into the low 40's and the bike performed normally (albeit with a little more fuel in the tank.) I spent part of 1976 in Arizona, and vapor lock was a common occurrence on some of the military vehicles we had in our fleet. Similar to fuel starvation, vapor lock would make the engine falter before stalling out altogether.
I did drain the carburetor, and found 5 or six small (<1mm) water droplets in the fuel. Morocco had an unusually wet winter this year. I'm wondering if maybe some water momentarily obstructed the main jet, and when I down-shifted the increase in vacuum caused the water to pass. Probably a little far fetched as theories go, but worthy of further investigation, I suppose. I intend to drain the tank, or at least measure rate of flow on the fuel tap normal and reserve positions. I will carefully inspect the fuel for water inclusion, especially from the reserve tap. Being in a rural area here, there is no fuel line available in the nearest village, and that has delayed me so far.
I also took a peek under the tank where the coil resides. It is covered in dust and the mounting bolts look a little rusty. I'll probably remove it for a good physical inspection and clean up of contacts and mounting points. It also occurred to me to inspect the magnetic pickup and circuit connections to the ecm.
This is a relatively remote area, and I really don't want to risk the bike taking a big shit miles from nowhere. Once i poke around a little bit, I'll feel a little better about venturing further afield. Hopefully I'll find something out of the ordinary. ____________________ History shows again and again how nature points out the folly of men - BOC |
| jeffyjeff |
| WD Forte |
 WD Forte World Chat Champion
| jeffyjeff |
 Posted: 22:16 - 02 Jul 2026 Post subject: |
So I took the bike out on my local test route last week, and the sudden no-power glitch manifested 4 times in 40 km under very similar environmental conditions. It happened with the fuel tap in both run and reserve positions, and in each case the power returned before I could even react; so there are two more data points. I decided to dive deeper into the ignition system, and was surprised at the apparent condition of the wiring upon removal of the fuel tank. Much of the harness was spotted with a kind of furry discoloration; resembling mold growth. Some of the exposed wire insulation also had dark spots. I cleaned up the harness with a damp rag and compressed air, and inspected the terminals at the accessible connectors, including the ECU and ignition coil. I removed the coil and cleaned up the spade terminal and mounting points with 400 grit sandpaper, then reinstalled and checked the spark.
I was surprised to observe a really weak spark. It was indeed a blue spark, but it was really small, a micro-spark that appeared to dance around the spark plug center electrode. I removed the coil once again and checked primary and secondary winding resistance against the manual specs.
My coil measured 0.9 ohms on the primary, and 7.84 k ohms on the secondary.
https://live.staticflickr.com/65535/55371031618_cd48e2f3c2_c.jpg
My coil has a single spade, like those on the 2005-06 YBRs and all XT models. As stated earlier, mine is a 2015 YBR ESD model, an orphan (at least in terms of available technical information), so I'm really not sure if my readings are out of spec or not.
On a hunch, I went down to my local hardware guy, who sold me a Chinese coil for a Honda GB125 (less than 5 quid!) that matched my OE coil dimensions exactly. It also matched my OE coil ohm readings exactly. I mounted it and found, unsurprisingly, no change in my weak spark condition.
Then I remembered that last year I had replaced the spark plug. My YBR takes an NGK CR6HSA spark plug. Last year, I found a set of four at an attractive price off Ebay. Oddly, they came in a Honda branded box (probably for a Honda inline four of some sort), but I really wasn't concerned about that much at the time.
https://live.staticflickr.com/65535/55370983643_3482b79398.jpg
I checked the spark on a used OE NGK plug and voila! The spark strength returned to about 80% of what I expected. I reassembled the motorcycle, and today I took it for a 60 km test ride with no recurrence of the issue.
So now my suspicions are focused on the spark plug. Perhaps I unintentionally installed a resistor type spark plug into a resistor type spark plug cap. Or perhaps I unknowingly obtained counterfeit NGK spark plugs that do not perform up to standard. Maybe both.
At any rate, that is where things stand today. Time will tell if the abnormal operation has been repaired permanently or temporarily. ____________________ History shows again and again how nature points out the folly of men - BOC |
| WD Forte |
| jeffyjeff |
| twowheelwonde... |
 twowheelwonde... Derestricted Danger
| jeffyjeff |
 Posted: 15:04 - 25 Sep 2026 Post subject: |
UPDATE 25 SEP 26: I now have ridden the bike 1361 km since the power loss incident without recurrence. I recently performed the 24000 km service, which includes a valve lash check and adjust. Valve lash was within Yamaha specification. I opened the petcock to drain the tank, then tried to invert the tank to remove all remaining fuel. Unfortunately, the steel cup (with the fuel nozzle restrictor hole) prevented the unusable volume from completely draining out. I could have removed the petcock but was not inclined to do so. Peering inside with a torch, I did not find any debris in the tank. This whole ordeal has made me hypersensitive to consistent smoothness of engine operation, and I have experienced an occasional hiccup that, prior to June 12, I would not have given a second thought. These instances are rare, however, the last one occurring 540 km ago. I am inclined to believe that the coil and spark plug change has done more to alleviate the condition than anything else I have done. The bike is running great under some fairly extreme weather conditions. In the past month, the thermometer has reached 46C in my area, and I have ridden frequently in temperatures up to 42C after filling the crankcase with Shell Helix 20W-50. ____________________ History shows again and again how nature points out the folly of men - BOC |
| sickpup |
 sickpup Old Timer
| jeffyjeff |
| jaffa90 |
 jaffa90 World Chat Champion
| jeffyjeff |
