Tiny leak after new tyres fitted
Freddyfruitba...
PostPosted: 14:59 - 20 Jul 2026    Post subject: Tiny leak after new tyres fitted Reply with quote
I had my (tubeless) tyres changed about 4 weeks ago, by my usual independent mechanic. Ever since then, I’ve noticed a very slight fall in pressure on the rear. We’re talking about 0.5-1.0 PSI per week, where previously, there was no discernible leakage at all. I've checked the wheel/tyre/valve with soapy water, but no dice.
It’s just a bit irritating, especially knowing I’ll have to put up with this for the lifetime of the tyre. I’m assuming there’s an imperfect seal on the rim? Would it be unreasonable to go back and ask to have it refitted? Or is this level of leakage considered ‘normal’?
panrider_uk
PostPosted: 15:13 - 20 Jul 2026    Post subject: Reply with quote
I'd say no leakage is normal.
Neither my Guzzi nor my Volvo have ever lost any tyre pressure.
I'd have them refitted for peace of mind.
A small leak becoming a big leak at speed wouldn't be fun.
Islander
PostPosted: 19:11 - 20 Jul 2026    Post subject: Re: Tiny leak after new tyres fitted Reply with quote
Check the valve stem for damage/cracks and consider changing the valve core.
PostPosted: 19:24 - 20 Jul 2026    Post subject: Reply with quote
If it was me, I'd replace the valve cores, re-inflate them to about 10psi over normal then let them back down to the normal pressure.
Evens chance it's either a slightly leaky valve core or the bead isn't quite properly seated, this would potentially fix both.
A100man
PostPosted: 09:30 - 21 Jul 2026    Post subject: Reply with quote
One of the guys I use routinely replaces the entire valve..
As an occasional rider I wouldn't worry about it, since I'll generally check before going out. A couple of strokes on a stirrup pump will give you 1 psi.
sickpup
Old Timer
PostPosted: 19:28 - 22 Jul 2026    Post subject: Reply with quote
It's good practice to do so every time you change a tyre.
twowheelwonde...
PostPosted: 19:37 - 19 Aug 2026    Post subject: Reply with quote
I'd take it back. 0.5 to 1 PSI a week isn't disastrous, but if it only started immediately after the tyre change I'd suspect the bead isn't sealing perfectly or the valve got disturbed. A decent mechanic shouldn't have an issue checking and reseating it.
Easy-X
PostPosted: 19:44 - 19 Aug 2026    Post subject: Reply with quote
I had a similar slow loss of pressure on the wife's car. My favourite tyre place found no problem with the tyre and just gave the rim a good clean*
*Fnarr, fnarr
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 55.88 Kb
