ER6 Low RPM trouble
Scrap
PostPosted: 13:59 - 01 Aug 2026    Post subject: ER6 Low RPM trouble Reply with quote
Hi all. I have a 2009 ER6 with 60k on it, normally used a few days a week and earlier this week the bike suddenly started playing up.
At low or idle RPM, the engine is intermittently dropping revs, like a on/off switch - one second it's ok, next second it's dropping revs; it's either dropping revs or it's ok - there's no middle occurrence where RPMs drop slightly. Pulling out of a T junction for example, the bike can stall because RPMs can drop at the same time I let the clutch out, so I have to give it a load of throttle and keep the clutch in for longer.
At over 2.5k-ish RPM the problem goes away. No dropped revs, no skips. I have noticed that when the revs drop, the exhaust can pop, and I can smell unburnt fuel.
On idle, the revs can intermittently drop to about 700 rpm. Revs can quickly bounce between normal 1.1k and 700 so sounds like a rough idle. With a little bit of throttle, it will bounce between, say 1.8k and 700 - it will 'sit' at either and not in between.
It did this on my 20 min journey to work and also the way back, it wasn't a particularly hot day - I've had the bike out doing the same journey when it has been much hotter.
I suspected the throttle position sensor might be bad. So I did some back-probe diagnosis using an oscilloscope on the connector at the TPS and the ECU:
- 0V and 5V are good and stable, when the key is on engine off and engine on.
- When the key is on engine off and engine on, the idle position is dead on 1.0V as per the spec in the Haynes manual, and the sweep is nice and smooth up to 4.4V with the throttle fully open, again exactly as per spec.
- There is no sign of the signal or voltages dropping, the curves are smooth and consistent.
- The readings are the same at the TPS and ECU connectors.
- Connectors at both the TPS and ECU look good, no sign of debris or corrosion.
And of course, the problem has now disappeared... Maybe a crap connection which I've wiggled when diagnosing and inadvertently made better.
So while I wait for the symptoms to come back and do my diagnosis again, what else should I look for? I've ordered a TPS connector adapter so I can probe more easily next time.
PostPosted: 19:16 - 01 Aug 2026    Post subject: Reply with quote
Battery holding a good voltage?
Maybe try a new set of plugs in it, could be dropping a cylinder?
Scrap
PostPosted: 12:24 - 02 Aug 2026    Post subject: Reply with quote
Battery is good, charging system is good.
NGK Iridium plugs were last installed 6,000 miles ago, so relatively fresh. I'll pull them to have a look next time.
I think it's possible that a cylinder is momentarily dropping, I wonder if this was the case, what could be causing it to only happen sub-2.5k rpm? Could dodgy spark plugs or ignition coils do this?
blurredman
PostPosted: 14:56 - 02 Aug 2026    Post subject: Reply with quote
Air leak between carb/barrel perhaps.
PostPosted: 15:16 - 02 Aug 2026    Post subject: Reply with quote
On the previous models (er5 and GPZ500) they did sometimes have a problem with the coil earths. They attach to the frame with a bracket and it would corrode under the bracket, eventually giving a poor connection. I'm not as familiar with the ER6 so i don't know if it's a similar setup but it's 17 years old and in the UK so corrosion is always a possability.
Scrap
PostPosted: 19:58 - 02 Aug 2026    Post subject: Reply with quote
No carb in the ER6, it's fuel injected. Doing a visual inspection and a firm grip and wiggle of the throttle body, it all looks solidly attached and I'm reasonably confident there aren't any leaks downstream of the throttles. Fuel injectors and their connector contacts look fine, for what that's worth.
I balanced the throttles two years ago, I'll check throttle balance again, later.
The connections from the ignition coils go directly to the ECU according to the wiring diagram at the back of the Haynes manual, i.e. no direct frame earth connection.
Corrosion has certainly been an issue! The swing arm had to be replaced and cut in to pieces before it could be removed; holes had corroded though it and the pivot was completely seized. I have replaced about a dozen electrical connectors, chopped off the rectifier connector and soldered the wires directly after needing to deal with a corroded connector for the third time. I eventually took everything off the frame, sanded the frame back and painted it, every bearing was replaced, rebuilt the front forks, new stanchions (old ones had rust pitted), re-built the brakes with new pistons (again rust pitting).
EDIT: I've also ordered a diagnostic connector adapter, to OBD2, hopefully I can use that to read some PIDs.
sickpup
Old Timer
PostPosted: 02:16 - 06 Aug 2026    Post subject: Reply with quote
What mileage are you getting to a tank?
WD Forte
PostPosted: 10:20 - 06 Aug 2026    Post subject: Reply with quote
As its FI and you've done all the basics like good sound connectors and grounding etc.
Trying to get some real time data via the ODB is worth a try but this will depend on what the software will allow you to quiz.
You may only get fault codes.
When you put the scope on did you look for spikes and/or drop outs across the rev range?
Also most of the sensors the ecu quizzes to calcuate timing anf fuel run at 5v and any erratic data, even momentary, can give the ECU conniptions.
Fault codes are usually pretty good but can't alway be trusted.
I'm reminded of the YBR that reported a faulty coil when it was
actually corrosion on the reg/rec terminals that caused the problem.
When they were cleaned, the 'bad coil' got good again.
bikers smell of wee
PostPosted: 18:57 - 06 Aug 2026    Post subject: Reply with quote
Agree with the above. I've been led on a right garden path by fault codes that were something else, BUT, its the place to start as long as the first thing it suggest isn't something stupidly expensive.
That said I bet it's electrical. Even if it's being caused by fuel issues thats going to be caused by the electrics.
If it's electrical I would bet a pound to a pinch of shit it's corrosion somewhere. multi meter on dc voltage or continuity are your friend here but if you are using an oscilloscope you probably know more about electronics than me!
Scrap
PostPosted: 21:43 - 07 Aug 2026    Post subject: Reply with quote
Nothing unusual with fuel consumption, at least from my last fill up, my mpg was where I expected it to be, 56 mpg to be precise.
I had a bit of time earlier today to do some more poking. Not enough time to pull the tank and check the plugs, though.
The problem has come back and is staying apparently. I took the opportunity to scope the TPS again (now with the benefit of the TPS test adapter) the curves with throttle movement are smooth and voltages are where they should be, no spikes or drops, same as last time. I also scoped the signal wire back to the ECU, that's fine too.
With that data point in hand, do you think it's safe to eliminate the TPS and associated wiring as a potential culprit?
The OBD adapter hasn't arrived yet, but I did the diagnostic jumper thing, and there were no active or stored codes, so I suppose there's nothing to lead me down the garden path, anyway. The intention is to see if the live data can tell me anything useful, if it works.
As for next steps, could this be something to do with the secondary throttle? Maybe the actuator or position sensor? It would make sense, to my novice mind, that if something was causing the secondary throttle to improperly close and open at low RPM, it could plausibly cause the problems I'm having?
The list of things to check while I wait for the OBD adapter to fly over from China:
Spark plugs and ignition coils
Secondary throttle, I'm thinking I can visually check the secondary throttle plates right before I pull the air box off to get to the spark plugs, I can open the cover on the air box and have a look at what the secondary throttle valves are doing when they do their range sweep on key on, and when the engine is running and the revs are dropping.
I think it is very plausible that this problem is to do with corroded electrical connectors, any suggestions for potential culprits to check?
I would appreciate any other suggestions!
WD Forte
PostPosted: 11:46 - 08 Aug 2026    Post subject: Reply with quote
I reckon so, its basically a variable resistor and needs to send a clean
voltage signal to the ECU as it moves, so one with a worn track will be notchy and drop out in places.
If it looks clean and consistent id be inclined to dismiss it and look at other sensors plus connectors, common grounding etc
Does it have an 02 sensor ? these have heating elements which can often play up.
At 60k I'd wonder if the fuel system is still tickety boo and try and investigate the pump, filter, pressure regulator and injectors.
If you're lucky its just the weather got in on an electrical connection
bikers smell of wee
Scrap
PostPosted: 15:38 - 08 Aug 2026    Post subject: Reply with quote
This afternoon has been exciting, I found a wasp nest in the air box, and unrelated to that I might have cracked this, if not, at least I have a good clue to work on.
I did a visual inspection of the O2 sensor connector and wiring, looked good, and the resistance check of the heater was in spec.
To do the rest of the diagnosis today, the tank had to come off. But before I removed it, I checked the tank vent, looked nice and clean, I suppose there was no wet weather to drag gunk in to it, for like the last three months. Also ran the engine with the fuel cap off, same problem. With the tank off, all the wires and connectors to the fuel pump looked good.
I did have a peek inside the fuel tank and fuel filter when I changed the fuel level sender (which stopped working) last year, the fuel tank is spotless inside and the filter was tinged beige but nothing concerning.
I had a look at the secondary throttle, it was doing everything I'd expected it do, it would return home on key on and fight against me trying to move it manually, so the motor obviously works and it knows its position. It doesn't hunt and it's always open wide enough to not cause the issues I'm having. So it's not this.
As I was playing with secondary throttle, I noticed that smoke was coming out of the no. 2 cylinder intake when the engine was off after running - smelt like fuel smoke, not oil or coolant, thankfully. Maybe the engine stopped with the intake valves open on no. 2 but closed on no. 1?
The spark plugs looked good, no. 1 and no. 2 looked very similar, evidence of running lean if anything - they're a bit whiter than most I've seen, no notable carbon build up and both were dry when removed.
Smoke again, came out of no. 2 cylinder spark plug hole but not no. 1. Maybe this is to do with one cylinder dropping?
The smoke points to a problem with one of cylinders anyway, so I decided to figure out if it is indeed a cylinder dropping and which.
I decided to run the engine and disconnect the power to each fuel injector at a time; I found that the engine would still run and even start just with no. 1 running (with the injector to no. 2 disconnected) but will quickly stall if the injector to no. 1 is disconnected. When running just on the 'good' cylinder, it's idling like a diesel, of course, but no rev dropping.
Similarly, the engine would still start and run on disconnecting the no. 2 ignition coil, but stall on disconnecting no. 1.
I swapped the fuel injectors over - same thing.
I swapped the spark plugs over - same thing.
I swapped the ignition coils over - now the bike starts and runs on cylinder no. 2 but not no. 1
Hmm...
Unfortunately that's all we have time for today! I'm about to leave for the airport and go on holiday for two weeks, so I'll have to pick this up when I'm back.
While I'm away, I suppose I can still order parts online. I'm not a fan of throwing parts in the hope that it fixes a problem (especially when it's iginition coil levels of money), but this feels like there's enough info to go on and I reckon it's time to order a new ignition coil, or maybe a set because I have to confess, these are aftermarket... Embarassed
Scrap
PostPosted: 15:51 - 20 Aug 2026    Post subject: Reply with quote
I'm back from holiday and the replacement ignition coils (used OEM, from a 2021 Z650) arrived, along with new spark plugs. The OBD2 adapter arrived too but that doesn't fit the bike-side diagnostic connector, so that's going back.
Most importantly, with replacement ignition coils, it's fixed!
Not only have the low RPM drops gone away, the bike idles and accelerates from slow speed smoother than it did before. I suppose the ignition coil(s?) was on its way out for a while.
In summary, for future readers:
- My 2009 ER6 had an issue where at low RPM including idle, the revs would intermittently drop, making slow riding difficult. The problem would disappear at >2.5k RPM.
- On further investigation, it turns out one cylinder was intermittently dropping out
- Doing trial and error, the bike would run if no. 2 ignition was disconnected, but will stall if no. 1 was disconnected.
- Swapping the ignition coils between the two cylinders would swap the stalling observation to the other cylinder, indicating a bad no. 2 ignition coil
- The people warning me not to use aftermarket ignition coils, because they're shit, were right. This set is less than 8k miles old.
- OEM Z650/Ninja 650 ignition coils for the model year 2020-2023 fit and work on the 2006-2011 ER6
- Do not use 2006-2011 ER6 ignition coils, they fit and work but will eventually rust and seize in to the valve cover - which is why I originally replaced mine
I appreciate all the help, funnelled me in the right direction, thanks all.
twowheelwonde...
PostPosted: 13:15 - 24 Aug 2026    Post subject: Reply with quote
Since the tps and signal wires scope clean, swap the two coil sticks side to side before chasing sensors. If the miss follows the swapped coil you've found it for nothing. A coil breaking down only under low load high dwell fits a fault that vanishes above 2.5k. Cheap to rule out first.
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 88.86 Kb
