| UKRedwing |
 UKRedwing Trackday Trickster
| SirEdward |
 SirEdward Could Be A Chat Bot
 Posted: 21:25 - 10 Jun 2011 Post subject: |
And you conclude the crash damage based on modified front fairing and completely sound forks & front end? As for the DB screen, if those two mounting bolts are so crucial, then I'll get a new front fairing spoiler.  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
Pardot Kynes in "Appendix I: The Ecology of Dune"" |
| The Tot |
 The Tot World Chat Champion
| UKRedwing |
| The Tot |
 Posted: 22:11 - 10 Jun 2011 Post subject: |
| SirEdward wrote: |
1200, practically 'traded' a spare Honda CBF-500 for it.  Also, ##Paddy##, yours appears to be not the Y model, K1 have a digital speedo - does yours?  |
Y models were the first of the "superman" types (headlight appearance) so do come with a digital speedo. Fuel injection came in much earlier - 97 or 98 on the SRAD. I was looking at Y/K1 GSXR750's /K1 Thous and ZX9R E's but eventually went for my FireBlade.
If you want to make it LOOK like it hasn't been bodged
Here's a H frame for you
That's for all your fairings
Or just the nose cone
But if you're happy with the way it looks, then that's fine, but the point we're trying to make was for "buyer beware", all too easy for a buyer to be naive and forget to check the most basics, we all make that mistake, or get told about it by our mates, or in this case, the forum.
If I saw something not cosmetically standard, I'd be probing for more questions or I would have run away and got a "mint" SRAD... or something that wasn't as molested as that but with a few scuffs... even IF the price was tempting. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| P.addy |
 P.addy Red Rocket
| SirEdward |
 Posted: 09:54 - 11 Jun 2011 Post subject: |
| UKRedwing |
| The Tot |
 Posted: 10:12 - 11 Jun 2011 Post subject: |
Those mirrors protrude by a significant distance, so based on the gradient or camber on the road, they would MOST definitely be the first things to touch down. A simple side stand drop and depending on the angle which you have you mirror set at will cause the force of the impact to be transmitted to the H frame. Mirrors effectively act as a crash bung... TRUST ME ON THIS! The frames themselves aren't meant to serve as an impact loading brace. Judging by your optimism, you haven't experienced the multitude of minor spills and mishaps so I'm just informing you of the possibilities.
Despite your bike having crash bungs, a LOT of owners tend to fit them "after the horse has bolted" to mitigate against further crashes.
In my opinion, NOBODY in the right mind would want to lop off 30% of their top fairing for "aesthetic reasons" and then put electrical tape over the rough edges and put cheapo mirrors in the wrong place, WHICH i might add, if they aren't supported, WILL fatigue the plastic and crack the fairing (I SHOULD know what I'm talking about because I'm a materials engineer by trade and a part of my work is failure investigation). ABS might be impact resistant, but if you have an unconstrained mirror just bolted onto the underside without any support - then you're just asking for trouble. Heed this warning! That's the reason why that H Frame bracing was ALL IMPORTANT!
As I said, I'm sorry to put a downer but I'm just addressing the facts. It could just be denial over a naive purchase. I bet you it was your first SRAD you saw, and you bought it straight away? Because, had you seen others, you would have noticed the tell tale signs straight away and walked away. (I was in the same position of you when I went of the first ZXR I saw when I was 18... and it turned out to be a lemon - proper money pit) ____________________ The Tot 2019 Z1000SX - 2007 R1
| SirEdward |
 Posted: 10:16 - 11 Jun 2011 Post subject: |
| UKRedwing wrote: | | SirEdward wrote: |
Sweet Jesus.  The RH fairing has a few scratches, it's back up and I'll post pics when I can.  The H frame could've been removed by the prev. owner due to aesthetic reasons, and about the front fairing - I can't picture a crash where the only thing to get damaged are the mirrors.
Occam's Razor does work, but I'm not a simple person.  |
Ok you being quite retarded now so I'm going to make this very simple as to what has very likely happened with your bike.
Someone HAS dropped it on its side, this is fact and you have told us yourself, the side you have not pictured which I suspect has more damage that that from a standing stop drop. Edit: Crash bung has deffinetly saved it duringg low speed crash
When landing on its side it has crushed the mirror which is directly screwed to the H frame, this has screwed the mirror, bent the frame and likely snapped or cracked the 'ears' on the nose cone not to mention the damage to the lower fairing etc
Then muggins has decided it is not worth him buying a new H frame, nose cone and mirror but rather to just bodge the whole front end up.
THE END. |
I think you like tickling my balls, but the photos are up.
I could've bought a 2009 R1 with a full Arrow exhaust as an everyday vehicle, though, I wouldn't be advertising the fact of said purchase, since that would be retarded and asking for it to be stolen, as the modus operandi appears to be in this world du jour.  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
| The Tot |
| UKRedwing |
| SirEdward |
 Posted: 10:25 - 11 Jun 2011 Post subject: |
| The Tot wrote: | Oh yes,
That carbon fibre can, junk it! IT's got a creaseby the end caps. That's the reason why your bike's sounding like a dog since there is a strong possibility that it's blowing if the weave is compromised. It's probably cracked so chances are the crack will propagate and blow the rest of your can off at the very worst.
That what I was talking about, soon to be replaced.
Did I come off sounding like an amateur with this thread? I created this thread, looking for advice for a particular gixxer and its problems. I won't be it taking apart, unless the excellent turn in turned to crap, and the bike's not stable anymore at "um, not 60 MPH".
Thanks for your care regardless, appreciated, but as said: it was dropped on its right side, standing, rolling - doesn't matter, the damage seems appropriate.
Yes and you can see my edit in the quote, I have pictures from my friends srad 50mph spill which he luckily got away with a bent and worn down crash bung, some scratches to the fairing and a broken rear brake lever. |
Physics. If it's such a lucky low-slide, then the person doesn't need to know.  ____________________ "Beyond a critical point within a finite space, freedom diminishes as numbers increase. This is as true of humans as it is of gas molecules in a sealed flask. The human question is not how many can possibly survive within the system, but what kind of existence is possible for those who so survive.
There is a gap of 15 years, 123 days between these two posts... |
| LauraS |
 LauraS L Plate Warrior
| WD Forte |
 WD Forte World Chat Champion
