Breaking NSR125R (another one!)
mr jamez
PostPosted: 19:32 - 15 Apr 2005    Post subject: Breaking NSR125R (another one!) Reply with quote
This is almost a complete bike. 1995 M reg NSR125R. All prices include postage unless specified
New front disc with the inner painted black £40.
Rear disc, loads left on it with the inner painted black £20.
Chain, riveted, might be too long so will need to be fiddled with £10
Complete set of fairings along with a extra set of side panels, some of it is damaged though, all of it needs respraying. Send me a PM about these so I can tell you about the condition of the specific panels.
Forks, they have been rebuilt with new seals etc, stanchions are pitted but this could be sorted quite easily. Fork lowers are painted black £35.
Top and bottom yoke, probably have the head bearings somewhere £25.
Clip ons, one bar end weight £15.
Rear sets for both sides, painted silver £35.
Pillion hangers, painted silver (though paint is gouged on one side)
£20.
Subframe £10, not sure about posting this. Painted silver, not the best of finishes.
Rear light, £10.
Grabrail painted silver, no chips or anything £12.
Shock (probably shagged) linkages (probably shagged) for postage costs.
Frame, have not recieved the V5 yet though. Painted silver, few scratches and chips but is quite a good finish, make me an offer.
Ignition barrel (I cut the connector block off to splice it to another loom so will need bodging) with a key £3.
Seat lock with key £8.
Fuel tank, needs a new filler cap. Whole thing looks a bit fucked so might take the fuel tap out if anyone wants, it £15.
Brand new powervalve cables with the pulley £10.
Clutch cable (new) £6.
Speedo cable £6.
Speedo drive £10.
Choke cable £6.
Complete throttle cable with oil pump cable £10.
Clocks, however the speedo is fucked (needs a new needle) £10inc
Front wheel, painted white, immaculate with a brand new unused pirelli sport demon. £40 (add postage to that)
Rear wheel, painted white which is slightly chipped from the chain rubbing the hub. With a brand new unused pirelli tyre £50 (add postage to that)
Rear brake lever £10.
Gear lever £8.
Pair of front indicators that attach to the side of the fairing £12.
Left hand crankcase (no alternator) needs repainting £15.
Right hand crankcase (with oil and water pump cover) needs a lick of paint, £15.
Complete bottom end of the engine, has done high mileage but if you need any bits out of it then I can strip it down.
Rectifier £10.
Pickup coil £10.
Alternator £15.
Rotor £30
Carb, looks alright, can't be arsed to strip it. £15.
Undertray £15.
CDI, no idea what model it is off (possibly a 1992 F model) the outside is melted on the corner, but works, £10.
NSR125R seat, will only fit the later foxeye models. has a small split, not through to the foam though, £15.
NS125F/R wiring looms. £10 each, probably a bit buggered but you might be able to use them to repair your exisiting loom.
Got a few other odds and ends, loads of bolts and stuff so PM me.
I Only accept paypal or bank transfers. No cheques unless it is for a decent amount, cash is fine providing you come to collect the parts and hand it to me in person (I will take the postage cost off the price)
Oh and no I do not have a front mudguard Laughing
DisabledRider
PostPosted: 03:49 - 17 Apr 2005    Post subject: Reply with quote
out of all that what parts will fit a NSR 2001 R model?
Im looking for front panels (black if possible), and the panel that goes under neath the grab rail.
Thanks
mr jamez
PostPosted: 16:21 - 17 Apr 2005    Post subject: Reply with quote
No, the later foxeye models are totaly different, sorry.
The last post was made 21 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 38.48 Kb
