Failed MOT, need advice UPDATE
fuzz
PostPosted: 11:52 - 16 Apr 2005    Post subject: Failed MOT, need advice UPDATE Reply with quote
The NSR failed the MOT on three things: Headstock bearings, front forks hydraulicing and front pads worn out.
Headstock bearings fair enough. Front forks, too much oil Confused How does that happen? It passed the last MOT and I certainly haven't added any more oil to it! Front brake pads were changed about 1000 miles ago, so how can they have almost worn out completely?
They quoted me ~£160 to do the lot. I'm a bit baffled as to why the latter two need attention. Suggestions?
Claud 14.7 to 1
PostPosted: 12:39 - 16 Apr 2005    Post subject: Reply with quote
Doesn't sound right to me. Confused
Have you checked the pads? And given the front forks a push or two/checked for leaks?
I'm always dubious of garages, especially when they quote me for something straight up. (not that I would know, as my bike's never been a garage, I hate them... but I can imagine.)
*ED* is there even a symptom for too much oil in the forks, apart from maybe oil leaking out? Confused
fuzz
PostPosted: 12:49 - 16 Apr 2005    Post subject: Reply with quote
I have checked the pads, they are worn down. Can't figure out why though. I changed them about 1000 miles ago along with the rear. The rear is fine and I use that quite frequently too. There are no leaks coming from the forks. What do they mean by 'hydraulicing'?
alains
PostPosted: 13:27 - 16 Apr 2005    Post subject: Reply with quote
about your front pads . this thing happens when the disk is dammaged or has unleved surface . i suggest you change the disk with the pads . about your forks , how long since the oil was changed . if you pass your finger along the tube , is your finger greasy ? if yes that's a sign of leak ! the problem is that changing the seals is quite expensive (require at least 1H1/2 work)
Scotsman37
PostPosted: 13:37 - 16 Apr 2005    Post subject: Reply with quote
My friend's bike a got a fail on the front forks last year saying that there wasn't enough dampening effect, and promptly took it back to the original mechanic that replaced the seals & bushels along with new fork oil. The mechanic bounced the front several times and he proved to us there was no sign of poor dampening. His suggestion take it to another MOT and mention nothing about the failed MOT, and so he didn't and it passed with flying colours!
The moral of the story is some garages trump up fails to get more business and so try another place for an MOT and see if they find the so called fault.
In regards to brake pads it could be due to not cleaning the calipers & pistons thoroughly enough with brake cleaner & toothbrush (or something similar) and coating the back of the pads with copper grease, plus the caliper's sliding pin with copper grease too. Your calipers are seizing on and so the pads are being worned down much faster !
alains
PostPosted: 13:43 - 16 Apr 2005    Post subject: Reply with quote
we have the same problem over here , except that the mot are independant from the garages (they are not allowed to repair anything) but the problem is about the qualification of the man who do the job .
Scotsman37
PostPosted: 13:54 - 16 Apr 2005    Post subject: Reply with quote
I totally agree with you because if a test centre (no doubt an apprentice mechanic has to do the job) is so used to testing modern bikes i.e. superbikes, etc, and hasn't tested older bikes from the 70s through to the mid 90s then he cannot tell the what the normal differences in technology does to the suspension, etc.
Another matter that the place where you take the bike to for an MOT maybe is not getting enough business to pay for the bills. So needs to go beyond what is required in the MOT and sets his own standards which are higher in a hope that you will leave the bike with them to fix. No doubt mysteriously find other faults too to make even more money!
Find another place to get your MOT and make no mention of the failed test see if they find the same fault!
fuzz
PostPosted: 13:58 - 16 Apr 2005    Post subject: Reply with quote
I have heard of this happening actually. Maybe if I had them do a service they wouldn't have found anything? I'll get the pads changed myslef agin, and make sure I clean and lube everything up when re-assembling. I'll then take it to another helpful dealer (this one seemed to be in and out as quick as possible, not really answering my questions satisfactorily) who might have a different opinion.
Thanks all.
Scotsman37
PostPosted: 15:21 - 16 Apr 2005    Post subject: Reply with quote
You could try a mechanic, if you want, to test the fork's oil level and that way you'll know if it's right/wrong?
PostPosted: 18:59 - 16 Apr 2005    Post subject: Reply with quote
I have had them fail an older bike before through ignorance on the testers behalf. They failed a bike for having leaky fork seals when it had no oil in the forks, working as it did with dry, grease damped springs. There were no oil seals to leak. He took quite a bit of persuading though.
BikerBen
PostPosted: 12:00 - 17 Apr 2005    Post subject: Reply with quote
Fuzz, before you go and change your pads check your front disc. You said you changed them 1000 miles ago and that they are already worn down. This could be due to (as someone already mentioned) scratches or an unsmooth disc surface causing the pads to wear down quicker.
I recently had to change my rear disc as I didn't realise my pad was worn down. Metal on metal for a while and the disc needs changing. Worth having a look otherwise you will be changing your pads more than you should have to.
My NSR --> https://members.boards.ie/instinct/Diagonal.jpg
Now proud owner of a 1999 ZXR 400
Scotsman37
PostPosted: 13:24 - 17 Apr 2005    Post subject: Reply with quote
If that is the case your disk is badly worn then here's a link to EBC brakes because they sell directly;
https://www.ebcbrakesdirect.com/bike/default.asp?v=bike&part=disc&sec=Jap&make=HONDA&model=51to125&t1=disc
alains
PostPosted: 13:59 - 17 Apr 2005    Post subject: Reply with quote
dear scotsman , they are very expensive !!
fuzz , i suggest you phone tim at https://www.davidsilverspares.co.uk (i saw a rear disk at £45)
but i saw that on ebay (worldwide) coming from germany
https://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&category=32112&item=7968623273&rd=1
and it's new !!! Very Happy
PostPosted: 15:03 - 17 Apr 2005    Post subject: Reply with quote
Another thing that can cause rapid disc wear is if the disc lands up sitting at a funny angle to the wheel.
It is quite common for a lot of corrosion to build up between a cast wheel and the disc causing it to be twisted away from level.
If you remove the disc, you may well find there is a load of white powdery corrosion where the disc fits onto the wheel, scrape this off with an old screwdriver and apply copper grease before fitting the disc.
fuzz
PostPosted: 13:12 - 25 Apr 2005    Post subject: Reply with quote
I took the bike to another dealer for an MOT. They don't repair Honda's, so I was pretty sure I would get an honest test.
I changed the pads last week, and so there was no fail in this respect.
They did not find any problem with the forks. They said that there was alot of oil in them, but it was nothing to fail a test on. They did however find another fault. With the wheel. The rim has become damaged and needs replacing. Which is more costly to repair than the forks would have been. Crying or Very sad
A Honda dealer/servicer quoted around £300 for the wheel, head bearings and fitting. I think I'd rather pay more knowing the faults are real, rather than paying for something that has no problem.
alains
PostPosted: 18:35 - 25 Apr 2005    Post subject: Reply with quote
go on ebay , they have complete wheels
The last post was made 21 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 92 Kb
