problem with?
nsrke
PostPosted: 19:14 - 13 Nov 2002    Post subject: problem with? Reply with quote
i just bought a new battery, because the other one was broken
but when i measure between the clamps of the + and the - pole I only measure 0.9V orso, is this normal?
can somebody with an NS125R from 1988 orso measure this out with him and put it on the board please. what can be the problem with my bike
the battery wasn't connected when i measured this
thanx!
Robby
Dirty Old Man
PostPosted: 19:16 - 13 Nov 2002    Post subject: Reply with quote
did you charge it? and does it have the right amount of acid in?
nsrke
PostPosted: 19:19 - 13 Nov 2002    Post subject: Reply with quote
it is a completely new battery from the shop and they charged it, but the battery wasn't connected!!!!
Guest
PostPosted: 19:37 - 13 Nov 2002    Post subject: Reply with quote
It should be around 12~13 volts, rising to 14~15 tops with the engine running at reasonable revs.
At 0.9V there is something wrong (with me that would be time to check I had selected the right range on the multimeter Rolling Eyes )
Zimma
Wheelie Junkie
PostPosted: 20:50 - 13 Nov 2002    Post subject: Reply with quote
Keith making mistakes like that?? never!! Very Happy
-Zimma
PostPosted: 23:44 - 13 Nov 2002    Post subject: Reply with quote
I was going to say me and electrics dont mix, but the trouble is that they sometimes do Shocked
Guest
PostPosted: 17:42 - 14 Nov 2002    Post subject: Reply with quote
the range was set correctly what could be the problem?
nsrke
PostPosted: 17:43 - 14 Nov 2002    Post subject: Reply with quote
the last post was mine sorry
Ropehead
PostPosted: 17:44 - 14 Nov 2002    Post subject: Reply with quote
the battery!
nsrke
PostPosted: 18:25 - 14 Nov 2002    Post subject: Reply with quote
the battery wasn't connected!!!!!!!!!!!!
and it can't be the battery because it's a new one
Guest
PostPosted: 20:04 - 14 Nov 2002    Post subject: Reply with quote
It does sound like the battery is faulty. There is no way that the voltage should be that low.
Take the battery back to the shop and get them to double check it. Maybe they have done something silly like connected the charger up the wrong way round when they charged it for you. Maybe the trainee filled it with distilled water rather than acid Wink
nsrke
PostPosted: 23:29 - 14 Nov 2002    Post subject: Reply with quote
when i measure the voltage on the battery it ok, it's about 12V
so the battery is nothing wrong with
but when i take of the battery, so it isn't connected any more to the bike,and then I start the engine and I measure the voltage between the positive and the negative pole of the bike(it think those clamps come from the alternator) I measure that 0.9V
PostPosted: 00:43 - 15 Nov 2002    Post subject: Reply with quote
Dont do that. The battery acts as a buffer for the current and protects the regulator / rectifier. Running with the battery disconnected is likely to fry the regulator / rectifier (although I believe you can get away with using a resistor instead of a battery).
To check the voltage with the bike running connect the battery normally, start the engine and then connect the voltmeter between the terminals
The last post was made 23 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.77 - MySQL Queries: 15 - Page Size: 70.26 Kb
