HELP! my oil filter is stuck!!
cqueen
PostPosted: 20:43 - 17 Apr 2005    Post subject: HELP! my oil filter is stuck!! Reply with quote
Ive tried moving it with a chain wrench & the strap type wrench but it just starts crumpling the fliter. How can I get it off? someone suggested whacking a screwdriver through the middle and turning it.
What do you guys think?
PostPosted: 20:46 - 17 Apr 2005    Post subject: Reply with quote
That's what I do with spin-on cartrige type filters.
Remember to lightly oil the o-ring on the new one when you fit it.
rsc
PostPosted: 20:49 - 17 Apr 2005    Post subject: Reply with quote
The only problem with whacking a screwdriver through it is that if you can't get it off after that you'll be stuck with a big hole.
PostPosted: 20:56 - 17 Apr 2005    Post subject: Reply with quote
Aye, but if you can't get it off with that, nothing is going to get it off other than a big stilson wrench. It does need to come off, it has already been crumpled with a chain wrench.
rsc
PostPosted: 21:02 - 17 Apr 2005    Post subject: Reply with quote
true!!
cqueen
PostPosted: 21:14 - 17 Apr 2005    Post subject: Reply with quote
Ok well I guess i'll give the screwdriver a try tomorrow...wish me luck!... any more suggestions are welcome!
White Noise
Mr Dudwee
PostPosted: 22:18 - 17 Apr 2005    Post subject: Reply with quote
Would there be any advantage in soaking the seal in WD40 over night and then again before you try and take it off to try and get some lubication on the join, not sure it would help as the thread is in the middle of the filter, but worth a go.
WN
cqueen
PostPosted: 22:29 - 17 Apr 2005    Post subject: Reply with quote
WN
Yeah I did give it a good sqiurt of WD40, I'll give it another try tomorrow. I dont think it's been changed for years & kind of rusted itself on. I got the chain wrench from halfords and its completley useless, it just starts cutting into the shell.
Whitetrash This post is not being displayed because the poster is banned. Unhide this post / all posts.
White Noise
Mr Dudwee
PostPosted: 22:37 - 17 Apr 2005    Post subject: Reply with quote
Sounds like a screwdriver and lump hammer job to me then! theres nothing like a bit of percussive engineering!
WN
Edit: just found it, what i used last time was a Halfords metal band filter wrench, seemed to do the trick, but the screwdriver option is the cheapest and probibly the most fun!
cqueen
PostPosted: 22:40 - 17 Apr 2005    Post subject: Reply with quote
Screwdriver and lump hammer it is then! Twisted Evil Thumbs Up
MitoIslander
PostPosted: 22:42 - 17 Apr 2005    Post subject: Reply with quote
screwdriver & hammer is what i always use, just.... don't wear a white T-Shirt! Embarassed
Passed the test, now for the paint....
cqueen
PostPosted: 22:45 - 17 Apr 2005    Post subject: Reply with quote
cqueen
PostPosted: 22:47 - 17 Apr 2005    Post subject: Reply with quote
good job i didn't do it today then! lol
Quote Me Happy
PostPosted: 23:24 - 17 Apr 2005    Post subject: Reply with quote
I had this problem the other day. Like everyone has said - a hammer and a screwdriver is the answer. Those chain wrenches are shit - I took mine back for a refund.
Hammer the screwdriver through the filter and use that as a lever to turn it Thumbs Up
Mr C
PostPosted: 23:30 - 17 Apr 2005    Post subject: Reply with quote
you can get an adaptor that sits on the top of the filter and takes a standard 1/2" drive for a few quid
then you can torque it to the correct setting for next time
187.3bhp = 201mph
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
NY_Sniper
PostPosted: 23:47 - 17 Apr 2005    Post subject: Reply with quote
did mine yesterday with a hammer n screwdriver worked 4 me just rember when ur putting the new one on oil the rubber seal and do no over tighten or ull not get that one off eather, screw it on till it touches then give it 1/4 of a turn :)good luck
That Dot On The Horizon .... Its Me
> Kawasaki ZX7R (Betty Jnr) <> Suzuki GS500e in pieces (Bitch) <> Suzuki GS500e (Martha) <>
PostPosted: 23:53 - 17 Apr 2005    Post subject: Reply with quote
I can't see the need for a torque wrench. Finger tight is sufficient.
cqueen
PostPosted: 19:48 - 18 Apr 2005    Post subject: Reply with quote
Success!! the hammer-screwdriver method worked a treat! although i didnt realise how sharpe the puncture was and cut my hand while unscrewing it ...yes I know im a whip! so anyone else attempting that one soon, be careful!
Also, with my new filter I got a new washer, it didnt fit over the thread so what was it for? anyone know?
Mr C
PostPosted: 20:38 - 18 Apr 2005    Post subject: Reply with quote
why guess
there is a torque setting in the manual so why not use it
your idea of hand tight may be a lot more or less than mine and I don't fancy mine weeping or coming off at 11500rpm in top Rolling Eyes
187.3bhp = 201mph
scottiel
PostPosted: 21:11 - 18 Apr 2005    Post subject: Reply with quote
I use a K/N filter it has a socket attachment on the end, so no messing about and it is cheaper than standard filter. Easy Peasy.
Cool
braddas
PostPosted: 22:44 - 18 Apr 2005    Post subject: Reply with quote
hi
is washer rubber or metal?
is the washer the same size as the drain plug ?
my wife say`s i`ve got far too many hobbies !!!!!!
cqueen
PostPosted: 23:54 - 18 Apr 2005    Post subject: Reply with quote
braddas wrote:
hi
It was metal, do you mean where you drain the oil from the sump? maybe it was for there....too late now though because I've filled up with fresh stuff!
The last post was made 21 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 122.08 Kb
