2nd to 3rd gear
Dan
PostPosted: 14:39 - 14 Nov 2002    Post subject: 2nd to 3rd gear Reply with quote
my bike doesnt like going from 2nd to 3rd when going fast, to change it u have to drop the revs, which means slowing down quite alot. its gets a bit anoying when ur doing 70 trying to change into 3rd. is there anything i can do to fix this?
also it is hard toget it into nutural.
cheers
Kris
PostPosted: 14:44 - 14 Nov 2002    Post subject: Reply with quote
I take it you've tried changing the oil? Very Happy
Dan
PostPosted: 14:47 - 14 Nov 2002    Post subject: Reply with quote
gear oil? nah not yet could be worth doing, but i can't see anywere to see the level
PostPosted: 14:52 - 14 Nov 2002    Post subject: Reply with quote
It may just have a dipstick (which is more usefull than a sight glass IMHO).
Guest
PostPosted: 15:09 - 14 Nov 2002    Post subject: Reply with quote
Could well be the gearbox oil. On alot of 2 strokes there is a small screw on the clutch casing. You take this out and then fill the gearbox with oil until it overflows through the screw hole. Not sure about the RGV but it wouldnt surprise me if this is the method to use.
Also check that you have the gearchange lever adjusted correctly. I had this problem with my 1200 Bandit when I bought it and it was due to a weak return spring in the gearbox. Basically when I change up the linkage inside the box didnt return to position correctly so was not ready to select the following gear. Same is possible if the gear lever isnt returning full , for example if your foot is holding the lever up
ROOTLESS
PostPosted: 15:19 - 14 Nov 2002    Post subject: Reply with quote
could be a slight adjustment too your clutch cable required Question Wink
japeneese werewolf in bradford
rod
PostPosted: 15:30 - 14 Nov 2002    Post subject: Reply with quote
Hey Dan,
I had the same problem with my TZR yesterday. The gear change lever had bent slightly when I dropped it so it was nearly impossible changing from 2nd to 3rd. (1st to 2nd was ok for some reason). I just bent it back and it was fine.
Rod
The last post was made 23 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 48.69 Kb
