dt125r running problems
Dusty
King of the Rim
PostPosted: 22:35 - 12 Apr 2005    Post subject: dt125r running problems Reply with quote
My dt, which I've only had running for a couple of weeks has ground to a halt again today.
I'd been riding it for about half an hour and had just done 5 minutes on dual carriageway with it just about maintaining 65mph (I'm guessing it's restricted?). I turned off onto a country lane and it seemed to start loosing power, kept going for about a mile and then cut out almost like it had run out of petrol.
There was a small amount of smoke coming from around the spark plug and that bit of the engine was very hot. So I let it cool down for 15 minutes and tried to kick it over, but it didn't want to start and it felt like there was less compression. I tried bumping it with no joy and the exhaust made strange 'tshhh' noises.
Have now got it home and checked that the plug and it seems to be sparking ok. Tried bump starting it some more with G's help but it doesn't seem to want to go.
Confused
Anyone got any ideas what the problem might be?
Other than this it seemed to have been running ok. I've checked the kill switch, that it has petrol in it and I filled the two stroke the day before yesterday.
Gallery
cagiva gezzer
PostPosted: 22:38 - 12 Apr 2005    Post subject: Reply with quote
Seized? Holed the piston?
Dusty
King of the Rim
PostPosted: 22:49 - 12 Apr 2005    Post subject: Reply with quote
I don't think it's seized because it still seems to turn over fine.
There might be a hole in the piston I guess it did get pretty damn hot, might also be the rings?
Was hoping somebody might tell me it was something less serious than this. Doh! Neutral
Gallery
cagiva gezzer
PostPosted: 22:56 - 12 Apr 2005    Post subject: Reply with quote
When they seize they still turn over as everything contracts back down.
Dusty
King of the Rim
PostPosted: 23:21 - 12 Apr 2005    Post subject: Reply with quote
Ahh ok could be then; didn't actually seem to seize as such while I was riding it, unless it was a fairly progressive seizing, but nothing sudden. suppose it may also have seized just as I came to a halt.
Gallery
killa
Won't Shut Up
PostPosted: 10:10 - 13 Apr 2005    Post subject: Reply with quote
Not sure how old it is but a gasket could have failed.
Or as said before seizure or the rings have disintegrated.
Smoto Bob
PostPosted: 15:27 - 15 Apr 2005    Post subject: bike Reply with quote
when you say it was getting very hot did you look at the temperature gauge on the dials? Sounds like you might have an auto lub problem or something as they tend to run for ever and ever if still resticted.
Should still start with lower compression if you have damaged the rings but they are only like £20 to buy new ones. Just check all the usefull things lean it over make sure the overflow s working/ reeds ect. ht lead
Good luck
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
Dusty
King of the Rim
PostPosted: 11:53 - 18 Apr 2005    Post subject: Re: bike Reply with quote
Unfortunately the temperature guage shows the bike to be completely in the red from the moment I turn it on. Confused If it had of been working I probably would have realised the bike was getting so hot.
Was with you all the way up to 'auto'. Embarassed Laughing
I've tried kicking it over quite a bit, but with no joy. The compression does seem very low, as in pretty much non existant. Will give it another go tonight though if you think there's a chance it will still run and that I won't do any further damage by trying..?
Excuse my slowness, but which overflow should I be checking? Thinking
Gallery
Smoto Bob
PostPosted: 14:03 - 19 Apr 2005    Post subject: bike Reply with quote
If you lean the bike over really far fuel should piss out just means fuels getting into the carb Thumbs Up. If it dont.. then start there Laughing
Auto lub, its just infront of the clutch cover theres the oil pump. Auto feeds the right amount of 2 smoke oil to the air/feul intake just before the reeds on your model. Would check that to make sure its working adjusted and getting oil if you do replace the rings ect(which it sounds like you need to do lol).
Just sounds like you rings have gone really, whip it apart and take it to shop. They shouldnt have don any damage to tha barrel so should be quite cheap as well, Thumbs Up
Temp gauge, lol you got water in it Wink (only useful gauge lol)
Dusty
King of the Rim
PostPosted: 20:32 - 20 Apr 2005    Post subject: Reply with quote
Cheers mate I'll have a look at it this weekend. Thumbs Up
Asked in shop about rings and they said new piston with rings for £50 ??? Seems very cheap. Confused
Gallery
Smoto Bob
PostPosted: 12:40 - 22 Apr 2005    Post subject: piston Reply with quote
na 50 is about right you can get a cheaper copy one if your realy hard up but wouldnt bother lol
J.K.R
PostPosted: 19:56 - 22 Apr 2005    Post subject: Reply with quote
the heat could melted a hole on top of the piston or maybe one of your crank seals has given up the ghost and that would explain the smoking (gearbox oil being burned in the cylinder) Just a suggestion!
EDIT: didnt realise the smoke was coming from the head Embarassed
www.oldskoolsuzuki.info
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 5.16 - MySQL Queries: 13 - Page Size: 76.55 Kb
