Front disk brake 'Grinding'
haGGard
PostPosted: 23:57 - 18 Apr 2005    Post subject: Front disk brake 'Grinding' Reply with quote
Hey, Cool
For about 4 days now, my front disk brake has being acting all weird. I can only describe it as making a 'grinding' sound when i apply the brake. I can also feel the grind vibrations through the lever. The disk is also constantly rubbing quite loudly when the brake is not being applied.
The scooter is currently at 6300 KM and new pads were fitted at 2500 KM. Do you think they would be low already?
If so, is it dangerous to be riding it? Will it damage the disk or is there any chance of the wheel locking up when the brakes are applied?
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
Gazdaman
I did a trackday!!!
PostPosted: 23:58 - 18 Apr 2005    Post subject: Reply with quote
Brakes are something you can't take a chance with.
It all depends how much you use the brakes. If in doubt just pop the pads out and have a look. Replace if necessary.
Gaz
White Noise
Mr Dudwee
PostPosted: 23:59 - 18 Apr 2005    Post subject: Reply with quote
Sounds to me that you have a binding brake i had a simular thing on my rear, that is being a pig to sort out, but hopefully yours should be just a dam good clean of the pistons!
have a look at Korns guide
https://www.bikechatforums.com/viewtopic.php?t=22573
WN
Tarmacsurfer
PostPosted: 00:08 - 19 Apr 2005    Post subject: Reply with quote
You're describing pads that are worn to the metal. Check them immediately, and yes. Use the bike much and you'll end up having to replace the disk as well as the pads.
I'm immortal. Well, so far.
haGGard
PostPosted: 00:13 - 19 Apr 2005    Post subject: Reply with quote
Shocked My scooter could do with a service anyway (and an MOT soon) so ill get that done as soon as possible...
Thanks Thumbs Up
bazza
PostPosted: 00:51 - 19 Apr 2005    Post subject: Reply with quote
Bear in mind that you're now rubbing metal against metal and generating heat through friction every time you use the brakes. It's not unknown to weld the metal in the pads and discs together, locking the front wheel and spitting the rider into, say, a busy T junction like a melon seed...
ZRX61
Victor Meldrew
PostPosted: 01:18 - 19 Apr 2005    Post subject: Reply with quote
Thanks Thumbs Up
TODAY! Do NOT ride the bike with it rubbing like that....
mattsmith95
PostPosted: 01:29 - 19 Apr 2005    Post subject: Reply with quote
Some brake pads don't last long, I once used SBS pads in my GT550 years ago but they didn't last long so I switched to ferodo pads which lasted longer.
These days I use Ferodo platinum, best pads I've ever used and they don't wreck the disc like EBC pads. (I only use EBC if I have no choice)
To be safe, check the pads now before riding, it could save your life.
Flip
PostPosted: 01:32 - 19 Apr 2005    Post subject: Reply with quote
Of all the important things on a bike the brakes will save your life.
Mines in the garage at the mo' with the brakes being stipped, cleaned, new pads & seals fitted and new fluid etc. And resprayed gold again. Because all the paint from the calipers has gone. Rolling Eyes
Took her out today and realised that the brakes were sh1tter than I thought and rode straight to a garage. (The back brakes were better than the front, so they must be bad).
£££ Arse. One of those things. I'll feel safer when I get her back though.
The last post was made 21 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 61.2 Kb
