where could i find a mito wheel bearing??
thuganomics16
PostPosted: 05:00 - 19 Apr 2005    Post subject: where could i find a mito wheel bearing?? Reply with quote
hi everyone, the title says it all really. im having a hard time trying to find a front wheel bearing for my 1991 mito does anyone have any idea what size is needed please? as everyone i have spoken too has no idea....thanks in advance Smile
Guest
PostPosted: 07:11 - 19 Apr 2005    Post subject: Reply with quote
Any industrial bearing factor will have one for about a fiver, but you'll need the size. Best bet is to drop the wheel out, remove the bearing and take it along.
PostPosted: 09:06 - 19 Apr 2005    Post subject: Reply with quote
Yep, the old bearing will have a number stamped round the edge of the outer race. If you drop it out, take it to a bearing factor (the bearing or the number off it) and they will most likley have them in stock with prices ranging from £2.50 to £10. Take their advice for which would suit your application best.
You can find bearing factors in the yellow pages, if they don't have your bearing in stock, they should be able to get it by the next day or they are not worth their salt. Smallness of shop front does not necessarily denote lack of stock, most of their business is supplying industry and industry demands rapid bearing supply. A broken 50p bearing can hold up an entire production line.
If you need the bike to go pick them up, you might be able to read the number off the bearing if you drop the wheel out and remove the circlip/dust covers without disturbing the berarings then replace them again.
Most motorbike wheel bearings are 6202 but this is not a hard and fast rule, you have an exotic bike so sods law dictates it will be different.
cagiva gezzer
PostPosted: 12:15 - 19 Apr 2005    Post subject: Reply with quote
The quick option is to phone up Mito Mondo and get some OE bearings. You will be raped for price.
The other option is to get some from M&P. They're £4.99 a side but i'm not sure what the size is. They might know what sizes they are.
But as said, the sizes should be etched on the outer race.
stef234stef
PostPosted: 12:27 - 19 Apr 2005    Post subject: Reply with quote
I donno if this will help but https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=36796&item=7969179524&rd=1&ssPageName=WDVW#ebayphotohosting
cagiva gezzer
PostPosted: 12:33 - 19 Apr 2005    Post subject: Reply with quote
Good try. Close, but not close enough...
Scotsman37
PostPosted: 17:14 - 19 Apr 2005    Post subject: Reply with quote
Here's a retailer of Cagiva wheel bearings and so you could contact them.
https://www.dimons.co.uk/aboutus/accessories.asp?parts=Cagiva
PostPosted: 18:00 - 19 Apr 2005    Post subject: Reply with quote
Given the code for the bearing on that site is "6004DDU" it looks like it is a 6004 bearing. Ask for a 6004 2RS (the 2RS is for 2 rubber seals).
planet rider
PostPosted: 18:04 - 19 Apr 2005    Post subject: Reply with quote
if i read this earlier i could have asked in dimmons while i was in there for you but its too late now as iam home. Confused
they can usualy get parts but it takes bluddy ages for bits unless they got them in stock.
Xj 900
thuganomics16
PostPosted: 02:24 - 20 Apr 2005    Post subject: Reply with quote
thanks for all your help lads, this site and the people on it kick arse! if i ever need anything your allways here to help so thanks to everyone who has helped me out with various things. you all deserve a knighthood Thumbs Up
PsychoHippy
Jammy Git
PostPosted: 04:53 - 20 Apr 2005    Post subject: Reply with quote
If you get no luck from any them, call Paul at DMA Racing on 01666 510456. He is a Cagiva dealer and will be able to send one out to you via the old snail mail.
I spend all my money on bikes and beer, the rest I simply waste!
thuganomics16
PostPosted: 23:21 - 20 Apr 2005    Post subject: Reply with quote
thanks psycho, got the bearing sorted Thumbs Up
now one more thing if you would be so kind.... any ideas where i could start looking for the micro switch on the rear brake pedal? thanks in advance Smile
thuganomics16
PostPosted: 00:27 - 21 Apr 2005    Post subject: Reply with quote
as im such a pain in the arse theres one more thing i just tought of....i also need a new rear light bulb, now is this just a standard bulb or am i going to spend the next 3 months trying to find one? thanks Very Happy
(beggining to think it was a bad idea buying an import Rolling Eyes )
Dom_
Points Mean Prizes
PostPosted: 00:32 - 21 Apr 2005    Post subject: Reply with quote
Bulbs a bulb mate. Idea
Scotsman37
PostPosted: 00:44 - 21 Apr 2005    Post subject: Reply with quote
Cagiva Mito 125 light bulbs;
Twin headlights with Bilux lamps 12v 25/25 Watt
Parking light bulb 12v 5 Watt
Blinker Bulb 12v 10 Watt
Brake light bulb 12v 21 Watt
Just checked the Hein Gericke manual and you're out of luck there!
Here you go and you can see if it's the same type;
https://www.beedspeed.com/bulbs.htm
https://www.norbsa02.freeuk.com/goffybulbs.htm
satans_BIG_helper
PostPosted: 00:50 - 21 Apr 2005    Post subject: Reply with quote
get LED bulbs for the rear light m8 its what i done its much better i think and they dont screw up as often as normal bulbs
PostPosted: 00:56 - 21 Apr 2005    Post subject: Reply with quote
Think the rear brake light switch is a pressure switch built into the banjo bolt holding the hose onto the rear brake master cylinder.
thuganomics16
PostPosted: 23:23 - 21 Apr 2005    Post subject: Reply with quote
dont have a spare one then? Mr. Green
satans_BIG_helper
PostPosted: 14:06 - 23 Apr 2005    Post subject: Reply with quote
If you need any parts for that get intouch with scottie at reservoir cogs as he has a complete Mk2 mito and i think he may be breaking it soon..
https://www.reservoircogs.com
pipnet11
PostPosted: 19:49 - 23 Apr 2005    Post subject: Reply with quote
What he said. Put the code into google, someone will have it. It wont always be used for the same thing, so ignore the stated use and look for the correct code. My gearbox layshaft bearings were sold as yamaha DT125 driveside cranckshaft bearings Laughing As long as the code is the same they will be fine.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
The last post was made 21 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 106.92 Kb
