god dam rear brake pistons
White Noise
Mr Dudwee
PostPosted: 22:52 - 18 Apr 2005    Post subject: god dam rear brake pistons Reply with quote
Right i have the back brake off my bike and got the piston that was stuck all the way out, which leaves the one that had free play on it in the piston chamber, i know that it will come out and not siezed, but short of putting the other piston back in and connecting to the brake system i don't know how to get it out, its right in the chamber i have thought about compressed air but can't get a good seal from the pump to the brake line hose bolt connector.
Any ideas would be most appriciated! Thumbs Up
Cheers
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
Guest
PostPosted: 07:19 - 19 Apr 2005    Post subject: Reply with quote
I've shifted 'free' pistons using a footpump via the bleed nipple (just cracked open) and just blocking the banjo bolt hole with my thumb. You have to pump like a dervish to keep the pressure up, easier with two pairs of hands.
I clamp the caliper half in the vice with soft jaws and this helps block any oilway through the caliper body
The last post was made 21 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 31.67 Kb
