engine heat
gimpy limp
PostPosted: 10:48 - 21 Apr 2005    Post subject: engine heat Reply with quote
what temperature do bike engines generally reach? Can you spray the block with normal 2pack bodywork paint? I know car rocker covers you can but the actual block you can't. Do they get as hot as car engines? (i've already got the paint save me having to buy more paint if I can use it)
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
dainesefreak
PostPosted: 10:49 - 21 Apr 2005    Post subject: Reply with quote
Mine doesn't I use cold fusion. Shocked
gimpy limp
PostPosted: 10:52 - 21 Apr 2005    Post subject: Reply with quote
much difference in heat between air cooled and water cooled?
killa
Won't Shut Up
PostPosted: 10:55 - 21 Apr 2005    Post subject: Reply with quote
I had an air cooled AR50 bored to an 80 with CDI ignition thing. It rev’d to around 12 grand, and it did 65mph and after a short trip to town you could feel the heat coming off it.
You could easily cook an egg on it Thumbs Up
The temp gauge didnt work but i'd say over 90 degrees or something.
Bendy
Mrs Sensible
PostPosted: 11:03 - 21 Apr 2005    Post subject: Reply with quote
Hot enough to heat the frame up so it burns your legs. Ow.
gimpy limp
PostPosted: 11:05 - 21 Apr 2005    Post subject: Reply with quote
shame, that'll be too hot then Confused hammerite time I think
dainesefreak
PostPosted: 11:12 - 21 Apr 2005    Post subject: Reply with quote
Not got a new R1 have you? Wink
Claud 14.7 to 1
PostPosted: 11:17 - 21 Apr 2005    Post subject: Reply with quote
Hammerite no good for high temp places. Has insulating properties, and on the block or even the rocker cover it wouldn't work.
You need specific high temperature paint.
Engines get very very hot.
gimpy limp
PostPosted: 11:22 - 21 Apr 2005    Post subject: Reply with quote
people use hammerite on car engine blocks all the time, not sure what gets the hotter bike or car engines, water boils at about 70/80 iirc so car engines (and in theory watercooled bike engines should be the same) should be around the same as that.
in theory
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:39 - 21 Apr 2005    Post subject: Reply with quote
You want to see the rhs NC30 frame when it gets hot. If you dropped the bike on it's side I'm sure you could fry an egg on it.
PostPosted: 14:21 - 21 Apr 2005    Post subject: Reply with quote
Err, water boils at 100 degrees, and higher temperatures under pressure. Temperature gauges on vehicles regularly go up to 120 degree, and some areas (such as near the exhaust manifold) will be far hotter than the coolant temperature.
Claud 14.7 to 1
PostPosted: 19:08 - 21 Apr 2005    Post subject: Reply with quote
OK use Hammerite then, I don't mind it's not my engine.
Before you do though, be sure to read the side, where you'll find it says do not use for high temperature applications. Rolling Eyes
mchaggis
PostPosted: 19:12 - 21 Apr 2005    Post subject: Reply with quote
Barbecue high temperature black. It works on exhausts, so there's no reason to suggest it shouldn't work on the engine. That's not to say that if it's an air cooled engine it won't overheat though.
I must not be a troll...
Mmmm, Guinness
Davo
Davo To The Rescue!
PostPosted: 19:47 - 21 Apr 2005    Post subject: Reply with quote
Had the temperature guage on the R6 hit 104 degrees today, just whilst filtering through heavy traffic, soon dropped off when I got on to the dual carriage way.
hustler
PostPosted: 19:53 - 21 Apr 2005    Post subject: Reply with quote
Reading the manual for my GSXR it says:
"When the coolant temperature is higher than 120 degrees C the display flickers and the indicator light (6) comes on. Futher if the temperature exceeds 140 degrees C the displays "HI" and the indicator light at (6) remains on."
I'd say that was hot.
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
gimpy limp
PostPosted: 20:07 - 21 Apr 2005    Post subject: Reply with quote
https://img.photobucket.com/albums/v311/K8CEE/block1Custom.jpg
https://img.photobucket.com/albums/v311/K8CEE/block3Custom.jpg
400ml spray can of hammerite and i know countless numbers of people that have done the same/\
it's too shiny that stuff but thats besides the point
Claud 14.7 to 1
PostPosted: 00:17 - 22 Apr 2005    Post subject: Reply with quote
You specified Hammerite paint, this won't work.
Hammerite Products Ltd. do do a High temperature version, so I suggest you look out for and use that.
Just so you don't choose the wrong one and mess up your engine. Good luck.
The last post was made 21 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 94.74 Kb
