NEED HELP ON GSXR 1100 M OILCOOLER
cronic
PostPosted: 12:37 - 22 Apr 2005    Post subject: NEED HELP ON GSXR 1100 M OILCOOLER Reply with quote
I POPPED THE OILCOOLER ON MY 1100 AND SINCE IT IS A CUSTOM BIKE I WANT TO REPLACE THE OILCOOLER WITH A AFTER MARKET COOLER. THE BANDIT 1200 OILCOOLER IS MOUNTED WITH THE INLET AND OUTLET ON THE BOTTOM OF THE COOLER. THE 1100 HOWEVER THE IN/OUTLET IS ON THE TOP OF THE COOLER. WILL IT BE POSSIBLE TO MOUNT THE AFTERMARKET COOLER WITH THE THE IN/OUTLET ON THE BOTTOM ?? I CANT FIND MUCH DIFFERENCE BETWEEN THE COOLING SYSTEM OF THE BANDIT & THE 1100M.
bish777
PostPosted: 18:12 - 22 Apr 2005    Post subject: Reply with quote
The engines are basically sub versions of the same motor.
You should be able to buy new oil hoses that will be the right length to do what you want without fuss and connect to the top. I also think it should work fine if you turn the cooler upside down lol.
GSXR1100J
The last post was made 21 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 31 Kb
