scottoil viscosity
tsmith
PostPosted: 22:13 - 23 Apr 2005    Post subject: scottoil viscosity Reply with quote
Anyone know what the viscosity of Scottoil is? The official stuff is quite expensive and if ordinary cheap 10w40 engine oil would do I'd rather use that.
Frost
PostPosted: 22:55 - 23 Apr 2005    Post subject: Reply with quote
Scot oil isn't that expensive. £5.50 for a few thousand miles worth.
Scot oil is water based and probably won't mix well with engine oil. engine oil on the chain also attracts dirt.
If you do use engine oil get th thinnest stuff you can (20W50?)
Bezzer
PostPosted: 00:41 - 24 Apr 2005    Post subject: Reply with quote
Chainsaw oil is about the closest and a lot cheaper especially if you have a local Agricultural type supplier you can use, failing that a DIY store.
sickpup
Old Timer
PostPosted: 22:04 - 24 Apr 2005    Post subject: Reply with quote
ATF fluid.
The last post was made 21 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 38.07 Kb
