Getting corossion off a frame!?
Barry_M2
PostPosted: 16:09 - 25 Apr 2005    Post subject: Getting corossion off a frame!? Reply with quote
The frame of my NSR250 is very pitted and has patches all over it where its been standing for a while.
Can anyone recomend anything I can use to get it nice and shiny and looking good again!?
Ta
iCraig
PostPosted: 16:23 - 25 Apr 2005    Post subject: Reply with quote
How about getting it powder coated, it would mean a total strip down of the frame but the outcome is worth it.
cqueen
PostPosted: 16:31 - 25 Apr 2005    Post subject: Reply with quote
I tried using 'Kurust' it's a chemical which eliminates corrosion. however you have to be very very careful with it or it turns surrounding areas black (I wasnt careful enough). I'm going to
clean it up again and give the frame a coat of aluminium paint...
I hope this will do the trick, does anyone know otherwise?
Barry_M2
PostPosted: 16:32 - 25 Apr 2005    Post subject: Reply with quote
Thought about it, but too much hastle. Might rub it down and give it a coat of paint!
Just wandered if there was anything out there like some metal polish or something that would get rid of the blotchy bits!
Josh|RD125LC
PostPosted: 16:34 - 25 Apr 2005    Post subject: Reply with quote
I have the same problem with my RD. I was recommended sand blasting, then powder coating it, but this proves to be quite costly in some cases. I was told it would cost around 80 quid. The only other thing I can suggest is getting a heat gun, heating up the corroded areas and using a wire brush. Seems to work, my dad did this to his 350LC frame and it came up pretty good.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
flat spot
PostPosted: 18:13 - 25 Apr 2005    Post subject: Reply with quote
EEK!! be very careful if you do this. To much heat and you'll change the property of the metal which could be catastrophic!!!!
bish777
PostPosted: 18:22 - 25 Apr 2005    Post subject: Reply with quote
not with a hot air gun, on a steel bike frame! lol
Id just get my drill with wire brush, get the rust off then generously coat with hammerite.
GSXR1100J
The last post was made 21 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 51.87 Kb
