back brake not working
phill.c
PostPosted: 17:56 - 25 Apr 2005    Post subject: back brake not working Reply with quote
as in title, i put new chain and sprockets on this weekend and when i came to ride it the back brake is hardly working the pads are ok, so do you think i'll need to bleed it and put fresh oil in?
ive got a cbr400 nc29 and do a current type oil?
and any rough idea of how much bleeding kits are?
CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed Smile
westendboy7
PostPosted: 18:10 - 25 Apr 2005    Post subject: Reply with quote
Yes. You should bleed brakes and maybe change fluid. Check that the pistons are moving freely too
Mike
bish777
PostPosted: 18:18 - 25 Apr 2005    Post subject: Reply with quote
all you need to bleed your brakes is a small washing up liquid bottle and some plastic hose.
Make sure the bottle is the flip up lid type with a small lipped spout. Attach the hose to the spout. Cut the bottom of the bottle off so its open. put a small hole near the bit youve just cut off so you can hang the bottle upside down (the end you cut off facing up) off the frame with a bit of wire or string.
Hang the bottle near the bleed nipple and attach the hose t the nipple, it should be a firm fit.
open up the reservoir and top up the fluid. Depress the brake lever and undo the nipple. Pump the lever like mad , continually topping up the reservoir. Fluid will begine to fill up the bottle. Once there is plenty of fluid into the bottle and no bubbles appear, keep the lever depressed and tighten the nipple.release the lever and then oumo a few times.
Voila bled brakes! once you have the bottle attached and are pumping fluid it only takes a minute or two.
This works much better than-press lever-open nipple-close nipple-release lever.
GSXR1100J
Mr.Everready
PostPosted: 20:10 - 25 Apr 2005    Post subject: Reply with quote
You shouldnt need to bleed the brakes just because you've had your wheel off.
Method
PostPosted: 20:13 - 25 Apr 2005    Post subject: Reply with quote
Have you tried simply pumping the brake through properly? You'll need to pump your brake to get the system under pressure again...
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 21 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 44.64 Kb
