Problem with Electrics? (Kawasaki)
rsc
PostPosted: 19:27 - 25 Apr 2005    Post subject: Problem with Electrics? (Kawasaki) Reply with quote
Hello again,
A quick question for those in the know.
A friend of mine has a GPX750, and has recently had problems with the bike, losing power, etc.
He replaced the battery around Christmas time, I think it is an electrical problem, as the bike goes fine for a while (after the battery has been charged).
Anybody got a checklist we could go through to get to the bottom of this!
Thanks
Ian (GPX)
PostPosted: 19:35 - 25 Apr 2005    Post subject: Reply with quote
Could be the regulator / alternator, check that these work first.
Also make sure all wires / connectors are not broken / loose.
rsc
PostPosted: 19:39 - 25 Apr 2005    Post subject: Reply with quote
thanks, I will have a word with him tonight.
bish777
PostPosted: 20:20 - 25 Apr 2005    Post subject: Reply with quote
Yeah sounds like the regulator is buggered. You can pick up a universal item thats cheaper than OE from MandP.
GSXR1100J
Bezzer
PostPosted: 21:50 - 25 Apr 2005    Post subject: Reply with quote
Put a voltmeter across the battery terminals, should read anything from 12.3 to 13.2 fully charged to be OK.
Then run the engine with the voltmeter still attached, the volts should rise with increased rpm peaking around perhaps 14.5 ish volts at probably 5,000rpm. If it doesn't get anywhere near the 14.5 or is way over then the reg/rec is probably duff (it might be the alternator but that's another story.
The last post was made 21 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 42.67 Kb
