Rusted on bolt
R4nger
PostPosted: 11:19 - 26 Apr 2005    Post subject: Rusted on bolt Reply with quote
I have tried to get a rusted bolt off my engine that is seized on. So far I have tried mole grips, lots of WD-40, sledgehammer, normal hammer. I have also tried to drill a hole in the bolt in the other side and try and turn it by putting the thread in the hole and trying to turn it with a spanner but this just wipes the thread out. I then put a nut in the hole and then tried to whack it with the sledge hammer but this eventually bent the nut. It just won't shift. Any ideas are welcome
Picture:
https://www.bikechatforums.com/files/engine_bolt.jpg
Barry_M2
PostPosted: 11:54 - 26 Apr 2005    Post subject: Reply with quote
Is there a nut on one end, or is there a thread in the frame / engine mount?
On your pic, can you highlight where there is a thread? Wink
R4nger
PostPosted: 12:13 - 26 Apr 2005    Post subject: Reply with quote
The nut was kindly angle grinded off by the break as I assume he could not remove it as you can see on the right side of the picture. It is actually ment to slide all the way through the frame and engine on both sides with spacers in between and there is thread on the end to tighten it.
It is on the left side of the picture where it comes out of the frame.
Klause
PostPosted: 12:23 - 26 Apr 2005    Post subject: Reply with quote
Your fooked! Laughing
Lots of heat, wd40, oil and most of all brute force and ignorance.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Barry_M2
PostPosted: 12:27 - 26 Apr 2005    Post subject: Reply with quote
So, the frame has a tread also cut in it!?
Hmmm! Like Klause said, lots of heat, hit it with a hammer to loosen the rust, dont put alot of stress on it trying to turn it or you will just end up rounding the head off.
Only other way is to drill it out, then re-cut the thread if need be.
sychosis
PostPosted: 12:48 - 26 Apr 2005    Post subject: Reply with quote
this might seem stupid, but have you tried jacking the engine up a touch?
Bikes owned: Aprilia RS 125 GP1 2003 (Now sold), Suzuki GSX-r600 1997 (streetfightered), https://www.bikepics.com/members/sychosis/
psy?cho?sis (si-ko-sis),n. pl. psy?cho?ses (-sez) ,A severe mental disorder, with or without organic damage, characterized by derangement of personality and loss of contact with reality and causing deterioration of normal social functioning.
ZRX61
Victor Meldrew
PostPosted: 15:14 - 26 Apr 2005    Post subject: Reply with quote
He didn't even mention using a 6pt socket & a breaker bar... Rolling Eyes
The last post was made 21 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 53.47 Kb
