| swaffs |
 swaffs World Chat Champion
 Posted: 09:09 - 26 Apr 2005 Post subject: :?: Bike not starting when hot. :?: |
I've got a problem with my CBR600 FY, where if I turn my ignition off when the engine is hot (which I have to do every morning to go and get my carpark pass) when I come back out to the bike 2 minutes later, the bloody thing wont start, it's almost as if the battery is not giving enough charge to turn the starter motor.
I can bump start it fine and have done each morning this and last week.
when I return to the bike at the end of the day it starts just fine so the battery is not actually flat (providing I hadn't tried too many times to start it in the morning).
I dunno why but I'm thinking reg/rectifier is overheating maybe?
I hope somene can help me with this as it's doing my head in each morning and I was tempted to pop into the office this morning with the engine left running, but I suspected I would have come out to no bike!! (this is central london)
Anyone any ideas? ____________________ Swaffs Photography |
BCF vinyl stickers
"Look not back in anger, nor forward in fear, but around you in awareness." |
| Black Knight |
 Black Knight World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
 Posted: 10:11 - 26 Apr 2005 Post subject: |
Reg/rec problems.
Contacts/block/wiring not making contact, as Scotsman37 says. Too high resistance in the wires. Earthing possibly, even loose battery terminal contacts could cause this.
Stator and/or wiring.
Seems like the battery is being drained somehow.
Doubt it would be fuel, as it's the turning over power that isn't making it catch.
If I had to guess right now, I'd say reg/rec.
You'll have to hook up a multimeter and start testing the power going back into the battery. It is quite possible the Reg/rec is burning up, as this is exactly what happened to my fault unit. Except the bike would lose all of its charge and just cut out when the revs settled to idle speed, leaving me stranded with no battery power to turn the bike over, in the middle of no-where.
So anyway, hook up the multimeter to the battery, rev the bike up to 4-5,000 and check the charging rate. It should be a healthy 13-15v regardless of what electrics are on. The ultimate test is with ALL the electrics on as it will be operating under max "load".
Also feel the reg/rec mine got very hot after about 1 minute, and until then it was working properly and charging up the battery fine. As soon as it got hot, it gave me the problems. They do get hot by nature but too hot and or too soon means they're faulty. Haynes gives you a test procedure for the reg/rec, although I didn't find it very helpful. |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Kickstart |
 Kickstart The Oracle
 Posted: 13:04 - 26 Apr 2005 Post subject: |
Very much doubt it is the regulator / rectifier. After all that affects charging, and the battery has loads of charge at the end of the day (and from the description Swaffs gives it seems it is cranking over happily, just that if he does it long enough he kills the battery for the end of the day).
Would be inclined to say that it is fuel vapour. Check for any blocked / misrouted carb breather. Check for a missing heat shield for the carbs.
On carbs the old Weber carbs used to suffer from this. The way round it was to try starting the car with the throttle open a fair way (just back off quickly as soon as it caught). Not sure you could do this effectively with CV carbs but it might be worth a try giving it full throttle.
| swaffs |
 Posted: 13:19 - 26 Apr 2005 Post subject: |
OK, when I try and turn the ingine over if it is hot.
IT tries to crank it over but dies after less than a second (like a flat battery)
but there is pleanty of charge because i can keep on trying it (well about 10+ times until it does actually lose charge)
It doesn't actually spin up, it's as if it doesn't have enough power to spin the starter motor. ____________________ Swaffs Photography |
BCF vinyl stickers
| Claud 14.7 to 1 |
| Wave2k |
 Wave2k G's Stalker
| Ian (GPX) |
| swaffs |
 Posted: 15:41 - 26 Apr 2005 Post subject: |
Cheers guys,
Ian can't check this stuff yet as I'm busy at work.
I'l check the voltages tonight and wil then know if the charging system is working ok.
and have a look into the starter relay.
I'm thinking a bettery replacement might be a good choice anyway as it's never been great since I've had the bike. and then I can review the sutuation.
Swaffs ____________________ Swaffs Photography |
BCF vinyl stickers
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| swaffs |
 Posted: 19:02 - 26 Apr 2005 Post subject: |
I started straightaway when leaving work, but as soon as I got home I tries again and.....
same thing:
took a little video on my phone:
MP4 version
AVI (sound only)
I've a feeling the battery is just getting old and not man enough to start the bike when warm.
Bend came up with good idea to try starting the bike via jumpleads when it is hot. ____________________ Swaffs Photography |
BCF vinyl stickers
| mchaggis |
 mchaggis World Chat Champion
 Posted: 19:21 - 26 Apr 2005 Post subject: |
An off the wall suggestion? It sounds a bit as though the starter is running fine, but being prevented from working properly, perhaps by clearances in the starter mechanism closing up when it's hot?
Obviously, try the jump lead approach to discount my idea, I doubt a starter clutch rebuild would be much fun; hopefully I'm barking up the wrong tree. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Kickstart |
 Posted: 20:05 - 26 Apr 2005 Post subject: |
While batteries do recover some charge if left for a while, I would doubt this is the problem. If the reg / rect was Donald Ducked then if would likely not charge the battery at all. Might do as you describe once, but likely that by the time you got home it would be totally flat.
Also it normally needs a fair amount more power to start a bike from cold than from hot. When cold the oil is all thick and results in a fair bit more drag.
It could well be the battery is on its last legs, and a new one might solve the problem but I am not convinced that it is all the problem.
Whatever happens, stick a voltmeter over the battery and see what it reads as you blip the throttle. This will hopefully confirm that it is charging OK.
| Ian (GPX) |
| swaffs |
| swaffs |
 Posted: 21:53 - 26 Apr 2005 Post subject: |
ok just been doing some tests.
Battery voltage was steady at 12.3V when engine off.
and at 14.5V when engine running, dropping slightly with lights/indicators etc on.
so no problems with charging...
I left the engine running long enough for the fan to cut in (hotter then it got today on way home)
and it just started fine for about 5 times !!!!
I then have just been out for a 'spirited' ride for 20 minutes. although the bike didn't get 'that' hot (1/2 way)
I shut the engine off, and then on starting, the starter motor span about 6 times before appearing to go flat.
I whacked the voltmeter on and tried again, this time the voltage dropped to about 5V during the starter motor spinning and it nearly fired.
next attempt at start it did fire...
I suspect it's not enough of a run to test it, my normal commute is 30minutes+ through central london i.e not very fast but lots of little sprints to keep the bike warm!!
I did notice when checking the voltage during the last couple of times trying to start, the the starter motor relay was clicking occasionally, although I suppose that would happen.
Thanks for all assistance so far... ____________________ Swaffs Photography |
BCF vinyl stickers
| yohomiesmelly... |
 yohomiesmelly... Two Stroke Sniffer
| swaffs |
 Posted: 22:28 - 26 Apr 2005 Post subject: |
ukbilleh,
that is just what I'm thinking and discussing in irc now.
I have had issues with the battery before not holding charge after a 40mile motorway blast, but hat seemed to fix it self. ____________________ Swaffs Photography |
BCF vinyl stickers
| Ian (GPX) |
 Posted: 22:38 - 26 Apr 2005 Post subject: |
| swaffs wrote: | | Ian (GPX) wrote: | I had a listen to the avi ..... it sounds just like my problem I had when engine was warm, starter motor sounds as if it's not getting the required power to turn it over, check the starter relay out.
It could be the starter motor, it might need a rebuild / replacing, but check the above first. |
Ian, any advice what to check with relay? |
Check the contacts and wires that go to it.
The starter relay should have 2 large wires, one from the battery, and one that goes to the starter motor, with the ignition on, bridge the two wires with something heavy, like a pair of pliers, see if this starts the bike when you have the problem again, this will bypass the relay and send current to the starter motor, be careful, don't jump when it sparks, a lot of current will go through. If this turns over the motor, then that will be 99% of your problem. |
The last post was made 21 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
