putting bike in neutral before starting
JakeyC
PostPosted: 11:50 - 27 Apr 2005    Post subject: putting bike in neutral before starting Reply with quote
how can i find neutral if my engine isnt started to see the neutral light, or can i turn the power on but not then engine, nsr 125 by the way, is it best just to get off your bike and put it into neutral so the next time you start it you dont need to find it??? not alot of experience on geared bikes Embarassed
mchaggis
PostPosted: 11:52 - 27 Apr 2005    Post subject: Reply with quote
You should be able to see the neutral light with just the ignition on, but if you can't, you can find it by going all the way down into first, then clicking into neutral like normal. Roll the bike to see if it is in gear or not. It won't roll more than a few inches either way if it is in gear, whereas in neutral it'll roll wherever you push it.
I must not be a troll...
Mmmm, Guinness
dainesefreak
PostPosted: 11:53 - 27 Apr 2005    Post subject: Reply with quote
Put it in neutral turn the engine off and get off. Shocked
JakeyC
Thumbs Up thanks, first time i left it into gear i started it and had to grab it before it shot into the road lol Embarassed
Smile Thumbs Up
dansuresh
PostPosted: 11:54 - 27 Apr 2005    Post subject: Reply with quote
you could just make sure its in neutral by siting on it and trying to push it forward..if its in gear it wont move forward much..
You sould be able to just turn the ignition on with out starting the bike and if theres a neutral light it will tell you.
I normally just leave it in neutral when i park the bike up.
Hope this helps
Dan
Section59
PostPosted: 12:14 - 27 Apr 2005    Post subject: Reply with quote
Smile Thumbs Up
I always use the clutch when starting, even if its says its not in gear - Just incase..
Done it too many times on off-road bikes that it has now become one of those things i always do...
Bomberman
PostPosted: 12:32 - 27 Apr 2005    Post subject: Reply with quote
Same here, hang over from years of car driving where starting in gear can cause real problems. On a 2 stroke 125 though, with a decently healthy weight person sat on it it's not going anywhere if you start it in gear. Well, mine won't Very Happy 'Bout 2 inches.
Liverpoolrobb...
PostPosted: 14:54 - 27 Apr 2005    Post subject: Reply with quote
knock it down 5 times and then 1 up
and there you go
Bomberman
PostPosted: 15:40 - 27 Apr 2005    Post subject: Reply with quote
and there you go
Doesn't really work with 2 strokes. Not standing anyway. Plus it should really be down 5, half up Wink Very Happy
Aikman666
PostPosted: 16:30 - 27 Apr 2005    Post subject: Reply with quote
Yeah i agree with everyone else, count gears, then roll to check. P.S this might be just my gearbox but you might find you'll have to roll the bike back and forward to change gear while off!
Will work for petrol
My Design Blog
tony532
PostPosted: 19:15 - 27 Apr 2005    Post subject: Reply with quote
you will be able to tell when you turn the ignition on
i usually use my hand to put the gears into neutral when the bike is on the side stand and i want to turn the bike round in the morning
bish777
PostPosted: 19:47 - 27 Apr 2005    Post subject: Reply with quote
If you have trouble putting it in neutral at a standstill, let the clutch out till it bites slightly and roll the bike back and forwards as you try and change gear.
GSXR1100J
loply
PostPosted: 21:18 - 27 Apr 2005    Post subject: Reply with quote
Hold the clutch in when you start the engine.
The day you trust the neutral light is the day you drop your bike, whilst parked on a hill, in the middle of a bike meet, and create a dominoe effect.
Yamaha SZR660 Caution to the wind, the throttle pinned!
JakeyC
PostPosted: 00:13 - 28 Apr 2005    Post subject: Reply with quote
cheers guys great help Very Happy Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 11:57 - 28 Apr 2005    Post subject: Reply with quote
A modern bike really shouldn't start in gear.
My XJ just flashes a red light at me when I'm doing something stupid, in gear, side stand etc.
But yes, as a rule, hold the clutch in. Not on my MZ though, if you hold the clutch in, the kick start does nothing and I wonder why there's no resistance.
Gaz
Fortuna
PostPosted: 19:46 - 28 Apr 2005    Post subject: Reply with quote
You can usually "feel" it.
lurker
PostPosted: 20:32 - 28 Apr 2005    Post subject: Reply with quote
and there you go
suggest you get your bike looked at if you can knock it down 5 when its at a standstill
fuzz
PostPosted: 20:57 - 28 Apr 2005    Post subject: Reply with quote
Gazdaman is right, you shouldn't be able to start the NSR while it's in gear (I know cause I've tried it). Some bikes do (Yam SR125 for example) but the NSR shouldn't. Just remember to put it into neutral before you turn off the ignition.
The last post was made 21 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 98.29 Kb
