WHAT MODEL NEW YAMAHA XJ600
itu_baba
PostPosted: 18:31 - 27 Apr 2005    Post subject: WHAT MODEL NEW YAMAHA XJ600 Reply with quote
I got this used Yamaha XJ600 but can not confirm if it is a diversion or not and would like to know the year of manufacture.
Engine # is: 2200CM3, chassis is: 4BP-02587. Can anyone help. Seems I need replace the engine and need advice.
bish777
PostPosted: 19:53 - 27 Apr 2005    Post subject: Reply with quote
send me a piccy, ive owned one.
I had a grey import USA model and they call it a Seca 2.
https://www.bikez.com/bike/index.php?bike=12087 this is a old XJ600
https://www.bikez.com/bike/index.php?bike=891 this is a diversion XJ600, the engine is very different!
GSXR1100J
Gazdaman
I did a trackday!!!
PostPosted: 23:19 - 27 Apr 2005    Post subject: Reply with quote
Kindly note that top picture is of my actual bike.
and, the one behind it is a 900 diversion. Depends which one yours looks most like.
Gaz
itu_baba
PostPosted: 13:31 - 09 May 2005    Post subject: MY XJ 600 PICTURES Reply with quote
I have taken pic of the bike, Hope you can view the attachment.
Gazdaman
I did a trackday!!!
PostPosted: 14:00 - 09 May 2005    Post subject: Reply with quote
Diversion, naked.
Gaz
White Noise
Mr Dudwee
PostPosted: 20:45 - 09 May 2005    Post subject: Reply with quote
as gaz said
XJ600n
bish777
PostPosted: 23:01 - 09 May 2005    Post subject: Reply with quote
Its also single front disc and is therefore the first model btw.
I had a first model Diversion ( US import 'Seca 2') and a friend had a second model XJ600N, the only difference being single and twin front discs, and a few plastic bits.
GSXR1100J
White Noise
Mr Dudwee
PostPosted: 23:05 - 09 May 2005    Post subject: Reply with quote
Didn't know that, Thumbs Up means i have a first model then, its an import but don't know where from!
WN
bish777
PostPosted: 23:10 - 09 May 2005    Post subject: Reply with quote
single front disc just means less expense when it comes to changing pads!
GSXR1100J
itu_baba
PostPosted: 18:58 - 10 May 2005    Post subject: Reply with quote
TANX,
I need an engine for this bike. Where can I get a good working one and the traficators
PostPosted: 19:21 - 10 May 2005    Post subject: Reply with quote
Indicators should be easy. You can buy cheap copies of the original Yamaha indicators.
Best bet for an engine is a breakers yard, or take a bit more of a risk and buy one from Ebay.
What is the problem with the engine on yours?
itu_baba
PostPosted: 13:25 - 12 May 2005    Post subject: Reply with quote
The culch was faulty, does not let go completely. Bought a complete kit bought it did not work (maybe wrong model). eventually got another kit but now engine very slow and smoking a lot.
PostPosted: 14:15 - 12 May 2005    Post subject: Reply with quote
My guess would be that the problem is the thrust bearing in the clutch. These are very cheap, but the Divvy seems to wreck them.
The Haynes manual says to lube them with engine oil. The Yamaha manual says to use molybendium diasulphide grease.
The last post was made 21 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 75.76 Kb
