Steering Dampers
Kaben
PostPosted: 20:32 - 27 Apr 2005    Post subject: Steering Dampers Reply with quote
How do these things work/what do they actually do?
Been looking through some catalogues and they look like a hydraulic piston that you attach to the back of your bars and attach to the stem also . Do they just make turning the bars slower or what? im confused by them. Shocked Confused
Its Not a Melon, Its Clearly a Lime!!
Yamaha Fazer 600Now dead, MZ 125 SM
My Deviant Art homepage https://robabloke.deviantart.com/
Method
PostPosted: 21:25 - 27 Apr 2005    Post subject: Reply with quote
The idea is that it stops your bars flapping about at high speeds or when cornering, yes they use hydraulic pistons.
i was going to get one for my GS500 but couldnt find anywhere that did one... without me having to take down hundreds of measurements and mounting points etc... for them to create one =/
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
mchaggis
PostPosted: 21:34 - 27 Apr 2005    Post subject: Reply with quote
Hydraulic dampers - a cylinder with a hydraulic piston with holes in it for the hydraulic fluid to pass through it. The size of the holes controls the rate at which fluid can pass through the piston, and so control the highest speed at which the piston and hence the bars can move.
https://www.turbomonster.com/Originals/Matris.jpg
The cylinder is fixed, and the piston is attached to the top of one of the forks. You can get into a situation where the bars flap violently and pretty much uncontrollably from one side to the other, particularly if you land a wheelie with the front wheel to one side - on landing, it gets whacked back past the centre, or whacked over to full lock. Either way, the wheel overcorrects itself and can set up an unstable growing oscillation - a tank slapper, which will spit you off eventually.
Steering dampers on the whole prevent the bars from moving quickly enough to allow a tank slapper.
https://www.bikechatforums.com/files/steering_damper_schematic.jpg
I must not be a troll...
Mmmm, Guinness
Kaben
PostPosted: 00:04 - 28 Apr 2005    Post subject: Reply with quote
thanks guys, thats helped out alot Thumbs Up
The last post was made 21 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 41.56 Kb
