| gmoney |
 gmoney L Plate Warrior
| gmoney |
| Fruit'n'nut |
 Fruit'n'nut Could Be A Chat Bot
 Posted: 01:00 - 28 Apr 2005 Post subject: |
Do you mean crash-bungs which mount via the engine-mounts, like this?
https://img.photobucket.com/albums/v392/FruitNnut/cutout.jpg
I appreciate that my gsxr is a little different in that the bung doesn't sit in the middle of a fairing-section.
What you should find is that the mounting-point doesn't actually provide any support to your fairing as it's an engine-mount, as far as I know. (At least it doesn't on the CBR600RR, where the crash-bung sits mid-panel.)
What you need to do is mark the inside of the fairing somehow, so you know where to drill a pilot-hole ... a blob of paint on the end of a bolt should do the trick
Once you've got a small hole drilled, you should be able to use a rotary tool (like a Dremmel) to open the hole up gradually, to fit the body of the slider/bung.
Disclaimer: my advice is purely that - advice - which you should verify. I take no responsibility for you making a bodge job of fitting sliders to your bike  ____________________ Power Ranger
| Fruit'n'nut |
 Posted: 01:04 - 28 Apr 2005 Post subject: Re: come on guys |
| Mr.Everready |
 Mr.Everready World Chat Champion
| Fruit'n'nut |
 Posted: 13:44 - 28 Apr 2005 Post subject: |
| G |
 G The Voice of Reason
 Posted: 14:01 - 28 Apr 2005 Post subject: Re: frame sliders |
Right.
You want the bolt on ones that go through the engine/frame. These act as the bolt that replaces them.
There is no fairing mount in this place, so you do not disrupt the fairing.#, apart from cutting the hole.
The ones that only mount to fairing holes mounts can often can cause more damage than they save; they can actually break the fairing when it may have got away just with minor scuffs if you didn't have anything on!
I have just got a set of r6 ones from these people:
https://www.loscrashprotection.com
Haven't 'tried them out yet'... but if it stays wet I may be this weekend . It is a small business run by a couple that seemed quite friendly and willing to accomadate. |
| Mr.Everready |
| Fruit'n'nut |
 Posted: 14:15 - 28 Apr 2005 Post subject: |
| Mr.Everready |
| gmoney |
| gmoney |
| Fruit'n'nut |
The last post was made 21 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
