U-Turn on practical test
kawakid
PostPosted: 23:37 - 28 Apr 2005    Post subject: U-Turn on practical test Reply with quote
Hi,
Further to my earlier post, my mate just said when he did his, he had to use clutch and throttle.
However I've been doing clutch, throttle & rear brake.
So been reving quite high, but braking and moving in a very tight turn.
Am I f*****
Does it matter?
I've a twin and a 4.
Ian (GPX)
PostPosted: 23:55 - 28 Apr 2005    Post subject: Reply with quote
Clutch, throttle & rear brake = correct way.
epz
PostPosted: 02:43 - 29 Apr 2005    Post subject: Reply with quote
it just means he has better throttle control, its possible to do a U turn with throttle only.
they dont care how you do it as long as you do your observations and dont put your foot down you will be fine, its not like you wouldnt be able to use a rear brake in real life.
the bike test does have some stupid rules like not puting the sidestand down before you get off but the guys actually want you to pass and arent out to be petty.
wantser
PostPosted: 09:48 - 29 Apr 2005    Post subject: Reply with quote
I was told that you can jolt round just as long as you make it!!
Dont worry about reving too high, ride the clutch as much as you like. They are wet clutch's on motorbikes rather than like a car. They can take so much more punishment. It is best to use the back brake as it keep your speed under control, its just about bringing it all together.
Practise makes perfect! Find the way you find most comfortable or successful as it were and do it that way. I didnt get them down until the day of my test!
Good luck
An expert is a person who has made all the mistakes that can be made in a very narrow field
black_mamba
PostPosted: 17:21 - 29 Apr 2005    Post subject: Reply with quote
I was under the impression that using the back brake in u-turns wasn't test-approved, don't know why. Question
JonB
Afraid of Mileage
PostPosted: 19:03 - 29 Apr 2005    Post subject: Reply with quote
I didn't bother using the back brake or the front brake for that matter at all today and my instructor said it was fine. Cool
Kye
PostPosted: 23:40 - 29 Apr 2005    Post subject: Reply with quote
I found an easier way of doing it is to make the turn as tight as possible when your setting off, so you're already facing backwards way before the centre of the road, that way by the time you're on the other side and worrying about slowing down, keeping your balance etc, you're just rolling forward slowly up to the kurb, instead of still turning.
Ducati 600SS
Vespa PX125
Josh|RD125LC
PostPosted: 00:39 - 30 Apr 2005    Post subject: Reply with quote
I'm dreading doing a U-Turn on my RG, its basically the size of the RS, maybe a bit wider. I tryed turning the RG a few days ago while moving, and it takes hell of a turn circle to do it.
Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures
JodieWodie
Reflective Banana
PostPosted: 01:44 - 30 Apr 2005    Post subject: Reply with quote
I got a minor for my u-turn but I passed it !
I used clutch, throttle, and kept rear brake on a lot.
Just ease yourself round...if you judder a tad so what!?
You will make it.
As long as you don't go mentally shaky or put your foot down you will survive it and get a pass.
A lot of people say that since the test they don't use their u-turns ...but I use them daily..especially outside my daughter's school.
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
m99dws
PostPosted: 11:08 - 30 Apr 2005    Post subject: Reply with quote
If you have a good controlled slow riding technique it will help. The most important factor however is "Look where you want to be, not at the kerb".
The last post was made 21 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 63.21 Kb
