My battered RGV250
2Smoke
PostPosted: 11:59 - 29 Apr 2005    Post subject: My battered RGV250 Reply with quote
Thought I'd take some pics of the beastie while it was still in one piece..
https://img.photobucket.com/albums/v139/two_smoke/trackday/Image1.jpg
https://img.photobucket.com/albums/v139/two_smoke/trackday/Image2.jpg
https://img.photobucket.com/albums/v139/two_smoke/trackday/Image3.jpg
Specs are; 1991 RGV250M, Huxley pipes, kit ignition, total loss electrics with lightened flywheel, straight plug heads with TZ combustion chamber, kit spec barrels, ported and flowed running an O ring head gasket conversion, modified reed cages, kit spec carbs, open airbox with cold air feed, Ohlins rear shocker, maxton front forks, gsxr600 front calipers, braided lines, custom made aluminium subframe, sprint steering damper. More dents than a very dented thing. rear wheel horsepower is 70+ ponies.
Looks like shite but does the job nicely! Smile
Jon
Anyone for donuts?
PostPosted: 12:15 - 29 Apr 2005    Post subject: Reply with quote
Looks pretty good to me Thumbs Up 70+ bhp Shocked Cool
Frost
PostPosted: 19:11 - 29 Apr 2005    Post subject: Reply with quote
What rubber you running?
18" rear?
Running 2 pistons rings or just the one?
Av gas heads?
2Smoke
PostPosted: 19:46 - 29 Apr 2005    Post subject: Reply with quote
Hi 17" rear 150R 110F metzelers
2 ring pistons standard pistons bar being balanced to each others weights.
Avgas heads 8.5cc volume
2Smoke
PostPosted: 19:49 - 29 Apr 2005    Post subject: Reply with quote
sorry they are rennsport rs2. very sticky Smile
I used to race a 250K too, handle way better than the later versions!
M1ke
Ped Boi
PostPosted: 20:45 - 29 Apr 2005    Post subject: Reply with quote
Couldn't you tell from the pattern of the tred?
2Smoke
PostPosted: 23:35 - 03 May 2005    Post subject: Reply with quote
Just when it was all going so well it has developed a serious water leak... oh well back to the garage with it Sad
Gazdaman
I did a trackday!!!
PostPosted: 00:41 - 04 May 2005    Post subject: Reply with quote
Very nice bike!
This is the current state of my TZR250 race bike..
https://www.gaz-racing.co.uk/bike/TZR/DSCI0063(Small).JPG
Gaz
2Smoke
PostPosted: 08:00 - 04 May 2005    Post subject: Reply with quote
Tidy m8... I got one of them in my garage but its a lot messier (even more so since it was involved in a 'racing incident') but it has a well tuned 350lc lump in it..
https://img.photobucket.com/albums/v139/two_smoke/P1010228.jpg
https://img.photobucket.com/albums/v139/two_smoke/P1010229.jpg
where do you race? ever do anglesey?
Gazdaman
I did a trackday!!!
PostPosted: 12:49 - 04 May 2005    Post subject: Reply with quote
Atm I've never been on a track in my life. The TZR or my MZ 250 will be the first to enter some bemsee rounds next year.
I should also be doing a track day next month aswell.
That is a nice TZR, those 350 lumps don't half shift.
I'm always amazed the extents racers go to to get the racing edge. Removing chokes, kick start mechs, drilling holes in casings etc.
Who do you race with? Didn't think you could put an rd lump in a tzr in the YPM?
Gaz
2Smoke
PostPosted: 17:50 - 07 May 2005    Post subject: Reply with quote
Hi well the tzr is raced in forgotten era where basically anything older than 1989 can race.
The holes etc in the motor are due to the dry clutch as it is a tz350 bottom end, and there is of course no kickstart fitted to them.
I remove a lot of stuff, the whole kickstart mechanism weighs a ton, the bike doesnt need choke to start so theres less clutter plus I made a lot of stuff in alloy to cut down on the weight!
Paul
The last post was made 21 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 68.4 Kb
