| zip70 |
 zip70 Nova Slayer
 Posted: 22:32 - 30 Apr 2005 Post subject: custom exhaust under engine question! |
does it matter hoiw long the downpipe between the engine and the end can is? will it effect the power?
the reason i ask is that i wanna weld a stubby endcan onto the downpipes, just under the engine, in front of the rear wheel, know what i mean??
https://www.hondacb1.com/images/front9.jpg ____________________ gixer 6 |
| Bezzer |
 Bezzer World Chat Champion
| bish777 |
 bish777 World Chat Champion
 Posted: 23:23 - 30 Apr 2005 Post subject: |
Youll need to rejet! It will need much richer mixture than stock as the stubby is going to be far less restrictive.
If your making this kind of mod you may also want to drop your airbox, fit pods and go to a stage 3 dynojet kit, or a factorypro kit to suit.
It will be difficult to get right-you either fork out and get a pro to do it, or like me spend months fiddling and fine tuning.
in this order, set things up:
1) Ensure float heights are set correctly (as per your manual)
2) Select the right jet-the one that lets the bike rev freely and gives good power to the redline
3)Fine tune things by raising or lowering the needle.
Your plugs are a good guide as to the state of carburetion, your aiming for a nice light brown colour. If its black and sooty go leaner (smaller jet, or lower needle by putting the e clip in a higher notch). If the bike is running too lean the plug will look glazed, and go the opposite way.
Change the jet if no amount of fiddling with the clip height gets it running right.
If you are running very rich the bike will 'bog' down and youll get a wet note from the exhaust, a sort of flabby note. Lean will get you loud popping noises and the accelleration will be very lurchy.
If you get the stage 3 dynojet kit, id suggest as your fitting a fairly open pipe, use the mid size (marked 128) jet as a starter. As im using a road legal pipe i used the 124 jet. Bear in mind dynojet sizes are NOT compareable direct to kehin or mikuni sizes. the dynojet 124 is roughly a 144 mik jet and the 128 is a 150 i think. ____________________ GSXR1100J |
| epz |
 epz Scooby Slapper
| Bezzer |
| sickpup |
 sickpup Old Timer
The last post was made 21 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
